Best Glue? - Finish Carpentry - Contractor Talk
Best Glue?
Old 03-10-2019, 06:08 PM   #1
Donohue Const's Avatar
Rewards Points: 1,380
Best Glue?
I dont do a whole lot of trim work
I'm working on a small chair rail project
I usually try to glue and pin the outside miters, but I got to thinking about some ca glue with the accelerator spray to make it set instantly
I took some scrap pieces and did a test
first one, ca glue with pins
second one, two small dots of ca glue and wood glue on joint(ca glue was used just to hold in place until wood glue cured) plus pin nails
third one, just wood glue with pin nails
I let them all sit for 24 hours (cure time for wood glue) , I tried breaking all three joints apart this morning .
first one was very hard to break
second one was tough but not that hard to break
third one broke very easy
I feel like the ca glue worked very well based on my small test
any one have any real word experience between the two different types?
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
The Following User Says Thank You to Donohue Const For This Useful Post:
Repede Emil (03-13-2019)
Old 03-10-2019, 06:13 PM   #2
Re: Best Glue?
trim was prefinished oak
Ryan
Old 03-10-2019, 06:31 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,845
Re: Best Glue?
Surprised the yellow glue failed the easiest.
My go to is usually yellow glue with a couple drops of CA (2P-10). Now they have a new glue, 2P-10R. Suppose to be more resilient against shock fracturing.
What was the yellow glue? I use TBII
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
donerightwyo (03-10-2019)
Old 03-10-2019, 07:00 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,434
Re: Best Glue?
Just pin nails don't provide enough clamping pressure for pva glue, especially on a mostly end grain joint.
Sent from my SM-N960U using Tapatalk
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 03-10-2019, 07:17 PM   #5
Re: Best Glue?
this was the glue I had
would the couple drops of ca glue I did on the second one be enough pressure?
Ryan
Old 03-10-2019, 07:18 PM   #6
Re: Best Glue?
this was the ca glue only
got a little to much on and it came out on the top
Ryan
Old 03-10-2019, 07:19 PM   #7
Re: Best Glue?
two drops of ca plus wood glue
Ryan
Old 03-10-2019, 07:20 PM   #8
Re: Best Glue?
wood glue only
all had a bout 4 pins per side
Ryan
Old 03-10-2019, 07:25 PM   #9
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
Throw the Gorilla glue away. Get Titebond one or two. Stay away from three.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
DaVinciRemodel (03-13-2019), rrk (03-10-2019), sunkist (03-11-2019)
Old 03-10-2019, 07:27 PM   #10
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,890
Re: Best Glue?
I've switched to TBII from 2p-10. Seems to hold up better, especially against shocks.
I have a lot of corner clamps, so I usually just assemble everything one day and install the next. Maybe do two batches in one day, but just remove the clamps to assemble more, I don't actually install the first batch until the next day.
Despite all that, I typically biscuit everything with enough meat.
Half of all people are below average.
Golden view is offline
Old 03-10-2019, 07:27 PM   #11
edward trowelhands
Trade: Diplomat
Re: Best Glue?
Does it have less strength as a trade-off for water resistance? Of course it's also more expensive.
Old 03-10-2019, 07:35 PM   #12
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
Suppose to be water proof. But all I usually hear about it is failures. I have stuff outside that I've glued up with TBII for decades.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-10-2019, 07:38 PM   #13
Re: Best Glue?
I was reading that the tbII held up better because the ca was supposed to be brittle
some said to use the two drops of ca glue to act as a clamp until the wood glue dries
I was expecting the ca with wood glue to be the best of both world, not waiting for clamp/dry time
I'll get some tbII and try the test again tomorrow to see if I get different results
Ryan
Old 03-10-2019, 07:40 PM   #14
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
I use the 2P-10 as a clamp for the TBII. I've done door trim this way. Bring a couple of pcs of prefinished plywood as work surfaces. A single or double biscuit depending on the width of the trim. TBII in the biscuit and along most of the seen edges and a medium size drop at each corner. Press them together for 10 seconds, do the other side and gently lift it to lean against the wall. Do the rest the same way and then when you're done go to the first and start installing. As strong as using those corner clamps and no holes. Great for stained trim.
All the CA is a clamp for the yellow glue.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
Golden view (03-10-2019), KAP (03-10-2019)
Old 03-10-2019, 07:42 PM   #15
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
Make sure the 2P-10 and TBII don't mix. It'll kill the 2P-10 and it won't dry.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
asevereid (03-11-2019)
Old 03-10-2019, 07:50 PM   #16
Re: Best Glue?
what would you do on a outside miter for a chair rail like this?
just clamp and wood glue?
you cant get a biscuit in it, can you?
Ryan
Old 03-10-2019, 07:56 PM   #17
rrk's Avatar
Rewards Points: 960
Re: Best Glue?
TBII and collins clamps
rrk is offline
Deckhead (Yesterday)
Old 03-10-2019, 08:02 PM   #18
LRG WoodCrafting
Leo G's Avatar
Re: Best Glue?
CA with TBII
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-11-2019, 10:40 AM   #19
hdavis's Avatar
Rewards Points: 4,474
Re: Best Glue?
I'd lose the bottle of gorilla glue....
hdavis is online now
Old 03-11-2019, 11:12 AM   #20
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,096
Re: Best Glue?
Is gorrila wood glue any different from any other PVA glue?
I'm thinking the only reason CA glue worked better is due to lack of clamping pressure.
Inner10 is offline
Glue down carpet removal platinumLLC Flooring 25 12-05-2014 04:55 PM
Let's Talk Glue Inner10 Tools & Equipment 56 06-25-2014 06:12 PM
Tigerwood Installation handyflooring Flooring 14 04-07-2013 12:47 PM
Glue down cork flooring, question to a real pros. hawaii Flooring 3 01-08-2012 11:27 AM
