Best Glue? - Page 2 - Finish Carpentry - Contractor Talk
Best Glue?
Old 03-11-2019, 12:01 PM   #21
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,087
Re: Best Glue?
I've used Gorilla PVA glue once. Weird consistency, whitish tan, it worked.
But I've been using TBII nearly my whole career. Before that it didn't exist and I used TBI. TBI dries harder, it doesn't have the plasticizes in it to be more rubbery and resistant to outdoor conditions which induce greater movement in the wood. TBI tacks up quicker than TBII. Which in most instances isn't a good thing for me. I trust TBII and have only had one (group) failure with it in my career. It was on cherry and it just didn't work. Parts fell apart with a slight bending. Don't know what happened, threw that bottle away and never had another issue.
Listen to me carefully. Put the bottle of Gorilla glue down. Step back and slowly turn around. Run to the nearest store and by a TiteBond glue.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
Donohue Const (03-11-2019), hdavis (03-11-2019), SmallTownGuy (03-11-2019)
Old 03-11-2019, 02:29 PM   #22
hdavis's Avatar
Rewards Points: 1,022
Re: Best Glue?
Originally Posted by Inner10 View Post
Is gorrila wood glue any different from any other PVA glue?
I'm thinking the only reason CA glue worked better is due to lack of clamping pressure.
It's a moisture curing urethane. Wet the wood, and you can get it to foam up like crazy. On occasion, it's the best solution, but those are so few and far between for me, I just throw out the bottle after I use what I need.
hdavis is offline
Old 03-11-2019, 02:36 PM   #23
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,484
Re: Best Glue?
The current fascination with anything named "gorilla" lately escapes me.
A wisdom learned the hard way (same here) I bet !
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (03-11-2019)
Old 03-11-2019, 02:40 PM   #24
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,348
Re: Best Glue?
No that's original Gorilla Glue, Gorilla wood is PVA.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Golden view (03-13-2019), hdavis (03-11-2019)
Old 03-11-2019, 04:08 PM   #25
hdavis's Avatar
Re: Best Glue?
Good catch, I didn't get past the gorilla. I haven't tried their PVA. Regular old carpenter's glue is PVA. I don't know if gorilla PVA is better or worse. If regular carpenter's glue isn't good enough, I just go with TB2. Waterproof, I go with DAP urea-formaldehyde, TB3, or epoxy.
hdavis is offline
Old 03-12-2019, 06:41 PM   #26
Donohue Const's Avatar
Rewards Points: 1,550
Re: Best Glue?
haven't had a chance to try the tbII yet
hopefully get a chance to glue one up tomorrow
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 03-13-2019, 12:20 AM   #27
Bull Trout's Avatar
Rewards Points: 664
Re: Best Glue?
Originally Posted by Leo G View Post
Throw the Gorilla glue away. Get Titebond one or two. Stay away from three.
What is wrong with 3?
Bull Trout is online now
Old 03-13-2019, 07:17 AM   #28
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
I've just heard to many complaints about failures to want to take the chance with the glue.
By all means, you can use it and let me know if you have any issues
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Bull Trout (03-13-2019)
Old 03-13-2019, 08:03 AM   #29
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 864
Re: Best Glue?
I pretty much exclusively use TB2. But my understanding, TB3 is slower setting & has advantages being used in complex, time consuming glue ups. I've done glue ups where getting all clamps on in 10 minutes or less was quite the challenge.
pinwheel is online now
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
Bull Trout (03-13-2019), Deckhead (03-20-2019)
Old 03-13-2019, 08:53 AM   #30
Railman's Avatar
Trade: Railing
Rewards Points: 601
Re: Best Glue?
We have been using TBIII for about 25 years on our curved rail glue ups, without any issues. As mentioned by Pin, III gives more time to get claps set correctly on complicated glue ups. I've never seen any issues on anything we glue up, including fittings.
One thing to remember though is that you need to prime cuts on end grains before adding final glue. This is especially important on rail fittings. Just coat, let set about a minute or so, & add a re-coat. If not, joint will end up dry.
