Crown Around An Odd Outside Corner - Finish Carpentry - Contractor Talk
Old 09-05-2017, 11:50 AM   #1
Expensive Hobby's Avatar
Trade: Finish Carpentry
Rewards Points: 4
I've ran into a corner I've never dealt with before on hanging crown. The room is a large rectangle with an 18 degree vaulted ceiling and then there is a small nook where the ceiling is not vaulted.
The crown has been hung all the way around the rest of the room and looks good - but all I have been able to come up with for this corner is to do returns on both ends, and I don't like how that looks. It's an outside 90 degree corner where one wall has a flat ceiling, and the other wall has an 18 degree vaulted ceiling.
Is there any way to make that corner? The way the crown sits on the two walls, it is about 3/4 of an inch different in height. I don't want to bring the crown down on the left side to match the right and put a filler piece between the crown and the ceiling because that will mess up things on the next corner, where I have a pie piece and then a 16' long piece that goes to the peak of the vault.
Any help would be appreciated. Thanks.
Expensive Hobby is offline
Old 09-05-2017, 11:51 AM   #2
Rewards Points: 4
Re: Crown Around An Odd Outside Corner
Here is a picture of it.
The Following User Says Thank You to Expensive Hobby For This Useful Post:
Uptime_const (10-06-2017)
Old 09-05-2017, 02:53 PM   #3
General Contractor
greg24k's Avatar
Rewards Points: 8,660
Horizontal to Rake with No Corner Transition Piece
Crown Moulding Spring Angle
38.00000
Wall Corner Angle
90.00000
Roof Slope Angle
18.00000
Crown Moulding Laying Flat with Top Edge of Moulding Against Fence
Face A
Crown Moulding Miter Angle
39.66001
Crown Moulding Bevel Angle
23.29149
Face B
39.66001
23.29149
Crown Slope Reference Plane Angle
34.00000
greg24k is offline
The Following 3 Users Say Thank You to greg24k For This Useful Post:
A&E Exteriors (09-28-2017), FrankSmith (12-02-2017), Metro M & L (09-09-2017)
Old 09-07-2017, 08:13 PM   #4
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,356
hope you get a picture of this when it is done . struggling to follow what Greg posted
JFM constr is offline
Old 09-07-2017, 11:56 PM   #5
General Contractor
greg24k's Avatar
Maybe this will help.
greg24k is offline
Old 09-08-2017, 08:45 PM   #6
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
where's Tipi when you really need him
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following 3 Users Say Thank You to parkers5150 For This Useful Post:
Calidecks (09-09-2017), SmallTownGuy (09-29-2017), Tom Struble (09-09-2017)
Old 09-08-2017, 09:16 PM   #7
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Rewards Points: 1,028
Looks like :poop:
Resta is offline
Old 09-08-2017, 10:31 PM   #8
AustinDB's Avatar
Rewards Points: 1,536
the piece of crown on the left of the corner is at a higher plane than the one on the right. will there be three pieces necessary to complete that corner?
AustinDB is offline
Old 09-09-2017, 12:58 AM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,008
Some things just can't be made to work and still look good. I think this is one of them.
Mike.
_______________
Calidecks is online now
Old 09-09-2017, 09:58 AM   #10
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
If nothing else, a plinth block would look better than what is there now.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
Railman (09-09-2017)
Old 09-09-2017, 11:22 AM   #11
Railman's Avatar
Trade: Railing
Rewards Points: 1,159
That has been my conclusion all along. A nicely done 1 pc block would probably look cleaner than 3 or 4 bstd pieces that are at different slopes/planes.
Railman is offline
Old 09-09-2017, 11:37 AM   #12
JFM constr's Avatar
my first thought was also a block . though i have issue with a single block .would it look off to do all the corners in blocks .or would just the two odd angles be enough to balance things . visually one block seems like a mistake or hiding a mistake .how to make it seem like it is meant to be .
Old 09-09-2017, 11:45 AM   #13
MarkJames's Avatar
Rewards Points: 18,981
I'd be inclined to leave the connecting wall out of it altogether. Maybe return the side room further back from the outside corner. (Oh, and paint the crown so it draws less attention.)
MarkJames is offline
Old 09-09-2017, 11:55 AM   #14
JFM constr's Avatar
this might make the most sense .
Old 09-28-2017, 08:23 PM   #15
tipitop's Avatar
Trade: carpenter
Rewards Points: 4,075
Savior here. You can not joint them properly. It is rake eave problem and it is googable. What he can do twist one or both crown more till he get good enough joint. It is not much of cathedral ceiling so he should be capable do it. Right solution is two different size crowns and is not applicable here.
tipitop is offline
Old 09-28-2017, 09:59 PM   #16
Texas Wax's Avatar
Rewards Points: 2,140
Personally, corner blocks are generally a copout ... but sometimes it's all you got
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 5 Users Say Thank You to Texas Wax For This Useful Post:
A&E Exteriors (09-28-2017), Calidecks (09-28-2017), FrankSmith (12-02-2017), Resta (09-30-2017), SmallTownGuy (09-29-2017)
Old 09-29-2017, 11:51 PM   #17
General Contractor
greg24k's Avatar
It is easier to cut your angles vs. making corner blocks. If you make corner blocks you have to make them for every corner, because one block at one corner will look out of place and it will stick out.
If you try dead-dead end both sides and fiddle with paint trying to hide it, that will look like an amateur job.
greg24k is offline
Stilla (09-30-2017)
Old 09-30-2017, 10:26 AM   #18
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 598
The flat ceiling is your benchmark. The crown should have been lower. There is no fix. Adding a plinth block isn't helping. Leave it alone, or lower the upper crown.
Stilla is offline
The Following User Says Thank You to Stilla For This Useful Post:
greg24k (09-30-2017)
Old 09-30-2017, 10:27 AM   #19
tipitop's Avatar
Trade: carpenter
You have special situation there where is crown 45 and cathedral ceiling is 45.
tipitop is offline
Old 09-30-2017, 10:50 AM   #20
Stilla's Avatar
Rewards Points: 598
He doesn't have a special situation, a rake molding, is larger. He faked it by changing the spring angle of the horizontal crown, and then rolled it.
Stilla is offline
The Following 2 Users Say Thank You to Stilla For This Useful Post:
greg24k (12-04-2017), SmallTownGuy (09-30-2017)
Crown moulding installation Xtrememtnbiker Finish Carpentry 437 05-18-2015 01:09 AM
Going to cut crown flat tomorrow, for the first time. SuperiorHIP Finish Carpentry 20 10-12-2011 06:32 PM
crown in a moving house? Mrmac204 Finish Carpentry 10 04-24-2011 10:52 PM
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Crown moulding in Kitchen w/ cabinet crown JTW Finish Carpentry 42 07-06-2010 08:26 PM
