So I did this kitchen today. The backing was already installed so it was just cutting and installing the two piece crown. It was pre finished cabinet crown.
It took me 6 hours working almost entirely solo. Is that a long time compared to what it should take? I don't do cabinet crown a lot so I'm sure I'm slower at it than some guys.
Also, what's the best way to scribe the crown when it's two different profiles? I would cut a beveled miter on the piece to removed as much as I could and then just held it up and drew the profile of the wall crown on it. It took anywhere from I'd say 10 to 20 times of cutting/scribing to get it to fit.
i would have planned for 4, and budgeted for 6.
I think you did fine.
I use one of those needle profile gauges, then fine tune it from there.
That means I do basically the same as you. mark, cut, test, then repeat as necessary.
Your install looks great. I run into the crown situation you had frequently so I came up with a quick solution because I'm not fond of pendants.
My trick involves getting a template of the existing crown traced onto a peice of paper, cutting that out, then projecting ( using a flashlight) that profile onto the scribe piece. I figured this out a few years back and have done it that way ever since.
To get the template you can either use a scrap peice of crown or slip paper behind a butt to wall that exists since you are overlapping.... Maybe sometime ill write this whole thing up with photos so it makes sense.
Here I had a traditional preprime I needed to meet with a shaker cherry that was already up. I had to do this 8 times on this particular job.
Yeah, near a full day sounds about right, working alone, by the time you figure setup and clean up time. At least it was paint grade, so there's room for a bit of caulk.
Yeah. The profile on the cabinet crown was awful. I'm not very practiced yet with scribing. I can cope similar pieces together pretty well. I think I was taking at least 20 minutes per inside corner. Realizing it was going to be 6:00 or 7:00 when I was done, I caulked it when I got down to 1/32 gap.
I wish we got to do it more cause it was fun. I just felt like I was slow. So did my Dad. Lol. He called at 5:15 and said "I assume you're at home?" Nope... Still here for a couple hours.
I think we need to bid more for cabinet crown. Especially when their is room crown to deal with.
I think you did good too. My time would be the same. You have to take your time with this type of work. You don't want to be bumping your tools scratching new cabinets.
It's pre finished cabinet crown and painted room crown. Both white but different shades. Client is painting on this job.
What is the general way people handle the differing profiles? I ended up reading some last night and saw the idea of crown blocks. Most everybody says use the same crown in the room and in the cabinets. I guess if it's custom cabinets that works as you can finish the crown to match the cabinets and paint it for the room. But this is pre finished cabinet crown that's of course very pricey compared to PFJ pine crown and backer.
Did you look for a crown on the cabinets that would match the crown on the room? or quote replacing the crown throughout the room?
You could also replace the two internal crown runs on the walls with the crown on the cabinet and get rid of 4 of the difficult copes. You can argue the aesthetic case either way.
But again, you'll get faster as you develop your personal bag of tricks.
You did fine, and will get faster with practice. If it was really 10 or 20 cuts and scribes per cut, then you should be able to cut that down quite a bit, scribing very carefully with a compass rather than free-hand drawing.
What tools are you using to cope? Grinders, sanders, files, etc., can make it go much faster. Back cut really hard with a grinder or sander, then do the adjustments to the cope more easily.
Did you look for a crown on the cabinets that would match the crown on the room? or quote replacing the crown throughout the room? Even in a budget situation you should quote the option if you can.
It really was at least 10 per piece I'm sure. Usually when it's the same profile I'm one to two tries per piece.
I have the fast cap scribe which I don't think would have worked well for that profiled of a piece. Also didn't have a pencil that worked in it with me. I should get a compass.
I was using a jigsaw without a coping foot (don't own one yet) and the RAS.
The crown was $120 per 8' piece. That's a massive cost difference to PFJ pine crown from HD. This was a job we were reusing trim in cause of budget concerns.
I don't know if we are able to get the crown in the same profile as the 3 1/2" crown that was in the room. I would guess not though.
The only wall run inside the cabinets was above the sink. We didn't run crown above the range because we tiled to the ceiling. I called a buddy who is a designer at a high end kitchen company here. He said they try to never run the cabinet crown on the wall. And I agree, I didn't like that idea for aesthetics. He said either wall crown, or a valence between cabinets with the cabinet crown going across. Often times with a cabinet finish soffit with 4" cans over the sink.
So I had 4 on this job, 2 at the sink, and the 2 at the ends of the cabinets. I imagine I spent at least 30 mins per piece with those 4 pieces.
I've done very little pre finished crown work and even less joining to other profiles. I know I'll get better. I was just a bit frustrated at the end of the day cause I felt like it took too long and the results weren't as good as I would have liked.
Travis I have had the coping foot for quite some time. I personally never found it to be as great as hyped. How did the RAS work out? That thing looks like a beast to do finess work. I wonder if slower smaller machine would be more controllable.
The RAS is awesome. I used it on speed 5 out of 6 yesterday. You grind away a lot of material and then slow down and fine tune.
Did you use the jig with the coping foot? I read an article that I think was by Gary Katz talking about not being impressed with it at first. He said he called David and told him and David asked if he was using the jig like he said. Gary said he wasn't. Then he started using it and like the foot much better.
I have started using the coping foot and a grinder on occasion. I am nowhere good enough to do the higher cost trim with either one yet though, so I still use the good old fashioned coping saw, files and sandpaper route when I am doing any of the expensive stuff.
Travis, I never ran into that situation, but (just a thought) would installing a 90° block in the corner provide a more finished, neater look - just for that particular situation where two different crown moldings meet?
Something similar to one pictured.
To me, I think that way he did it would attract more of my attention. I'm not saying what he did was wrong in any way.
I just mean, if I was there for dinner, I'd probably look at that corner most of the night thinking about different ways of handling that situation. I'm weird like that.lol
This is why when I'm invited to friends houses for dinner, I keep my head down and try not to look at the millwork, etc... else my OCD will ruin the evening for sure... :laughing:
I like my little 12v jigsaw for coping. Lightweight and comfortable to hold upside down. I dont think I would like using the Trion or Carvex upside down.
My understanding is the coping foot snaps off the Carvex real easy with no tools. Unlike any of the other jigsaws. That's a big plus to me as I only would have one jigsaw.
Travis,
Adjustable coping box. The bench hook on the bottom slips over my saw wings. The toggles then clamp it down. Crown gets cut in the box. Base,chair, etc get clamped and cut flat. The quick and dirty ones others mentioned are also very effective.
I use an older Bosch jigsaw dedicated to the coping foot and a 244 blade. When not in use it lives in a Systainer with my other jigsaw a selection of blades and the files I use most frequently to tune copes.
Looks nice. You and Darcy have both mentioned using files for tuning the copes. The only file I have is for metal. Where should I find a file for wood? I'm googling rat tail file (the kind Darcy mentioned) and getting almost nothing. I guess I was thinking it would show up with results from good sites to buy from or with hits from forums or something.
If you're only doing larger than 4" radius. :laughing:
Related Threads
3.5M posts
151.3K members
Since 2003
