Cutting Off PH - Door Stop - Finish Carpentry - Contractor Talk
Old 06-22-2015, 03:46 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,248
The pic is from google just shows what I'm starting with.
Customer has 2 closets with 2-2/0 swing out doors - each closet. 2 1/4 clamshell casing - painted.
They want mirrored bi-pass doors which I've installed before. They got a quote from the box store labor only near $1000 - they're R&R molding, tear this and that out - no painting of course.
I can do 2 ways - cut off the stop - overlay the 4 9/16 jamb with clear pine - leave the casing and all - install the mirrored bi-pass.
Or, dado out 3/4 or 5/4 and overlay to make a clean jamb. The 1" or so diff in the doors / bi-pass (as you see them) is not a problem with the customer.
Question - if I have to cut off the PH stop - how best to do that ? I have a Feim MM ---- any other ways ? The MBR is occupied.
We Fix Houses is offline
Old 06-22-2015, 07:46 PM   #2
rrk's Avatar
Rewards Points: 2,340
Re: Cutting Off PH - Door Stop
Unless I am missing something isn't the stop just nailed on?
rrk is online now
Old 06-22-2015, 07:54 PM   #3
Pre hung split jamb. The stop is integrated into the material.
Old 06-22-2015, 08:07 PM   #4
rrk's Avatar
Ok, we don't have those here, never seen one.
But I guess I would use a multimaster.
rrk is online now
Old 06-22-2015, 08:12 PM   #5
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Rip it out and install new solid jambs. When installing new trim slightly widen the reveal to cover the old paint line on the wall. Its easier if you first coat the trim on horses and second coat in place. There should be no need to repaint walls and the doors will fit properly.
JAH is offline
The Following 2 Users Say Thank You to JAH For This Useful Post:
MarkJames (06-24-2015), Tinstaafl (06-22-2015)
Old 06-22-2015, 08:39 PM   #6
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
Easiest cheapest way, which is what they seem to want. Would be to rip a dado into your new jambs.
Screwing around with a multimaster would be my last choice.
mgb is offline
The Following User Says Thank You to mgb For This Useful Post:
thezoo (06-24-2015)
Old 06-24-2015, 08:08 AM   #7
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Have only seen it nailed on or on here as well. Rip it out and rebuild. It will be faster cleaner and save headaches. As mentioned above trying to cut it off would be my last choice. You will be sanding and preping and they will be looking it over like a used car salesman.
kingcarpenter is offline
Old 06-24-2015, 08:20 AM   #8
thezoo's Avatar
Rewards Points: 238
I think both are close in time, mm would fly through that, a few minutes. Overlay new jambs.
Grab router, edge guide and have at it, got a big enoug dado bit or do you need 2 passes? If so, mm is faster.
If they want to pay to have it look original tear out the split jambs and install new, for more $$$
thezoo is offline
Old 06-24-2015, 08:48 AM   #9
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,295
If you overlay, you get a wide reveal, so that's out. If you MM the stop on a split jamb it can fall part before you're finished anyway. .
JAH has it right.
MarkJames is online now
Old 06-24-2015, 04:22 PM   #10
Kolbym's Avatar
Trade: Trim and Light Remodel
Rewards Points: 228
How would cutting out the stop be any quicker than tearing out and installing solid jambs? By the time you tear the old jamb to pieces with a mm, router, Sawzall, whatever, then try to rig it to make it look like a solid jamb, you could have installed and painted new ones.
Kolbym is offline
Old 06-24-2015, 04:23 PM   #11
Kolbym's Avatar
Rewards Points: 228
Oh yeah, and you just cut out half of the structural part of the split jamb...Now what?
Kolbym is offline
The Following User Says Thank You to Kolbym For This Useful Post:
JAH (06-25-2015)
Old 06-24-2015, 07:51 PM   #12
rrk's Avatar
A stop is structural on a doorjamb? Especially one that will be getting sliding doors?
And an overlay is needed any way so the sliders overlap, you are making it a much bigger job than it really is. Cut it off stop, install overlay, paint overlay, done.
No replacing and painting trim, possibly needing to paint walls etc
rrk is online now
Old 06-30-2015, 09:16 PM   #13
C&C Custom Trim's Avatar
Trade: Interior trim
Rewards Points: 226
The stop is structural on a split jamb. There won't be any shims either more than likely. Cut the stop and it's all gonna fall apart.
C&C Custom Trim is offline
Cutting through 3' of concrete H&S Excavation Commercial Construction 9 12-29-2011 12:48 AM
Glass tile cutting Aaron Tritt Tiling 13 06-06-2011 01:46 PM
Problem cutting in bad drywall job tripster Painting & Finish Work 23 02-10-2011 10:33 AM
apprentice having trouble cutting accurately likeke34 Carpentry 193 12-21-2009 01:29 AM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 10:54 AM
