Crown Moulding - Finish Carpentry - Contractor Talk
Crown Moulding
Old 05-29-2010, 09:47 PM   #1
Home remodeling
jhcontracting's Avatar
Trade: home remodeling
Rewards Points: 157
Crown Moulding
Would like to know several things. What is the best way for me to attach crown moulding on kitchen cabinets so the nails are the least visible. I have heard that pin nailers are good. what size are they and are they the preferred way to nail.
Also I inquired about miter saw blades. The answer I got was John Forrest blades. I looked them up on the internet, and they run about $145. Are they that much better for cutting kitchen cabinet crown
thanks for any help I can get
jhcontracting is offline
Old 05-29-2010, 10:46 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,623
Re: Crown Moulding
If you are attaching crown to a cabinet then you should be using a 23 ga pinner. Get a Grex that shoots at least 1 1/2".
Forrest blades are damn good, Tenryu is another damn good blade. If you are price savvy then stick with a Freud Diablo, it is a good blade. Try to stay away from thin kerf blades, they tend to deflect, especially 12".
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
superseal (05-31-2010)
Old 05-30-2010, 01:31 PM   #3
YesMaam27577's Avatar
Trade: Small-jobs contractor
Re: Crown Moulding
What Leo said.
A Grex 23 ga pinner is the nuts. Forest and Tenryu blades are great. Freud is also quite good.
If its a small job and you expect few or no others, get the Freud. (But still get the Grex pinner. You'll wonder how you got on without it.)
YesMaam27577 is offline
Old 05-30-2010, 01:44 PM   #4
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Re: Crown Moulding
I thought all the red diablos were thin kerf. i have never had great success with those blades, too thin. forrest blades are awesome but i don't use them for most trim. not everyday am I doing hardwood crown for a kitchen. the black makita blades are smooth and reasonable for most cuttings. for hardwood bump up and use the better blade like leo stated.
along with the 23 gauge grex or cadex pinners, if you can, fasten a nailer piece on top of the cabinets with small trim screws. this will give you more meat to nail into and make the block out of non-hardwood material so your pins go in easier.
if you have never done crown at the top of cabinets before, just realize it's going to take you a while longer if there are lots of inside and outside corners. it's not something that can be slapped up if you want it to look good.
good luck.
ApgarNJ is offline
Old 05-30-2010, 01:49 PM   #5
LRG WoodCrafting
Leo G's Avatar
Re: Crown Moulding
The red Diablo's are think kerf. But it is still a good blade. A 8 1/2 or 10" blade should only deflect a small bit if you are cutting quickly into a hardwood. A 12" will deflect to much in my opinion. The OP sounded like the price was to much, and just about any full kerf blade runs in the higher range.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 05-30-2010, 06:15 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
Re: Crown Moulding
Run a bead of hot glue behind the cabinet crown after you pin it on.
For blades, WWII, Tenryu, or Matsush!ta.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-30-2010, 07:26 PM   #7
frankster's Avatar
Rewards Points: 75
Re: Crown Moulding
All the blades listed above are great blades. NO THIN KERF especially on the 12" saw and do not use a 60 or more tooth blade for the hardwood either. A good quality 40 tooth blade will work great.
frankster is offline
Old 05-30-2010, 08:26 PM   #8
I like Green things
Re: Crown Moulding
40 tooth????
Warner Mill Works
Facebook
YouTube
Old 05-30-2010, 08:29 PM   #9
LRG WoodCrafting
Leo G's Avatar
Re: Crown Moulding
I'd like to see what a 40 tooth 12" blade would do.
Just think, you could take it off the chop saw and use it as a rip blade.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 05-30-2010, 09:49 PM   #10
Dan
ApgarNJ's Avatar
Re: Crown Moulding
only 40 tooth 12inch blades i have seen are framing, I'm with leo though. would be good for ripping hardwood on a table saw. i'd have alway used 100 tooth or more for any type of finish carpentry.
ApgarNJ is offline
Old 05-30-2010, 11:09 PM   #11
I like Green things
Re: Crown Moulding
100 is a lot.
I run 2 different 60's and one 80 which is an alternate tooth, alternate face grind with a raker.
That 80T is only used once in a while. These blades are 260mm, about 10".
All I used on a 12" was 80t.
Warner Mill Works
Facebook
YouTube
Old 05-30-2010, 11:56 PM   #12
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: Crown Moulding
I just did a kitchen of pre-finished Maple Crown with a 12" 80 Tooth Diablo...
TBFGhost is offline
Old 05-31-2010, 09:26 AM   #13
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
Re: Crown Moulding
I have several 80t Diablo 12", and I have 2 92t Diablo 12" they cut great.
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Old 05-31-2010, 12:40 PM   #14
Dan
ApgarNJ's Avatar
Re: Crown Moulding
i find the diablos deflect way too much for 12". i haven't purchased one of them in years. was never happy with their longevity or cutting power.
ApgarNJ is offline
Old 05-31-2010, 01:38 PM   #15
UpNorth's Avatar
Trade: Engineer & Ret. GC
Re: Crown Moulding
And then there is top-mount crown molding, for which the fastener type doesn't matter, as they cannot be seen.
UpNorth is offline
Old 05-31-2010, 09:23 PM   #16
frankster's Avatar
Rewards Points: 75
Re: Crown Moulding
I run the 10" blades. I use a 40T on the table saw and a 50T on the chop saw. I use the 40-50T for hardwood only. If Im doing trim work Ill use a 60T on the table saw and a 80T on the chop saw. Only for softer woods. I found that useing the 60-80T blades on hardwoods just burns up my blades and burns the hardwood.
Old 06-01-2010, 08:46 PM   #17
Dpscott's Avatar
Trade: Builder
Rewards Points: 25
Re: Crown Moulding
The last kitchen crown I did had a space for a rope moulding to be added in the middle. That made it real easy to attach it to some blocks I fastened to the top of the cabinets out of left over 2x scraps with trim screws.
Dpscott is offline
Old 06-02-2010, 05:33 PM   #18
michaeldh's Avatar
Trade: Finish carpenter
Re: Crown Moulding
They are great blades.
Finish Carpenter Sarasota
michaeldh is offline
Old 06-02-2010, 05:54 PM   #19
rselectric1's Avatar
Rewards Points: 886
Re: Crown Moulding
You did a GREAT job on that corner. When doing rope molding crown, even when it's just an insert, I am usually tempted to stick my neck under the miter saw a few times. They are tough to make consistent.
rselectric1 is offline
Old 06-02-2010, 06:03 PM   #20
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Crown Moulding
Some are worse than others, but the twisted, or spiral ropes are enough to make you curse. Especially on kitchen layouts with angled corner cabinets and alternating cabinet heights. They really need to send out opposing twists so you can match the corners.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
rselectric1 (06-02-2010)
crown moulding pricing installation popeye oil General Discussion 2 03-17-2010 11:25 AM
Painters and crown moulding... The Invetor Painting & Finish Work 7 01-02-2010 09:41 AM
crown moulding mnjconstruction Finish Carpentry 42 03-25-2009 04:05 PM
Crown moulding question davinci Carpentry 14 02-21-2009 10:54 PM
pricing crown moulding boydbuild Finish Carpentry 15 12-19-2008 10:12 PM
