Car Siding Used Outside - Finish Carpentry - Contractor Talk
Old 01-27-2020, 09:15 AM   #1
GTXKen's Avatar
Rewards Points: 58
I have a covered porch that I would like to cover the ceiling and the one wall with car siding. Neither would ever be exposed to any direct contact with rain but since it will be outside, temperature change and humidity will certainly be an issue. I'm in indiana so we get extreems in heat and cold and the associated humidity.
How would you top coat or treat the wood?
My thought was to simply use a wood sealer like I would on the decking.
Car siding used outside-img_9853.jpg   Car siding used outside-img_9854.jpg   Car siding used outside-img_9855.jpg
GTXKen is offline
Old 01-27-2020, 09:53 AM   #2
GTXKen's Avatar
Rewards Points: 58
Re: Car Siding Used Outside
By the way I wasn't quite sure if I should post this here or in the siding forum
GTXKen is offline
Old 01-27-2020, 03:19 PM   #3
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
If you're using T&G planking, I would suggest using an exterior grade would sealer. Like you mentioned, similar to what you would use on decking.
CharlieDelta is offline
Old 01-28-2020, 10:52 PM   #4
rblakes1's Avatar
Rewards Points: 3,690
The couple I've done in the past, we used cedar and left it natural.
Too bad you didn't do a structural ridge, could've eliminated the tie
-Rich
rblakes1 is offline
Old 01-29-2020, 12:33 AM   #5
Mordekyle's Avatar
Rewards Points: 5,756
What is car siding?
Mordekyle is online now
Old 01-29-2020, 07:38 AM   #6
GTXKen's Avatar
Rewards Points: 58
-Rich
I plan on leaving it natural pine but I'd like to seal the surface
GTXKen is offline
Old 01-29-2020, 07:45 AM   #7
GTXKen's Avatar
Rewards Points: 58
Originally Posted by Mordekyle View Post
What is car siding?
It was actually originally called box car siding. It was used in barns and to line box cars before plywood came around. Now it used primarily in remodeling for lining walls and ceilings.
GTXKen is offline
The Following User Says Thank You to GTXKen For This Useful Post:
Mordekyle (01-29-2020)
Old 01-29-2020, 09:07 AM   #8
tjbnwi's Avatar
Rewards Points: 2,822
Gotta ask---do you own a Plymouth GTX? If so how about a picture? The good ol' days....
tjbnwi is online now
Old 01-29-2020, 09:23 AM   #9
GTXKen's Avatar
Rewards Points: 58
Yes I do, the first forum I joined was a mopar forum hence the name, it just stuck
GTXKen is offline
Old 01-29-2020, 09:32 AM   #10
GTXKen's Avatar
Rewards Points: 58
Had to resize them
Car siding used outside-20120927_163202.jpg   Car siding used outside-20120927_162058.jpg
GTXKen is offline
The Following 4 Users Say Thank You to GTXKen For This Useful Post:
AustinDB (02-03-2020), Idothat (01-29-2020), rblakes1 (01-29-2020), tgeb (01-29-2020)
Old 01-29-2020, 09:34 AM   #11
GTXKen's Avatar
Rewards Points: 58
I just noticed where you live, I'm also in Cedartucky just North of Lowelabama
GTXKen is offline
Old 02-03-2020, 12:53 PM   #12
Box Builder
Morning Wood's Avatar
Rewards Points: 10,346
I'd seal all 4 sides and then blind nail it.
Morning Wood is offline
Old 02-06-2020, 12:52 AM   #13
tjbnwi's Avatar
I'm currently in Colorado Springs, moving here perminently in the next few months. I'm west of the town, Calumet Ave is behind my house.
I'll be home in a few weeks to get some things done on the house to put it on the market.
I thought I was the only one here who used auto rotators...
Idothat (02-07-2020), MN_general (02-08-2020)
Old 02-06-2020, 07:55 AM   #14
GTXKen's Avatar
Rewards Points: 58
I've got two daughters out that way. It's always sunny out there. I made mine, what kind of car is that in there? Looks like a rear engine car of some sort.
GTXKen is offline
Old 02-06-2020, 08:36 AM   #15
tjbnwi's Avatar
A Pantera.
Old 02-07-2020, 05:45 PM   #16
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,727
Detomaso?? 351 Cleveland ?? Or were they Windsor??
rescraft is offline
Old 02-07-2020, 06:32 PM   #17
tjbnwi's Avatar
Yes
Cleveland, all were 4 bolt mains.
This one has twin turbos, an Australian nickel block, produces 1200 hp to the wheels.
Tom.
Car siding used outside-3ef35e18-acfb-4c42-affa-4db0faa5df7c.jpeg   Car siding used outside-6c133e98-6847-41ef-805b-a908acb305e3.jpeg
Idothat (02-07-2020), rescraft (02-08-2020)
