Crown Molding Attachment On Cabinet - Finish Carpentry - Contractor Talk
Old 07-03-2012, 10:37 AM   #1
Wasting Time
Knighton's Avatar
Rewards Points: 75
I'm about to attach some crown and light rail on some cabinets that don't have flush ends. The face frame sticks out about a 16th, maybe a bit more. I would like to make it flush just at point of attachment. I don't want to leave it alone as it would be too noticable. I considered using a mortising bit on a trim router and making some sort of jig to keep it level. Anyone have any thoughts?
Knighton is offline
Old 07-03-2012, 12:39 PM   #2
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 876
Re: Crown Molding Attachment On Cabinet
I wouldn't cut into the face frame. I'd either add matching scribe molding horizontal on those edges that would give you a flush surface and barely seen behind your added moldings. Or matching skin on the whole side that would give it a more solid/filled in appearance overall.
dsconstructs is offline
The Following 4 Users Say Thank You to dsconstructs For This Useful Post:
hdavis (07-03-2012), mikeswoods (07-03-2012), thecabinetguy (07-06-2012), William James (07-14-2012)
Old 07-03-2012, 12:44 PM   #3
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 52
scribe the crown.
goneelkn is offline
The Following User Says Thank You to goneelkn For This Useful Post:
hdavis (07-03-2012)
Old 07-03-2012, 01:06 PM   #4
bconley's Avatar
Trade: Kitchen and bath design+remodel
I chisel just out the side
bconley is offline
The Following 2 Users Say Thank You to bconley For This Useful Post:
J F (07-06-2012), pinwheel (07-05-2012)
Old 07-03-2012, 01:12 PM   #5
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
I chisel the rail
nailkiller1 is offline
The Following User Says Thank You to nailkiller1 For This Useful Post:
Old 07-03-2012, 01:55 PM   #6
Robs660's Avatar
Trade: Commercial modular
Rewards Points: 81
I rip fillers and leave the face frame
Robs660 is offline
Old 07-03-2012, 02:05 PM   #7
manipulator of wood
I Mester's Avatar
Trade: general contractor
I usualy either rip down a piece of stock and make a filler. or notch the rail to make it flush. skinning the side would be the best way to do it and give you a most finished look.
I just love the smell of sawdust in the morning!
I Mester is offline
Old 07-03-2012, 03:35 PM   #8
Wasting Time
Knighton's Avatar
Rewards Points: 75
Thanks for the suggestions! I'm gonna think about it a bit more. Don't have to complete it until after the 4th. Waiting for the backsplash to get installed before I install the light rail. I will take a photo of what I ended up doing.
Knighton is offline
Old 07-03-2012, 07:33 PM   #9
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
all of the above what ever works for you, next time order the cabs with furniture ends.
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
BoGoCo (07-06-2012)
Old 07-05-2012, 08:39 PM   #10
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
Common feature on most stock cabs, best option is to skin the whole side. If not in the budget I use a adjustable square and cut it with a new sharp utility knife, then remove the material with a nice sharp chisel... your done.
MF Custom is offline
The Following 2 Users Say Thank You to MF Custom For This Useful Post:
chris klee (07-19-2012), rrk (07-19-2012)
Old 07-05-2012, 09:20 PM   #11
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
I usually add a scribe piece on the side of the cabinet only where the crown is, to make it run straight. Otherwise notch out and attach the crown, gives a goofy look on the corner though IMO
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
The Following User Says Thank You to WilsonRMDL For This Useful Post:
Old 07-05-2012, 10:28 PM   #12
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,562
Forget the scribe and flush side. Add a 1x to the tops of the cabinets that is stained to match the crown. Hold the 1x out so your crown can be nailed to it. It will create a nice extra reveal line and solve the issue. It should look like this.
overanalyze is offline
Old Grumpy (07-14-2012)
Old 07-06-2012, 01:51 PM   #13
cabinet runner's Avatar
Trade: cabinet installer
Rewards Points: 150
I've done it all the ways mentioned . The best IMO is adding a skin but using scribe or a ripped filler looks good as well . I prefer not to notch the cabinet rail but if i don't have the material i will do it and it looks fine .
In this situation i think you will be the only one that notices how you do it . All the ways mentioned look decent . I know some installers who insist on notching the cabinet . I prefer not to . A good supplier sends the skins to address this issue or make sure the cabinets at the end of the runs have the sides flush with the rail but many don't figure on this problem.
It's not a big deal . i'm sure however you do it will be fine
cabinet runner is offline
Old 07-14-2012, 01:18 PM   #14
Wasting Time
Knighton's Avatar
Rewards Points: 75
Thanks for all the suggestions. I ended up notching the ff with a multitool and it looks good. The skins just wouldnt have worked for various reasons.
Adding the plywood top wouldnt work because of the reveal. The cabinets were designed with an 1/8 reveal all around.
Again, thanks for the suggestions.
Knighton is offline
Old 07-14-2012, 02:31 PM   #15
KAP's Avatar
Trade: Custom
Rewards Points: 40,224
For future reference, while notching works, the way to do it is to bring the side flush through either a strip or a skin... although a skin is ideal as it brings it as close to furniture grade as you can get with stock. One of the pitfalls of stock cabs..
By notching, you are making the bottom of the crown sit on the notched part of the FF instead of on the face of the cab like the rest of it...
Your customer probably won't care either way...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Old 07-16-2012, 09:07 AM   #16
Wasting Time
Knighton's Avatar
Rewards Points: 75
Where can i find some 1/16" skins?
Knighton is offline
Old 07-19-2012, 08:13 AM   #17
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
i have notched the face frame, and i have used scribe to make up the difference also. i think the scribe looks better, but neither look correct.
its usually a little under 1/4" on most stock boxes.
CK Carpentry
chris klee is offline
Old 07-19-2012, 06:53 PM   #18
leakygoose's Avatar
Trade: Finish Carpentry
Rewards Points: 150
If it's your own cabinets then go the extra but if it's for a cheap azz builder / HO that doesn't have some scrib or skins or something on site for you to use then just notch the rail and be done with it, move on.
Don't let little things like this waste your time.
leakygoose is offline
Old 07-19-2012, 10:41 PM   #19
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Where's the pic?
Brian Peters is offline
Crown molding kevinv52000 Finish Carpentry 41 05-02-2012 07:26 PM
Cut-N-Crown is new here, but have been around crown molding for some time cutncrown New Member Introductions 15 03-09-2012 12:32 AM
Crown moulding in Kitchen w/ cabinet crown JTW Finish Carpentry 42 07-06-2010 08:26 PM
Need help on Crown Molding on Trey Ceiling pcumming Finish Carpentry 52 01-31-2010 08:42 PM
plaster crown molding install prices... CREATE NYC Painting & Finish Work 2 01-19-2009 06:43 AM
