Counter Top Cover - Finish Carpentry - Contractor Talk
Counter Top Cover
Old 12-30-2018, 05:32 PM   #1
Artworks's Avatar
Trade: Renovations & Construction
Rewards Points: 354
Counter Top Cover
Ok, here is the problem: I need to repair piece of laminate counter. It has a bull nose front , It is at a booth with a window. Belt buckles have broke away some of the laminate and wore the particale board substrate
The booth is used 24/7 so my repair has to be fast. My idea is to get a piece of stainless bent to cover up the damaged are and last much longer than a plastic laminate surface. Has anyone done such a repair ? Or has any Idea's.
The piece only has to be 7" deep ( from tip of the bull nose to the window ) wrap the bull nose 1 3/8" and under approx 1 1/2 " , I have make it a min. of 24" Long, but thinking I go width of window, 40 1/2 "Long.
I just screw edges and under to counter and a nice bead of caulk at window .
Thanks
IF IT WAS EASY, EVERYONE COULD DO IT !
Artworks is offline
Old 12-30-2018, 07:00 PM   #2
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 292
Re: Counter Top Cover
Sounds like a good plan. It'll be pretty expensive. I'd go full length, it'll look better. But, you'll probably have to sell the benefits.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
The Following User Says Thank You to t.carpenter00 For This Useful Post:
Artworks (12-31-2018)
Old 12-31-2018, 12:09 AM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 33,894
Thanks
Re-laminate and route the edge off and install new edging that can be also be replaced as needed in the future... hour or two job... tops...
Take your pic...
https://www.kuehnbevel.com
http://www.loticorp.com/loticorp.shtml
https://www.wilsonart.com/laminate-edge-options
http://www.formica.com/en/us/products/idealedge-real
You can get matching laminate colors, or complimentary colors, solid-surface, wood edge, etc...
KAP is offline
Old 12-31-2018, 11:42 AM   #4
Artworks's Avatar
Rewards Points: 354
I thought of that, but I don't think I can re laminate the bull nose, and have to rip the entire bull nose edge off and build it back out. Also the substrate is also worn. It be just as easy to replace the whole top. which I would do if they don't like my stainless cover plan. I would be looking at approx 15 sq. ft. of bull nose counter . with a 45 degree at joint. and in 2 -3 years replacing again.
Another plan would be cut out the damaged area and replace with an Oak bull nose piece. Multi cutter & router and biscuits and / or pocket screws.
Artworks is offline
Old 12-31-2018, 12:59 PM   #5
KAP's Avatar
Trade: Custom
Sounds like it's a post-formed top... Is the goal here to save them money at your expense or you to make money?
I'd simply replace the top, in and out, but it sounded like you wanted a work-around with existing top which is what I suggested...
KAP is offline
Old 12-31-2018, 07:19 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,113
I doubt you're bending any laminate around that bullnose. They heat that up to 300 or so degrees and then bend it while it's flexible. the SS is probably a good idea.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
rrk (12-31-2018)
Old 12-31-2018, 07:38 PM   #7
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 3,914
If you make a whole new piece you should be able to take it out and put the new one in quickly, come back in two years and make some more money!
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is online now
Old 12-31-2018, 08:18 PM   #8
rrk's Avatar
Rewards Points: 1,636
and what are the chances of bending the SS to match that profile especially if it has a no drip edge
just replace it
rrk is offline
Old 12-31-2018, 08:24 PM   #9
LRG WoodCrafting
Leo G's Avatar
Much better than the laminate. The SS isn't going to snap in the middle of the bend.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Tonneau Cover Cole82 Vehicles 7 12-31-2012 04:50 PM
open minded customer likes counter top idea but not sure if it will work Randal Kitchens & Baths 3 11-28-2011 03:31 PM
In-wall box with cover, for transformer UpNorth Low Voltage 0 07-19-2011 07:27 PM
How do you cover travel time for employees? RadRemod Business 31 03-18-2011 11:47 AM
