Trade: Commercial interior super
Bay Window Trim..
Hey guys, been a while since I've been on, THANK GOD!! Work is picking up..
Anyway, I have a question about what type of tool to use. I'm replacing a bunch of rotten trim around 3 bay windows, which is mainly located at the bottom pieces and such. My question is, I have about a 14' vertical piece, which only needs about 8" replaced. It's also the piece that butts up to the brick siding. What tool do you all use to just cut a level line above the rot, so I can just replace a 1' of trim, instead of the entire piece? I'm assuming you all are going to go with the Fein Multi Master. But do you all have any other suggestions..
"Relentless in Reliability and Satisfaction!" Oh yeah, 1 other thing... Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Re: Bay Window Trim..
Angle grinder should work, I would recommend using some painters tape on the trim to make a straight line before you cut.
Advertisement |
That might work, what blade would you recommend?
Sponsored Links | |||
Advertisement |
Rewards Points: 2,000
If it's brickmold you're talking about,
you'll probably be time and money ahead if you just pull the whole piece off and replace it. The older it is the less likely it is that the profile will even remotely be a match.
No, it's a 1x8 piece...
Same principle, just be sure you are
realistically weighing the time and effort involved in saving that remaining piece against blowing it off and putting in a new one. ![]()
Oh, I am brother. Trust me.
Cool, I can't see it
you can. It's just easy to get carried away with the original thought and wind up chasing rainbows. ![]()
Rewards Points: 2,464
Hey mitch,
I have used my bosch flush cut saw for stuff like that on numerous occasions. You should be able to let the end of the blade just touch the brick, it dosen't jump like a sawzall does when the end of the blade hits something. And the blade is switchable from left to right. I picked mine up at lowes it included all three blades, I believe they still carry them and the blades. Its does all kinds of stuff, cuting door jambs is a big one for me. Heres the saw: http://www.toolbarn.com/product/bosch/1640VS/ Dave |
#10 | |
![]() Re: Bay Window Trim..Quote:
Thanks DK!!
Trade: remodeling, and LOTS of repair work
Rewards Points: 79
Generally, it's better to replace the whole piece, but if you have to "patch"---if it's a molding like brick molding, I use my Fein to make the cut and make sure you BEVEL the cut! (I use about 20 -30 degrees) and seal the ends of each piece(caulking smeared on with a putty knife or finger is just fine). Do NOT square cut the joint. If it's a flat casing, I use a circular saw, cordless or corded, and my speed square. Yes, this gets beveled, too! If you are replacing a piece at the bottom, make sure you seal the bottom edge where it meets the sill. I'm talking about sealing the entire end grain (the part that sucks up the water), NOT on the outside of the joint after it's in place.
Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Replacement Window Question? | Max10 | Windows, Siding and Doors | 41 | 11-03-2013 12:01 PM |
estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
Screwing aluminum trim to window. | Patrick | Windows, Siding and Doors | 27 | 07-08-2008 03:44 PM |
Exterior Window and Door Trim | MikeNeufeld | Carpentry | 5 | 10-30-2007 01:57 PM |
Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 08:47 AM |
Go to Page... |
