Cutting Down A Pantry Cabinet - Finish Carpentry - Contractor Talk
Old 02-12-2013, 10:59 PM   #1
232323's Avatar
Trade: remodeling contractor
Rewards Points: 154
Ill soon be installing a 90" tall single-piece pantry cabinet as part of a complete kitchen remodel. The problem is the ceiling height is 89-5/8." I didn't want to drop down 6" inches on the pantry height, so I figure I'd find a way to make this work and still look decent. I can add a 3/4" scribe moulding at the top of the cabinet without interfering with the doors. I know by cutting down the base 1/2" or so, the toe kick height won't match with the adjoining cabinet, but I don't think this will be too noticeable in a small kitchen. The other problem is tipping the cabinet in place...allowing room to stand it up with provisions to neatly cover any gaps. I'll install a separate toe kick in front, but would prefer not to use one on the side. Any suggestions would be appreciated.
232323 is offline
Old 02-12-2013, 11:13 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,542
Re: Cutting Down A Pantry Cabinet
Cut the toe kick off. It's the only way you have a chance at standing it up. Build your separate toe kick. Stand the unit up and slide it on the base. Shim it tight to the ceiling.put a plywood skin on the exposed side.
overanalyze is online now
232323 (02-13-2013)
Old 02-12-2013, 11:14 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Thats what I was going to say.
ohiohomedoctor is offline
The Following 2 Users Say Thank You to ohiohomedoctor For This Useful Post:
232323 (02-13-2013), overanalyze (02-12-2013)
Old 02-12-2013, 11:20 PM   #4
tjbnwi's Avatar
Rewards Points: 4,606
Figuring the cabinet @ 24" deep, you would have to cut the entire toe kick off. 86" rise, 24" run equals a 89 5/16 diagonal. If the cabinet is less than 24" wide ithat would decrease the diagonal.
Looks like you're cutting the toe kick off.
tjbnwi is online now
232323 (02-13-2013)
Old 02-13-2013, 11:02 AM   #5
hdavis's Avatar
Rewards Points: 1,802
Originally Posted by ohiohomedoctor View Post
thats what i was going to say.
x3!
hdavis is online now
Old 02-14-2013, 06:47 PM   #6
AustinDB's Avatar
Rewards Points: 1,572
might be able to stand it up near the center of the room....if it's just a bit off jack the floor up. Sounds like a job for a track saw and to take apart the cabinet-install it in pieces.
AustinDB is offline
Old 02-14-2013, 07:34 PM   #7
KAP's Avatar
Trade: Custom
Rewards Points: 40,148
Either on-site assembly standing up (not that hard), or separate toe-kick...
KAP is offline
Old 02-14-2013, 08:16 PM   #8
dkillianjr's Avatar
Rewards Points: 2,464
I say the same thing. All of the pantry cabinets that I've installed have had the toekick seperate from the maker.
dkillianjr is offline
Old 02-14-2013, 08:49 PM   #9
hammer7896's Avatar
Rewards Points: 30
What if you remove the front,back and unexposed side then stand it up on the remaining side and slide it on a home built toe kick.
hammer7896 is offline
Old 02-14-2013, 09:25 PM   #10
rondon's Avatar
Trade: carpenter
Rewards Points: 102
WE have don it already to install a toe kick on the open side as well as the front. That way you do not have to put a skin on the side and it does give the cabinet a nice look.
rondon is offline
Old 02-15-2013, 08:59 AM   #11
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
If you are there with just the sub floor, you can remove a section between a pair of joists and tip it up.
In an extreme case of ah chitness, do the same thing with the ceiling.
It works, believe me
Gus Dering is offline
The Following 2 Users Say Thank You to Gus Dering For This Useful Post:
hdavis (02-15-2013), thezoo (02-15-2013)
Becoming a Cabinet dealer Milhaus Marketing & Sales 2 06-15-2012 03:44 PM
Weird Cabinet Question Bergstrom Finish Carpentry 31 01-01-2012 08:40 PM
Cabinet Rails & Stiles - Supplier blackte Finish Carpentry 3 04-03-2010 06:48 PM
Another crazy cabinet.. Leo G Finish Carpentry 39 03-18-2010 06:58 PM
Cabinet for built-in oven mattsk8 Finish Carpentry 10 03-15-2010 11:14 PM
