Best Glue? - Page 3 - Finish Carpentry - Contractor Talk
Best Glue?
Old 03-15-2019, 11:40 AM   #41
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,412
Re: Best Glue?
i do not have any specific research regarding tb3 compared to to ,well anything .
i am not familiar with shock resistant cyclamate . that would be an improvement .
i have an article from july august 07 FHB . they use a bridle joint to compare different glues .Polyurethane does not do very well .i was glad since it was such a pain to work with .cyclamates are not even considered .
JFM constr is offline
Old 03-19-2019, 07:00 AM   #42
Donohue Const's Avatar
Rewards Points: 1,722
Re: Best Glue?
I glued one up using the tbII and two dots of ca to hold it until glue dried
that one held better then any of the others
just cant believe that the other wood glue sucked so much
thanks guys!!
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following 2 Users Say Thank You to Donohue Const For This Useful Post:
hdavis (03-20-2019), pinwheel (03-19-2019)
Old 03-19-2019, 07:15 AM   #43
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,701
Re: Best Glue?
Would I lie to you?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 03-19-2019, 07:29 AM   #44
Re: Best Glue?
maybe
just cant believe it was that big of a difference
Ryan
Old 03-19-2019, 08:33 PM   #45
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 506
Re: Best Glue?
Originally Posted by Donohue Const View Post
maybe
There's a reason those of us who do a lot of glue ups, use TB2. If it works, don't fix it.
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
SmallTownGuy (03-20-2019)
Old 03-20-2019, 08:03 AM   #46
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 7,632
Re: Best Glue?
Doing a lot of stuff outside I like TB3 for any domestics. The only problem I've ever had with it is if it stores too long it will separate into a clumpy mess. I also always use the titebond brush these days. That thing is awesome, keeps everything way cleaner and a perfect amount of glue.
TB2 I use for most edge glue ups.
Lots of epoxy for outside as well especially in exotics but that's a whole different animal. I've never gotten anything to stay put with TB3 on exotics no matter how I prepped, inside is a different story.
‘ugly and inaccurate because our thoughts are foolish, but the slovenliness of our language makes it easier for us to have foolish thoughts.’ -George Orwell
Deckhead is online now
Old 03-20-2019, 09:27 AM   #47
JFM constr's Avatar
Re: Best Glue?
i had to make some exterior shelves from IPE ,did research and some found a review ,said his tb3 held the best . I the wiped the edge with something/alcohol or before glue-up .i also used dominoes .i told the client it was a dumb choice of wood . all i ever heard is that the boards warped big .never said they came apart .Well it held well enough that I got them delivered ,that I know .
Old 03-20-2019, 10:10 AM   #48
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
What is this Titebond Brush you speak of?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-20-2019, 01:13 PM   #49
tjbnwi's Avatar
Rewards Points: 4,762
Re: Best Glue?
It’s just a silicone glue brush with TB’s name on it.
These are the ones i use, have a few extra in the kitchen and grill area also.
https://www.woodcraft.com/products/s...e-glue-brush-1
tjbnwi is offline
Old 03-20-2019, 02:14 PM   #50
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-20-2019, 07:15 PM   #51
Re: Best Glue?
does the brush help with anything? like bond better
or is it just for making spreading glue on a larger area easier?
Ryan
Old 03-20-2019, 07:50 PM   #52
hdavis's Avatar
Rewards Points: 2,198
Re: Best Glue?
The right brush helps you get the right amount on. Some will give too little, some too much.
hdavis is offline
Old 03-20-2019, 08:33 PM   #53
tjbnwi's Avatar
Re: Best Glue?
We use it to spread the glue in miter locks primarily.
tjbnwi is offline
Old 03-26-2019, 01:55 PM   #54
skill77's Avatar
Rewards Points: 72
Re: Best Glue?
Whenever I am trimming or building something I clamp immediately i use TBI because it seems to require the least clamping time so when preassembling casing and small crown or base sections I can get them installed faster. If it is going to take a while to clamp or is exterior I use TBIII but I will say I hate the stuff. Every jug I buy seems to have sand in it. Dad has used TBII for years for any and everything and to my knowledge has never had a problem.
skill77 is offline
Old 03-28-2019, 07:17 AM   #55
Deckhead's Avatar
Trade: Carpentry,
Re: Best Glue?
