Crown Molding On Concrete Ceiling - Finish Carpentry - Contractor Talk
Old 09-11-2012, 04:15 PM   #1
CadetC's Avatar
Trade: Residential construction
Hi
I got project in Chicago's downtown condo.
Owners want to install 3 piece crown thru whole apartment - around 630 lnf of crown.
My problem is, all ceilings are solid concrete and all wall are drywall over metal studs.
I been planing to use trim screws to attach to wall( screw into metal studs) and drill 1/4" holes in ceiling, wood plug them and drive trim screws to attach ceiling piece -of course use adhesive too
Maybe there is better way to do it?
All comments welcome
Thanks,
Chris
CadetC is offline
Old 09-11-2012, 04:18 PM   #2
General Contractor
Doctor Handyman's Avatar
Rewards Points: 408
Re: Crown Molding On Concrete Ceiling
Install a backer first then nail as usual.
Doctor Handyman is offline
The Following 4 Users Say Thank You to Doctor Handyman For This Useful Post:
BoGoCo (09-15-2012), hdavis (09-11-2012), Sir Mixalot (09-13-2012), WarriorWithWood (09-11-2012)
Old 09-11-2012, 04:37 PM   #3
CadetC's Avatar
How backer will help me to install 3 piece crown- by 3 piece i mean : base installed on wall, base installed on ceiling and then crown molding installed over
Somethink like this , but bigger size and different profile:
Chris
CadetC is offline
Old 09-11-2012, 05:39 PM   #4
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
I would think of just installing a chamfer strip. I'm sure thats what Doc meant.
Possibly just screwing into the top plate/studs of the wall. Construction adhesive or silicone e.t.c. against the concrete.
I would refrain from drilling into the concrete.
mgb is offline
The Following 2 Users Say Thank You to mgb For This Useful Post:
Doctor Handyman (09-12-2012), Sir Mixalot (09-13-2012)
Old 09-11-2012, 05:41 PM   #5
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Tapcon the base to ceiling, hiding screws where crown will cover, do the same with trim screws on wall piece. Nail crown up with short brads into your built up pieces. If ceiling is relatively flat not many screws would be needed if you used some PL to bridge between them.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
chris klee (09-11-2012)
Old 09-11-2012, 06:25 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6
On a somewhat related note, I recently posted about trying to match up to some plaster crown. We had to demo a wall and needed to try to match the existing crown. We decided to go with a 3 piece and completely envelope the existing crown. Homeowner is thrilled.
Crown molding on concrete ceiling-plaster-crown.jpg   Crown molding on concrete ceiling-plaster-crown-coverage.jpg
Warren is online now
Old 09-11-2012, 06:27 PM   #7
CadetC's Avatar
After second thought I think I need to talk with building engineer -perhaps ceiling is PT slab? -so no drilling or tap-cons in ceiling allowed
Chris
CadetC is offline
The Following User Says Thank You to CadetC For This Useful Post:
overanalyze (09-11-2012)
Old 09-11-2012, 06:42 PM   #8
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
Cut blocks and pl to wall and ceiling. Shoot a 15g nail into wall to hold till glue dries.
Eric K is offline
The Following User Says Thank You to Eric K For This Useful Post:
Eaglei (10-16-2014)
Old 09-11-2012, 06:42 PM   #9
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,030
Chris
Was just about to ask that...still could do the base and backer on the wall...
overanalyze is online now
Old 09-11-2012, 07:24 PM   #10
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
One possibility;
Cut a backer so that the edge away from the wall will meet the back edge of your base at the ceiling. Then pocket screw the base to the backer with adhesive at the ceiling.
If you back bevel one or the other slightly, it may lend some upward pressure to the ceiling when you tighten the pocket screws.
Just an idea
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
hammerone40 (09-16-2012)
Old 09-11-2012, 09:59 PM   #11
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
Gus is on the right track . If you add a rip to bottom of each piece of baseboard you could screw them together as a large "L" , screw it to the wall , glue it to the ceiling, install the crown , collect your check and head off to the next job.
Trim40 is offline
The Following User Says Thank You to Trim40 For This Useful Post:
parkers5150 (09-13-2012)
Old 09-13-2012, 10:55 AM   #12
Munanbak's Avatar
Trade: Renovation, Remodeling
Rewards Points: 135
Haven't done this, so just a theory. If possible, for the field, nail the two baseboards to the backer first. Install (3 piece) backer, Install (4th piece) crown. You'd have to play with the corners. Nevermind just read the above two posts.
Munanbak is offline
Old 09-13-2012, 09:08 PM   #13
JesseCocozza's Avatar
Rewards Points: 810
Chris
Had to do this before on a pt ceiling. We weren't allowed to drill or tapcon but we were able to use powder actuated fasteners. Got a
Bunch of washered fasteners and shot the ceiling peice to the concrete, then the wal pieces were glue and nailed, the installed crown.
JesseCocozza is offline
Old 09-15-2012, 09:14 PM   #14
Lion Hunter's Avatar
Trade: General contractor/ carpentry
Rewards Points: 75
when the ceiling is concrete its normally a lot harder then your normal home foundation. some of these old condos are built like bomb shelters. probably would burn a lot of bits and break off a lot of tap con heads.
Lion Hunter is offline
Crown Molding attachment on Cabinet Knighton Finish Carpentry 18 07-19-2012 10:41 PM
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 12:45 PM
plaster crown molding install prices... CREATE NYC Finish Carpentry 21 01-27-2010 05:28 PM
crown to sloped ceiling fourcornerhome Finish Carpentry 5 12-26-2009 12:36 PM
crown molding HWCostruction General Discussion 8 12-13-2008 04:30 PM
