Crown Moulding Installation - Page 20 - Finish Carpentry - Contractor Talk
Old 05-01-2015, 06:55 AM   #381
rrk's Avatar
Rewards Points: 5,430
Re: Crown Moulding Installation
Originally Posted by m1911 View Post
Check out the fantastic technique and coping hack saw...
https://www.youtube.com/watch?v=iGfW7zi4yUA
I feel so stoopid, I have been doing it wrong for so long?
Whats worse is that people will try to do it that way
rrk is online now
Old 05-01-2015, 07:36 AM   #382
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,740
Cutting like that unsupported is dumb. You are referencing off the back flat that hits the ceiling instead of the one that hits the wall. There are many crowns where the wall and top flats aren't square.
If you make a set of wood fences that mirror the stock ones it works and you can cut moulding that is way past the listed vertical capacity of the saw. It's upside down and backwards-reversed. The crown he's cutting is around 7". With the clearances on his POS saw it wouldn't fit nested in the normal fashion but flip it around and it works.
I've never thought to try to cope with a hacksaw.
Justin Huisenga is offline
The Following 2 Users Say Thank You to Justin Huisenga For This Useful Post:
EricBrancard (05-01-2015), m1911 (05-01-2015)
Old 05-01-2015, 08:17 AM   #383
tipitop's Avatar
Trade: carpenter
Rewards Points: 4,097
But expert show coping at crown made of foam. Still always didn't see no one video of coping of hard wood. However it would make sense hire that guy help selling my DVD (99,99$). Evidently he is capable sell advices about things that he do not know nothing about.
tipitop is offline
Old 05-01-2015, 12:37 PM   #384
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I almost understood that...but it's too early in the day to start drinking...
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following 3 Users Say Thank You to m1911 For This Useful Post:
avenge (05-02-2015), jb4211 (05-01-2015), Xtrememtnbiker (05-01-2015)
Old 05-01-2015, 01:17 PM   #385
JR Shepstone's Avatar
Rewards Points: 1,552
Says who?
Only drink 23, that way they won't have a case against you.
JR Shepstone is offline
The Following 2 Users Say Thank You to JR Shepstone For This Useful Post:
avenge (05-02-2015), m1911 (05-01-2015)
Old 05-01-2015, 05:37 PM   #386
The crown at 0:56 to the end is maple. Hardwood. If a saw blade can cut it it can be coped by any method. A self proclaimed "true expert" such as yourself should be able to recognize this.
https://www.youtube.com/watch?v=ZxXK8RYhERs
Old 05-01-2015, 06:39 PM   #387
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I've never used one of those before. I learned how to cope with a hand coping saw and then learned the back to back sanding discs on an angle grinder later on. I still do most of my coping by hand, but I think I'm going to order that coping foot and give it a shot.
EricBrancard is offline
Old 05-01-2015, 07:01 PM   #388
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I'm using the coping foot in conjunction with the Festool RAS. I especially like the coping foot for tall base that has a tall flat section that is s straight cut. You can't beat the speed of the coping foot on trim like that. In stuff with more contours I like the RAS/grinder method.
Lewis Carpentry
Spencer is offline
The Following 2 Users Say Thank You to Spencer For This Useful Post:
EricBrancard (05-01-2015), StrongTower (05-02-2015)
Old 05-01-2015, 07:08 PM   #389
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
I don't believe you'll be disappointed with it.
I first saw this demonstrated at the 2000 (I believe) JLC Live in Las Vegas. I've been using one ever since. It helps to follow the manufacturer's recommendation and use the Bosch T244D Jigsaw Blade for the best results
Jeff G is offline
The Following User Says Thank You to Jeff G For This Useful Post:
Old 05-01-2015, 07:17 PM   #390
For the $30ish that it costs it's worth having around for cutting oddball scribes if coping with it isn't your cup of tea. There's a learning curve but once you get a feel for it it's pretty fast. I use a similar cutting order to what I would do with a hand saw. Some guys split the line when cutting. I like to leave the line and file it righteous.
I cope small mouldings like shoe and picture rail by hand and I like having a grinder around for those 45/45 crowns where the profile gets paper thin to tune the cut.
EricBrancard (05-01-2015), Spencer (05-03-2015)
Old 05-01-2015, 07:28 PM   #391
m1911's Avatar
It was $20ish when I got mine...
I'd like to get a barrel grip saw though...
m1911 is offline
Old 05-01-2015, 07:37 PM   #392
Not the first time I've overpaid for something.
Old 05-01-2015, 07:46 PM   #393
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
It's $60 for the Carvex...
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Justin Huisenga (05-01-2015)
Old 05-01-2015, 07:49 PM   #394
m1911's Avatar
I meant I got mine so long ago...
m1911 is offline
Old 05-01-2015, 08:02 PM   #395
Inflation sucks.
My old truck got broken into about 7 years ago and they took my original one and its barrel grip jigsaw. I had to replace it quick so I bought at the over priced local store. I am positive I was over charged.
The Following User Says Thank You to Justin Huisenga For This Useful Post:
m1911 (05-01-2015)
Old 05-01-2015, 08:13 PM   #396
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 876
$31.05 on Amazon (just ordered it) Ha, this forum has cost me much more than that on tools previously.
dsconstructs is online now
The Following User Says Thank You to dsconstructs For This Useful Post:
Old 05-01-2015, 09:44 PM   #397
tipitop's Avatar
Trade: carpenter
Well in my add at CL I do not advertise myself like expert. There are many experts there. I just say "I do not use putty or silicone to hide quality of joints in trim that I made" and it is about it. I post "I do not carry silicone or putty with me at all. Carpenters should not do painters jobs unless they want hide something". Customers dig it big time. Countless time I come after some putty expert start job.
tipitop is offline
Old 05-01-2015, 09:58 PM   #398
Rewards Points: 986
First off, I don't know anyone who uses silicone to caulk trim work. We use Towertech urethane caulking. Not only do I carry caulking and filler with me, I carry a sprayer as well because we paint our work.
Maybe if you learned how to adjust your attitude, you wouldn't have to advertise on CL. I know I sure don't. Just think about your customer pool - they are people who hired some hack off of CL and then they find your ad when they are looking for someone to fix the work. Your entire view of your competition would be much different if you were swimming in the same pool as those of us who don't compete with the CL crowd.
The Following 4 Users Say Thank You to EricBrancard For This Useful Post:
kixnbux (05-11-2015), m1911 (05-01-2015), Spencer (05-03-2015), TNTRenovate (05-02-2015)
Old 05-01-2015, 10:05 PM   #399
m1911's Avatar
In all fairness, I think his perceived arrogant attitude might just be because of the language barrier... I'll give Tipsee the benefit of the doubt...
m1911 is offline
Old 05-02-2015, 05:36 AM   #400
jb4211's Avatar
Rewards Points: 2,306
In all fairness, this thread would be rather boring with him.
Jon
jb4211 is offline
The Following 2 Users Say Thank You to jb4211 For This Useful Post:
digiconsoo (05-02-2015), Sabagley (05-02-2015)
crown moulding for rookie sailfish27 Finish Carpentry 58 05-24-2014 10:46 AM
Clients occupying crown moulding work area...? kevbo Finish Carpentry 52 07-31-2013 08:48 PM
Crown moulding jhcontracting Finish Carpentry 21 06-02-2010 09:35 PM
