Base Issue! - Finish Carpentry - Contractor Talk
Base Issue!
Old 01-14-2012, 10:40 PM   #1
Wasting Time
Knighton's Avatar
Rewards Points: 75
Base Issue!
I'm running 4-1/4" base and am debating on what the best way to run it under these return vents (one of which is only 2-1/4" off the floor).
I've got three potential soutions, and wanted some feedback as to which one (if any) would work best:
1) stepping down the base trimming the bottom and then stepping it back up at the end of the return.
2) run it strait and make a cutout in the base for the vent.
3) run the base to the vent, use a self return, then use base shoe under the vent, then begin base with another self return.
Any ideas would be greatly appreciated.
Chris
Knighton is offline
Old 01-14-2012, 10:46 PM   #2
Pbrenos's Avatar
Trade: General contractor
Rewards Points: 14
Re: Base Issue!
Is it possible to raise the vent 2".
Pbrenos is offline
Old 01-14-2012, 10:48 PM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Base Issue!
Ya, looks like a return air vent... piece of cake to move it.
-Steve
TimelessQuality is offline
Old 01-14-2012, 10:49 PM   #4
jb4211's Avatar
Rewards Points: 2,306
Re: Base Issue!
I would probably run the 4-1/4 trim and shorten the height of the return. I think this would look best. I would consult with my HVAC guy first to be sure, but I don't see that being a big issue. It appears to be a large return as it is.
Or still shorten the height of the return, but maybe make the return wider to make-up for the shortened height.
I would try my best to run the trim normally
Jon
jb4211 is offline
Old 01-14-2012, 10:52 PM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Base Issue!
Looks like you could use a pack-out to run the base right past the grills. Just remove the lower screws so you can remove them, if need be.
The base won't encroach on the actual open space.
loneframer is offline
Old 01-14-2012, 10:57 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Base Issue!
id use vented base
Tom Struble is offline
Old 01-14-2012, 11:28 PM   #7
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
Re: Base Issue!
Looks to me that you could just run the base directly across the vents Based on the 1st photo - looks like the base and cap is below the grate of the vent (though not below the trim of the vent). I would apply the base cap to the vent cover so that you could remove all as one piece- back rabbet as needed to keep everything in the proper plane. I think you could work it out so that the base and cap stayed in the same plane around the corner with adjustments made to keep the vent cover removable. It is not a great situation but it is what it is. Changing heights and orientations with returns etc. would just attract even more attention. Of course if you can raise the vent that would be the best.
Grace is bestowed upon the soul - not upon the ego.
RS Sam is offline
Old 01-15-2012, 12:04 AM   #8
Wasting Time
Knighton's Avatar
Rewards Points: 75
Re: Base Issue!
The base trim in the photo will be removed, but rabbeting out the back may work!
Knighton is offline
Old 01-15-2012, 12:10 AM   #9
Wasting Time
Knighton's Avatar
Rewards Points: 75
Re: Base Issue!
By pack-out I assume you mean to shim the base out from the wall far enough to pass over the grill?
Knighton is offline
Old 01-15-2012, 12:13 AM   #10
Wasting Time
Knighton's Avatar
Rewards Points: 75
Re: Base Issue!
Unfortunately, I've got to solve this without getting a new grill.
Knighton is offline
Old 01-15-2012, 12:40 AM   #11
jb4211's Avatar
Re: Base Issue!
Why
Jon
jb4211 is offline
Old 01-15-2012, 12:42 AM   #12
KemoSabe
loneframer's Avatar
Re: Base Issue!
Exactly. Rip something on the table saw or you might get away with 1/4" thick lattice molding.
Old 01-15-2012, 12:43 AM   #13
jb4211's Avatar
Re: Base Issue!
If that's the case, trim the base as necessary to go around the vent cover and angle the cut as it's not at 90 degrees when it meets the grill but something more appealing, like 45 or 30 degrees.
Jon
jb4211 is offline
Old 01-15-2012, 12:44 AM   #14
JesseCocozza's Avatar
Rewards Points: 810
Re: Base Issue!
Anytime I have that application I step it down tight to the register and then step back up. That's how's I've always done it.
JesseCocozza is offline
Old 01-15-2012, 12:45 AM   #15
jb4211's Avatar
Re: Base Issue!
I don't think it would look right have the grill go behind the molding. I think it would look weird.
Jon
jb4211 is offline
Old 01-15-2012, 12:45 AM   #16
jb4211's Avatar
Re: Base Issue!
I think this is the only way to do it.
Jon
jb4211 is offline
Old 01-15-2012, 12:52 AM   #17
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 514
Re: Base Issue!
I'd try option 2 first, rabbiting out the back of the base to fit the grill depth. Or keep it tight, and step it down/back up. It looks like you'll be having the same problem around the corner too...
Maybe accent the return rather than working around it? frame it out with a quarter round, or similar sized trim, then blend that into the base?
KnottyWoodwork is offline
Old 01-15-2012, 12:53 AM   #18
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Base Issue!
Do not trust the nfc guy..
ohiohomedoctor is offline
Old 01-15-2012, 01:10 AM   #19
cannon's Avatar
Trade: Interior trim
Re: Base Issue!
Cleanest option is to frame the grills with your base material and run the base cap around the grill s, depending on what you plan on doing with that jacked up window sill
cannon is offline
Old 01-15-2012, 01:11 AM   #20
WildWill's Avatar
Rewards Points: 504
Re: Base Issue!
I miter the base and then rip the base to go around the register. Like so. The register comes off and the base/trim runs under it a bit.
WildWill is offline
The Following 4 Users Say Thank You to WildWill For This Useful Post:
DC INC (01-15-2012), jb4211 (01-16-2012), Metro M & L (01-15-2012), TIGHTER MITER (02-15-2012)
base trim on island Kent Whitten Finish Carpentry 40 03-03-2012 01:14 AM
Router Table base cabinet. ApgarNJ Tools & Equipment 83 11-06-2010 12:39 AM
Need a saw to cut 7.25 base standing up DKC94 Finish Carpentry 14 09-26-2010 08:11 PM
Old Floors - Water Base Sealer is down - Grain Raise JPlous Flooring 15 12-22-2008 10:00 PM
New base housing Higgs General Discussion 5 11-10-2008 06:18 PM