Because it's a silicone brush it basically runs several beads across the surface which is exactly what I want every time.
Not too mention, if I forget to clean it, the glue (and even epoxy) will pull off of the head of the brush.
Old 03-28-2019, 07:54 AM   #56
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,122
Re: Best Glue?
Less expensive
https://www.amazon.com/Fodier-Silico...ateway&sr=8-17
An appeaser is one who feeds a crocodile, hoping it will eat him last.
Winston Churchill
Robie is offline
TRThomas (04-09-2019)
Old 04-09-2019, 05:42 PM   #57
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 382
Re: Best Glue?
First of those silocone glue brushes I ever bought were Rockler branded but I'm sure they weren't the first to market. Those basting brushes look like a much more cost effective option for gluing only. The Rockler, Titebond, Benchdog etc branded ones have a caulking spreader which is occasionally handy.
In my experience TBIII is the strongest if you get the joint clamped tight and keep it clamped until the glue sets but that's not always an option. TBII has a little more "give" once set than III which is better for pinned miter joints that might not (very likely not) be clamped as tight as something you had spring clamps on. If you've cleaned dried TBII and TBIII off glue bottle caps you'll notice the difference. Gorilla PVA glue isn't very good in my experience.
I've had pretty good results using 2p-10 and TBII and III. I spread TBII / III on the outside edge and a bead of TP-10 on the inside so any squeeze out of 2p-10 isn't visible and you can wipe the TB glue. If you've ever tried wiping 2p-10, or any CA glue for that matter with a damp rag, you will soon discover moisture instantly cures CA glue.
TRThomas is offline
Old 04-12-2019, 07:46 PM   #58
David-Remodeler's Avatar
Trade: Residential Remodeling Contractor
Rewards Points: 36
Re: Best Glue?
So what is the longest amount of time you guys are willing to work with TB2 between putting it on the lumber and being done clamping it up? 5 minutes? 10 minutes? More?
Anyone ever use any the Titebond extended stuff?
I've been using almost entirely TB2 and it's done well for me but this last week I glued up a 23 foot bar top out of 8/4 maple (built in sections) and I think I was pushing the limits of the assembly time on the glue so it might nice to find some other options if anything like that comes up again.
David-Remodeler is offline
Old 04-12-2019, 08:47 PM   #59
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
10 minutes easy I glue up large face frames onto a cabinet carcass and it can take me that long to do it by myself.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 04-12-2019, 08:53 PM   #60
TRThomas's Avatar
Rewards Points: 382
Re: Best Glue?
I used TBII for a cutting board I made a while back, IIRC it was 18 pieces 1-1/4" x 14" glue surface. I tried gluing all of them at once (1 side of each then flipping them 90-degrees to clamp) and the glue set up before I could get all of the pieces lined up perfectly. Ended up with a couple joints ~1/32" out of alignment. It was a gift so it didn't really matter but that was the first and last time I'll use TBII on anything like that which might require some finagling. TBIII has a significant longer open time, and is what I typically use for just about everything that can be clamped for at least an hour. I leave butcher block tops and cutting boards glued up for at least 12 hours though.
I also recall some lab did a strength test of a bunch of wood glues and TBIII had the strongest bond of all they tested. I don't remember if TB or TBII was second but it was one of them. Still prefer II for trim work, but 3 is best for large glue ups.
You could always use a slow set 2 part epoxy if you don't mind the extra effort in cleaning up the squeeze out. Table top epoxy is workable for quite a long time and its bond strength is incredible. I'm probably going to use some to join an edge grain to end grain maple counter top I'm installing next week. I tested it out couple days ago, glued a 3/4"x1" x6" end grain to edge grain board and couldn't break it by by hand. Took a pretty solid hit from a hammer and it tore the edge grain.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 is what I used.
TRThomas is offline
Glue down carpet removal platinumLLC Flooring 25 12-05-2014 04:55 PM
Let's Talk Glue Inner10 Tools & Equipment 56 06-25-2014 06:12 PM
Tigerwood Installation handyflooring Flooring 14 04-07-2013 12:47 PM
Glue down cork flooring, question to a real pros. hawaii Flooring 3 01-08-2012 11:27 AM
