Cutting A Mitre In A Radius - Finish Carpentry - Contractor Talk
Unread Yesterday, 11:01 AM   #1
florentinepogen's Avatar
Trade: Fences
Rewards Points: 4
Hello. I'm constructing a pretty high end fence, atleast for me, out of cedar. See pic of panel i sketched. it's not to scale. I would like to know your thoughts on how to layout the mitre on the radius piece. it is cut from 1x6 stock measuring 2.5" wide and it lays flat against the lattice. there will be a cap placed on top which is not shown. the straight piece is straight forward but i dont know how to properly cut the angle on the radius piece. i would like to cut with an electric mitre saw to get a tight mitre....but it's curved and it doesn't sit against the saw's fence!
florentinepogen is online now
Unread Yesterday, 11:21 AM   #2
Railman's Avatar
Trade: Railing
Rewards Points: 609
Re: Cutting A Mitre In A Radius
To get cut line, just overlay curve over the straight & mark intersect points. I'd do the curve cut 1st, & then the straight. The length of the cut line has to be the same on each piece.
As far as how to hold in mitre saw, it just depends on profile. On railings, we tend to rest the bottom flat of curve against the fence so it touches fence just beyond cut. Then adjust turret degrees to make cut.
Railman is offline
The Following 6 Users Say Thank You to Railman For This Useful Post:
Deckhead (Today), hdavis (Yesterday), pinwheel (Yesterday), rrk (Yesterday), SmallTownGuy (Yesterday), Tom M (Yesterday)
Unread Yesterday, 01:10 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,391
Tack it to a square panel of scrap, lining up the "outside" corners of the radius (inside of fence) exactly. Cut the 45 off that (one end only, in your case)
MarkJames is online now
asevereid (Today)
Unread Yesterday, 01:29 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,681
Yup. Pretty much a educated guess to get the correct miter angle. Do as Railman says to find the miter, you'll get it close enough and personally I'd just lay it out on the miter saw and put the concave side side against the fence and hold it down tight and go slow with the saw. If the blade is sharp you won't have any issues. Then just match it with the straight pc.
Cool fact. You can't really do this with a straight cut. Both the curved pc and the straight pc need to be cut with a slight convex/concave curve to make everything line up perfectly. The bigger the molding the more noticeable it becomes.
Doing it with a straight cut certainly gets it close enough for most all applications.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
TheConstruct (Today)
Unread Yesterday, 01:34 PM   #5
LRG WoodCrafting
Leo G's Avatar
Someone noticed the issue in this thread on Woodweb.com
http://www.woodweb.com/knowledge_bas...Mouldings.html
http://www.belleartae.com/bn/blog/1/...ight-mouldings
https://www.thisiscarpentry.com/2019...unting-miters/
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Unread Yesterday, 02:18 PM   #6
MarkJames's Avatar
Actually, I don't think that's going to end up a true 45 on the top piece.
Therefore, overlapping/intersecting line method is the way.
Unread Yesterday, 02:58 PM   #7
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 70
Is that not only with profiled trim? Flat 1x not an issue?
Golden view is online now
Unread Yesterday, 03:02 PM   #8
LRG WoodCrafting
Leo G's Avatar
Not an issue. The curve is to line up the profile correctly. It's not much of a curve either.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Golden view (Yesterday)
Unread Yesterday, 03:31 PM   #9
MarkJames's Avatar
What's this about curved cuts to make it work? How? I'm not seeing it.
Unread Yesterday, 03:47 PM   #10
LRG WoodCrafting
Leo G's Avatar
Did you look at the two articles I posted?
Not going to matter for flat stock, something I rarely get to use. So automatically this came up in my mind because 99% of everything I touch has some sort of a profile on it.
Which is why I put it under the cool fact header.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Unread Yesterday, 04:24 PM   #11
edward trowelhands
Trade: Diplomat
Rewards Points: 70
What's your technique for cutting the curve?
Unread Yesterday, 04:28 PM   #12
MarkJames's Avatar
Well ok then.
Unread Yesterday, 05:17 PM   #13
hdavis's Avatar
Rewards Points: 1,668
Flat stock I just lay one over the other in the position I want them, then mark both edges of both pieces. Connect the marks and cut. Take your pick of how to cut, clamp guide and circ saw works.
hdavis is offline
rrk (Yesterday)
Unread Yesterday, 06:34 PM   #14
LRG WoodCrafting
Leo G's Avatar
My technique is to cut it straight and fudge it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
TheConstruct (Yesterday)
Unread Yesterday, 07:31 PM   #15
edward trowelhands
Trade: Diplomat
Rewards Points: 70
Looks good from here!
Unread Yesterday, 07:46 PM   #16
hdavis's Avatar
Mmmmm.
I like fudge....
hdavis is offline
Unread Yesterday, 08:19 PM   #17
rrk's Avatar
Rewards Points: 2,436
that is how I do it also. You may need small spacers to keep parts parallel when holding them. I mark top and bottom intersect points and connect the points
rrk is online now
Unread Yesterday, 11:45 PM   #18
Dirtywhiteboy's Avatar
Rewards Points: 11,798
I'd stack one on the other get it looking good and double cut it at the intersection points.
Dirtywhiteboy is offline
Unread Today, 05:30 PM   #19
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,222
I found Matt Kenedy's explanation of how he cuts hunting miters very interesting. He uses autocad to plot the profile lines to get the get the curve of the hunting miter, then makes plywood templates on his spindle sander to cut them. Fairly similar to the "this is carpentry: method with a pattern bit in a router, but reduces the chance of tear out. I have yet to ever cut a hunting miter, but his method seemed the most sound to me.
https://www.instagram.com/p/Bbc1rj8gopA/
Philament is offline
Unread Today, 05:41 PM   #20
LRG WoodCrafting
Leo G's Avatar
As long as you can trust your spindle sander to be square and straight. A router bit you know will be straight.
But tear out is a real problem, even with a backer board.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
