Dealing With Beam Height Offsets For Coffered Ceiling? - Finish Carpentry - Contractor Talk
Old 06-23-2015, 07:52 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
How do you typically deal with beam height offsets on a coffered ceiling?
Situation:
-Beam has a routered edge profile that would require mitering if kept on the same level.
-1/2 Beam around perimeter
-2 Beams running each direction on interior
Should I run all the beams through running north and south and then raise the beams running east and west 1/4"?
It is stain grade hickory.
As usual I'm flying by the seat of my pants. Found out today at 4:00 this was my project for tomorrow.
Lewis Carpentry
Spencer is offline
Old 06-23-2015, 08:47 PM   #2
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,740
Re: Dealing With Beam Height Offsets For Coffered Ceiling?
Keep the beam bottoms at the same elevation. Miter and preassemble the beam sides and crown. It's a much cleaner look than the off sets.
To align and reinforce the joinery I use biscuits cut with a 5/32 slot cutter in a router or splines cut with a 1/4" slot cutter. With the beam sides over hanging the bottom any over cut with the router will be covered and if you use biscuits you can slide them in from the sides if you need to.
Justin Huisenga is offline
The Following 2 Users Say Thank You to Justin Huisenga For This Useful Post:
JesseCocozza (06-23-2015), Spencer (06-23-2015)
Old 06-23-2015, 08:58 PM   #3
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,260
I'm with Justin on this one Spencer. Typically will run string lines or laser for keeping elevation lines.
StrongTower is offline
The Following 2 Users Say Thank You to StrongTower For This Useful Post:
Justin Huisenga (06-23-2015), Spencer (06-23-2015)
Old 06-23-2015, 09:07 PM   #4
JesseCocozza's Avatar
Rewards Points: 810
Situation:
Well, you have the option like the computer sketch you did, but if the perimeter is a true half beam vs, just a band, then I personally would match the elevation. I would install all the nailers first set with a laser line if you have one, and then run all the bottoms, then treat each box separate with mitered corners.
As mentioned before 1/4" spline works great for the butt joints. Just make sure to keep the east and west runs uniform to the north and south runs.
For the mortise and spline, we also use a slot cutting bit in a router mounted in a portable router table, works great with the fence and father board set up so all the slots stay uniform.
We recently did a coffered ceiling where they asked for a different sort of intersection and it turned out really slick in my opinion. It also helped because the material was milled at slightly different thicknesses so it helped by not having to sand all the joints perfectly flush.Dealing With Beam Height Offsets For Coffered Ceiling?-imageuploadedbycontractortalk1435111448.402020.jpgDealing With Beam Height Offsets For Coffered Ceiling?-imageuploadedbycontractortalk1435111496.949599.jpg
You could also see if the mill shop can put a dado on the back of the side pieces to help keep the bottom reveal perfect throughout.
EDIT:
Sorry spencer, I just realized it was you, and we already discussed that intersection.
JesseCocozza is offline
The Following 2 Users Say Thank You to JesseCocozza For This Useful Post:
greg24k (06-24-2015), Spencer (06-23-2015)
Old 06-23-2015, 09:11 PM   #5
Livin the dream...
Spencer's Avatar
Thanks for the timely responses guys. Miter them I shall.
I'll try and post some pics as progress gets going. It's going to be a sweet room. Hickory coffered ceiling, walls will be completely covered and paneled with hickory, hickory fireplace, and the safe room gets a concealed door. Should be fun.
Lewis Carpentry
Spencer is offline
Old 06-23-2015, 09:22 PM   #6
Livin the dream...
Spencer's Avatar
Is there a rule for how you handle the joints on the beam bottoms? Which runs run through and which ones butt into the one that run through? I assume on the perimeter half beam the bottom/horizontal 1x should be mitered in the corners?
Lewis Carpentry
Spencer is offline
Old 06-23-2015, 09:53 PM   #7
Given the choice I use a butt joint in the corners. Frequently the design calls for a miter. It's a toss up.
If the material lengths allow I run the longest lengths through.
The Following 3 Users Say Thank You to Justin Huisenga For This Useful Post:
JesseCocozza (06-23-2015), Spencer (06-24-2015), StrongTower (06-23-2015)
Old 06-24-2015, 04:03 AM   #8
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
You won't have as much mitering to do if you make the bottom piece the one with the profile on it instead of the sides. Boxes will go quick and then you can partially miter in the bottoms.
dave_dj1 is offline
Sagging Beam Chris Johnson Remodeling 32 03-15-2015 09:01 PM
Wood framing/furring for suspended drywall ceiling akm Carpentry 30 04-24-2013 09:42 PM
Mildew On Ceiling Mitch M General Discussion 7 08-28-2012 07:00 PM
Eng beam question boot83 Framing 5 04-14-2009 10:36 PM
