Crown Moulding Installation - Page 17 - Finish Carpentry - Contractor Talk
Old 04-19-2015, 02:42 PM   #321
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,736
Re: Crown Moulding Installation
Originally Posted by tipitop View Post
Aha customer here. Guy is try to hard to be funny bat at last can recognize true experts.
Btw. And really no joke. As long as we talk about crown here only me post some pictures. What is with rest of you. Wanna se especially stain grade coping. One more picture from true expert.
I wouldn't have coped anything in the kitchen you pictured. I would have pre-assembled with glue and nails/screws/staples from the backside and put it up in units. Reenforced like this is more durable long term than a cope and is also faster.
I don't usually bother taking pictures of crown only unless it's something out of the ordinary or part of a larger overall project. It's just crown. It is not hard and is only one very small part of the overall job description of a finish carpenter. Coping crown is not difficult in hardwood or softwood. I'm not sure if it is the language barrier or something else that is keeping you from understanding this.
For grins here's a couple pictures. The only reason I took pictures of the oak is because it's a 3 part built up that had both T&G and rabbets as part of its assembly.
Crown moulding installation-3-part-rabbeted-oak-crown.jpg   Crown moulding installation-2013-05-06_17-03-25_935.jpg   Crown moulding installation-img_20140117_115600532_hdr.jpg
Justin Huisenga is offline
The Following 9 Users Say Thank You to Justin Huisenga For This Useful Post:
AustinDB (04-20-2015), EricBrancard (04-19-2015), Johnny_5 (04-21-2015), kixnbux (04-26-2015), m1911 (04-19-2015), MF Custom (04-20-2015), skillman (04-20-2015), Spencer (04-21-2015), tipitop (04-21-2015)
Old 04-19-2015, 02:46 PM   #322
These are of an uncopable profile that gets a combination of a cope and a miter/jack miter.
Someone asked to see the process and I was bored so I took pictures.
Crown moulding installation-img_20140515_135256373_hdr.jpg   Crown moulding installation-img_20140515_135236802_hdr.jpg   Crown moulding installation-img_20140515_135319952.jpg
The Following 7 Users Say Thank You to Justin Huisenga For This Useful Post:
EricBrancard (04-19-2015), Johnny_5 (04-21-2015), m1911 (04-19-2015), overanalyze (04-19-2015), Railman (04-19-2015), skillman (04-20-2015), Xtrememtnbiker (04-19-2015)
Old 04-19-2015, 02:58 PM   #323
Here's a different coffer ceiling with both construction and finished pics. That room required the fabrication of the casework, raised panel wainscot and the ceiling with the crown being the easiest part of whole thing.
Crown moulding installation-2013-03-25_15-33-36_573.jpg   Crown moulding installation-img_20140117_115706216.jpg   Crown moulding installation-img_20140117_115653860.jpg
The Following 6 Users Say Thank You to Justin Huisenga For This Useful Post:
EricBrancard (04-19-2015), Johnny_5 (04-21-2015), m1911 (04-19-2015), MF Custom (04-20-2015), skillman (04-20-2015), Xtrememtnbiker (04-19-2015)
Old 04-19-2015, 03:15 PM   #324
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 832
Yeah..but do you have a video?
overanalyze is offline
Old 04-19-2015, 03:30 PM   #325
I didn't know that many guys are not capable cope hardwood crown. When advertise again in September will add line like - "I DO cope hardwood crown (maple, oak, mahogany, cherry) so joints will not fall apart with weather change".
There are far more difficult things a finish carpenter must do than cope crown. Fabricating and installing this is just one example.
Crown moulding installation-great-room-night.jpg   Crown moulding installation-foyer-.jpg   Crown moulding installation-1174555_189054191278069_1906952064_n.jpg
The Following 3 Users Say Thank You to Justin Huisenga For This Useful Post:
EricBrancard (04-19-2015), MF Custom (04-20-2015), skillman (04-20-2015)
Old 04-19-2015, 03:30 PM   #326
Nope.
Old 04-19-2015, 04:38 PM   #327
Joemack1's Avatar
Rewards Points: 382
Justin how did you set those beams by yourself? Looks like the fireplace was a fun scribe.
