Chipping Out With Router - Finish Carpentry - Contractor Talk
Old 01-11-2019, 02:00 PM   #1
rblakes1's Avatar
Rewards Points: 2,350
I was running maple through the router for some doors I'm making and had a lot of chip out. I'm hoping you guys can throw some pointers my way so it doesn't happen again.
Speed was probably around 3 on my Bosch evs1619, I don't think I was pushing them through too fast (but maybe I was?) I was doing this in my garage early in the week, so temps in the mid to low 30s. The bits are whiteside, and have maybe 20 doors total run through them (mostly poplar, some oak). I had this issue with the poplar, but I assumed at the time the issue was the poplar
All I need to slow down my feed speed more? Slow down the router?
rblakes1 is offline
Old 01-11-2019, 02:41 PM   #2
Ed Hartmann's Avatar
Rewards Points: 58
Re: Chipping Out With Router
Go slower, get a better bit, or do it in a few passes. Some combination of that will be the answer or use the table saw.
Ed Hartmann is online now
The Following 3 Users Say Thank You to Ed Hartmann For This Useful Post:
Fixed (01-11-2019), rblakes1 (01-11-2019), ScipioAfricanus (01-11-2019)
Old 01-11-2019, 03:33 PM   #3
rblakes1's Avatar
Originally Posted by Ed Hartmann View Post
Go slower, get a better bit, or do it in a few paces. Some combination of that will be the answer or use the table saw.
I don't know why I didn't think of gradually increasing the depth, I'll give that a shot
rblakes1 is offline
Old 01-14-2019, 12:06 AM   #4
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,656
did gradually getting to full depth help .
guess if i was having this issue with cut/bit then i would run the board backwords to remove some of the cut . back cut a little bit .
are you using any feather boards ? if not you might try that.
JFM constr is offline
Old 01-14-2019, 01:07 AM   #5
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,006
Could be grain direction also.
Going against the grain can cause tear-out. Flip that same piece pictured end for end and try it.
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is offline
brhokel606 (01-14-2019)
Old 01-14-2019, 03:46 AM   #6
hdavis's Avatar
Rewards Points: 1,812
Slow down the feed.
The angles on the bit may be aggressive.
hdavis is offline
Deckhead (01-14-2019)
Old 01-14-2019, 06:55 AM   #7
rrk's Avatar
Rewards Points: 388
Much easier to do that on a table saw
rrk is offline
Old 01-14-2019, 07:15 AM   #8
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 9,068
Speed up the router and slow down the feed.
Whitesides are a good bit.
Could even be if you're not perfectly flat on your base the bit is angling a little, make sure your board isn't tilting. Rrk is right though... Deep straight cuts on a router are a pain in the balls.
He knows nothing about everything and isn't afraid to prove it, so he defends ignorance with stupidity.
Deckhead is online now
Old 01-14-2019, 08:43 AM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,524
Wrong, wrong, wrong, wrong.
This is what happens when you are trying to make this particular cut. Taking a deep straight cut will almost always produce some sort of chipout in a hardwood. With a shaper cutter to prevent this you do a destructive cut which will take a 1/16" or so off the width of the board along with putting the slot in. This cleans up the chipout, but it has occurred, and you're just milling it off in the same pass.
There are two ways to do this. Take a very shallow cut, lets say 1/32" (or less) into the wood with the slotter cutter. This will likely produce a clean cut. On some grains, especially against the grain you may still get some minor chipout. But nothing like you have in that picture.
Problem with this method is it will be two setups. You'll need to move the fence and getting the perfect setup is hard enough without having to do it in two setups.
What I would do, and this is just me, is do a climb cut. Run the wood in the same direction as the cutter is going. Don't do a full depth cut, just enough to form the start of the slot. This way you make the clean cut. And then push it through as normal to get the full depth of the slot. Since you've already cleaned out the cut with the climb cut there will be no chipout.
Now you have to be careful with this technique. If you go to deep the cutter may grab the wood and toss it. That's why you only take a small depth of cut. This is better done by holding the router than it is done on a table. But either way will work when you get the hang of it. Just be cautious of the first times you do it until you see how it will react. Keep your hand at the start of the board so it can't get away from you in the first place.
Climb cutting is done all the time to prevent chipout, even on shapers. I do it all the time with a hand held router. I mean all the time.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
The Following 3 Users Say Thank You to Leo G For This Useful Post:
hdavis (01-14-2019), rblakes1 (01-14-2019), Texas Wax (01-14-2019)
Old 01-14-2019, 11:16 AM   #10
JFM constr's Avatar
climb cut -thats the term i was looking for !
Old 01-14-2019, 12:08 PM   #11
KAP's Avatar
Trade: Custom
Rewards Points: 30,790
If you're going to use a router, as Leo said, but for that cut, with no profile involved, you'd be better off using the table saw to clear a groove as the rotation of the blade compliments the grain and doesn't push out against the sides so little to no chance of chipping like you have (unless you have a crap blade)....
KAP is offline
Old 01-14-2019, 03:26 PM   #12
rblakes1's Avatar
Thank you for all the replies. I haven't gotten back out to test out any other techniques yet.
Here are the bits and table I use, and as mentioned I have a bosch evs1619 under the table. I had the one feather board set on top and another parallel to the fence, feeding with a combo of hands and push stick
As much as I'd love a shaper, that's not in the cards right now. I could pick up the dado kit for my table saw, I had just assumed this bit set would eliminate that need.
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
hdavis (01-14-2019)
Old 01-14-2019, 03:51 PM   #13
LRG WoodCrafting
Leo G's Avatar
You won't be using a feather board if you are climb cutting. I would do each pc in a double motion. Set it in front of the cutter and pull back only letting it graze the pc so you get the start of the slot in there. Then I'd just push it through as normal.
If I was putting a featherboard anywhere, it's be to hold the pc down to the table. That way it'd flatten out any slight bow in the board.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 01-14-2019, 04:39 PM   #14
JFM constr's Avatar
Great serious looking table . When I am working with fir all the bits have to die into a sacrificial fence .there is term for this and i would appreciate some help discribing what i am saying .some types of wood you can get by without doing this .i do not seeing that your doing this on the set-up in the picture . the cutter is cutting on the into the fence on the leading side .which will greatly reduce chip out and splitting .please jump in help me make this easier to understand .wish i had a picture .
Old 01-14-2019, 04:44 PM   #15
LRG WoodCrafting
Leo G's Avatar
Zero clearance fence.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Made in USA product list J.C. General Discussion 372 01-09-2019 06:37 PM
Portable work table with router plate at HD platinumLLC Tools & Equipment 3 04-01-2016 08:30 AM
Looking for CNC Router for woodcarving recomemdations donschaeffer New Member Introductions 3 05-31-2013 05:31 PM
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
Router talk....101..... PrestigeR&D Tools & Equipment 94 12-16-2012 10:58 PM