Railman is offline
The Following 4 Users Say Thank You to Railman For This Useful Post:
Bull Trout (03-13-2019), Deckhead (03-20-2019), pinwheel (03-13-2019), Xtrememtnbiker (03-14-2019)
Old 03-13-2019, 09:53 AM   #31
Bull Trout's Avatar
Rewards Points: 664
Re: Best Glue?
Thanks guys
Old 03-14-2019, 10:39 PM   #32
tjbnwi's Avatar
Rewards Points: 4,638
Re: Best Glue?
I like Roo Glue, 2 minute clamps and you can't get the pieces apart.
I keep CA on hand for the times you just have to use it.
tjbnwi is online now
rrk (03-15-2019)
Old 03-15-2019, 05:54 AM   #33
Re: Best Glue?
I appreciate all the advice
I picked up some tbII yesterday
I'm going to mess around with it this weekend
so your saying it's best to glue both sides, let it sit for a minute to soak into the wood, then add more glue and clamp together?
Ryan
Old 03-15-2019, 07:30 AM   #34
pinwheel's Avatar
Rewards Points: 864
Re: Best Glue?
I don't do it that way. I apply to one side & mate it with the other piece & move them back & forth to smear the glue to both surfaces, then clamp.
The Following 3 Users Say Thank You to pinwheel For This Useful Post:
Donohue Const (03-15-2019), john5mt (03-23-2019), rrk (03-15-2019)
Old 03-15-2019, 07:56 AM   #35
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
I didn't say that and don't really agree.
PVA coat one side and stick'm together. On rare occasions I'll clean my finger off on the other miter, but that's mostly to just clean my finger
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
Donohue Const (03-15-2019), pinwheel (03-15-2019)
Old 03-15-2019, 09:33 AM   #36
Railman's Avatar
Trade: Railing
Rewards Points: 601
Re: Best Glue?
I would agree on typical moldings, but It depends on what you are gluing...ie oak vs maple, & how important it is to hold. On simple mitered moldings it's no big deal. Rail fittings & such it is a big deal. I have experienced dry fit failures on fittings. Prime, & re-glue is cheap insurance. Tightening up fittings can take longer than anticipated.
https://www.woodcraft.com/blog_entri...zing-end-grain
Railman is offline
Old 03-15-2019, 09:41 AM   #37
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,052
Re: Best Glue?
Leo -I also have been using tb3 for years . as far as i know it has never failed .have never heard of it failing for anyone .i have used in outside projects with 100% success also . Very surprised to hear you say that .
JFM constr is online now
The Following User Says Thank You to JFM constr For This Useful Post:
Railman (03-15-2019)
Old 03-15-2019, 10:02 AM   #38
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
Softer woods like pine and poplar might benefit from coating both sides because of the open grain and the chance it may suck up some glue. But birch, maple and other harder woods won't really benefit from it. Just make sure you put enough on that it squeezes out just a bit. Not to the point it dripping onto the floor, but little glue bubbles. Nail it, wipe off the glue, with water if it's prefinished or sand it into place if it's going to get painted. It'll fill in any small gaps.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-15-2019, 10:03 AM   #39
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
Anytime I read something about TB3 it's a failure issue of some sort. Glad you guys have good luck with it. I won't be using it anytime soon.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-15-2019, 11:02 AM   #40
hdavis's Avatar
Re: Best Glue?
There is a lot to this topic. Best really depends on the details of what you're doing. TB3 tends to give weaker joints than some other glues, but that still can depend on species, surface roughness, and clamp pressure.
hdavis is offline
Glue down carpet removal platinumLLC Flooring 25 12-05-2014 04:55 PM
Let's Talk Glue Inner10 Tools & Equipment 56 06-25-2014 06:12 PM
Tigerwood Installation handyflooring Flooring 14 04-07-2013 12:47 PM
Glue down cork flooring, question to a real pros. hawaii Flooring 3 01-08-2012 11:27 AM