Joemack1 is offline
Old 04-19-2015, 05:31 PM   #328
On that job I worked as a sub to the millwork contractor. The beams are hollow and pre-finished. I handled the cutting, scribing and fitting of the beams and posts to each other and had the millwork contractor and his laborer help me move things when I wanted/needed help. I also did the glue up of all the beams and all of the reclaimed planking. He had a scaffolding company come in erect us a dance floor in the air. Between the three of us and my home made cabinet lift lifting and holding things in place it wasn't hard.
The scribing was interesting.
Crown moulding installation-fitting-lift-2.jpg   Crown moulding installation-beam-lift.jpg
The Following 4 Users Say Thank You to Justin Huisenga For This Useful Post:
EricBrancard (04-19-2015), m1911 (04-19-2015), overanalyze (04-19-2015), skillman (04-20-2015)
Old 04-19-2015, 05:39 PM   #329
Joemack1's Avatar
Rewards Points: 382
Justin that is quite the work platform. We have used drywall lifts before to raise beams but I wouldn't want to do it alone. You need to get the contractor to let you put a ground up before the stone masons start. It makes life a lot easier.
Joemack1 is offline
Old 04-19-2015, 05:48 PM   #330
The job was a reno and the stone was existing. They wanted it saved and left un-modified.
I had help moving the larger ones but it was just as easy doing the small ones alone with the lift.
The scaffolding guys were the heroes on that one. Their platform made the job much easier. It wouldn't have turned out the way it did without them.
Old 04-20-2015, 07:42 AM   #331
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
Nice work...
MF Custom is offline
The Following User Says Thank You to MF Custom For This Useful Post:
Justin Huisenga (04-20-2015)
Old 04-20-2015, 04:46 PM   #332
Originally Posted by MF Custom View Post
Nice work...
Thank you.
Old 04-20-2015, 05:12 PM   #333
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 1,214
Originally Posted by Justin Huisenga View Post
Thank you.
I think he was talking about tipitops cabinet crown job
EricBrancard is offline
The Following 3 Users Say Thank You to EricBrancard For This Useful Post:
avenge (04-20-2015), Justin Huisenga (04-20-2015), m1911 (04-20-2015)
Old 04-20-2015, 05:18 PM   #334
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I'd love to have Tipitop's instructional DVD on hanging crown and his fastener schedule.
There is always room to learn something new.
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
EricBrancard (04-20-2015)
Old 04-20-2015, 08:04 PM   #335
jb4211's Avatar
Rewards Points: 2,306
I went to look at a job today: replacing two windows with a French door. The HO was bragging about his new kitchen. I took a quick look. The contractor installed crown flat against the cabinets. It really looked like you'd think it would too. I asked why he did it that way. The HO just shrugged his shoulders, like, "I don't know."
The same HO had colonial trim installed high up on the wall where crown would typically go.
I honestly would think, if he wanted crown that bad, just hire someone to install it.
Jon
jb4211 is offline
Old 04-20-2015, 08:06 PM   #336
m1911's Avatar
And you didn't take some pictures to share?
m1911 is offline
Sabagley (04-21-2015)
Old 04-20-2015, 08:12 PM   #337
My mistake. I'm feeling fragile after my long day of being an actor and got confused.
The Following User Says Thank You to Justin Huisenga For This Useful Post:
Old 04-20-2015, 08:13 PM   #338
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 320
The compliment is still true.
Xtrememtnbiker is offline
The Following 2 Users Say Thank You to Xtrememtnbiker For This Useful Post:
Bedfordboy116 (04-20-2015), Justin Huisenga (04-20-2015)
Old 04-20-2015, 08:19 PM   #339
I hear help is on the way for $99.
Old 04-20-2015, 08:23 PM   #340
m1911's Avatar
That's just a teaser. Once you watch it, you'll be wanting to buy the entire set...
m1911 is offline
crown moulding for rookie sailfish27 Finish Carpentry 58 05-24-2014 10:46 AM
Clients occupying crown moulding work area...? kevbo Finish Carpentry 52 07-31-2013 08:48 PM
Crown moulding jhcontracting Finish Carpentry 21 06-02-2010 09:35 PM
