Custom Window Intallation? - Finish Carpentry - Contractor Talk
Old 11-13-2008, 09:14 AM   #1
boydbuild's Avatar
How do you install the old rope and pulley windows from the 40s? I installed plenty of new construction and replacement windows but never these old types? any and all help would be helpful, thanks so much
boydbuild is offline
Old 11-13-2008, 10:24 AM   #2
jclem's Avatar
Trade: remodeling, and LOTS of repair work
Rewards Points: 79
Re: Custom Window Intallation?
Do you mean how do you replace the sash cords or how do you install the whole window?
Sash cord replacement is fussy but doable. I can go into details if that's the issue. The whole window is just like a new, wood-cased window except the ROW has to be bigger to allow for the weights.
jclem is offline
Old 11-13-2008, 11:35 AM   #3
Rewards Points: 2,000
Originally Posted by genecarp View Post
NEVER SAW THAT
Originally Posted by boydbuild View Post
bump. I have to bid on this job this weekend and ive installed new construction and replacement windows plenty of times but i never installed these types. Do you think it will be like new construction with flanges or ?
Back up a minute.
Where did the windows come from?
Where are they going?
Remodel?
Restoration?
New construction?
Details?
No, they will not have flanges.
That's the only question you
have given enough information
to answer.
If they need weight pockets,
they were likely intended for
balloon framed houses, and
if you are asking....you've a lot
of research to do.
Sash weights and thermal
pane glass?
Fishy.
Do not double post!
It is against the rules,
and it will confuse you
and anyone who tries
to respond.
Now it's all in one place.....
in two places.
neolitic is offline
Old 11-13-2008, 11:55 AM   #4
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 3,920
I start by removing the window stop on each side.
Next I remove the bottom window - if you look at the sides you should see a cutout with a small screw-
Then remove the cutout and look at the weight and how the knot is tied ( Make sure that when you replace the rope it does not hit the bottom of the sill inside)
Repeat for upper window. I hope that helps
Snobnd is offline
Old 11-13-2008, 10:32 PM   #5
boydbuild's Avatar
They are being done by a custom window shop to reciprocate the old style, and being installed in old apartment buildings in nyc. So I wanted to know how to install these, like replacement or new construction, how?
Old 11-14-2008, 07:41 AM   #6
Bob Kovacs's Avatar
Trade: Consultant
More than likely they're set up as "new construction" windows, but wouldn't it be easier to just check with the manufacturer???
Bob Kovacs is offline
Replacement Window Question? Max10 Windows, Siding and Doors 41 11-03-2013 12:01 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
Bidding a New Construction Custom Window Job Brendakeen Business 5 11-22-2006 09:43 PM
