Azek, Never Used It. Going To Be On A Trim Package. - Finish Carpentry - Contractor Talk
Old 08-26-2016, 12:32 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,493
I'm going to be using a lot of 1x8. Comes in 18' lengths. Most of my lengths will be in the 12' area. I'm making corner boards with a bead and rabbet. I'll likely be gluing them together as a unit then shipping them.
I have to make some beam covers and some post casings. The beam covers will consist of a 10 3/4" tall side and a 8" bottom that will be dadoed into the sides. The 2 bottom inside edges will have coves milled into them. The post casings will be the same beaded corner, just make square boxes (tubes) out of them. Glue 3 sides and then the 4th on site after they are slipped over the 6x6 PT engineered posts.
Mostly concerned with movement. I know it moves with temperature and more than wood. Plus what adhesive do you recommend. I've heard the Azek glue is OK, but not really strong. I was looking around and found something called Trimbonder and it might have been renamed as TrimGrip.
Any hint, pitfalls, suggestions would be helpful.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-26-2016, 01:06 PM   #2
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 976
Re: Azek, Never Used It. Going To Be On A Trim Package.
Where are you buying it from?
EricBrancard is online now
Old 08-26-2016, 01:28 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,748
Christy's Red hot adhesive.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Tom M (08-26-2016)
Old 08-26-2016, 01:33 PM   #4
gbruzze1's Avatar
Rewards Points: 2,608
Is it getting painted? I don't think you're going to be able to route s bead into it and get it to match the factory finish. Molts of sanding and acetone will get you close.
Also, spray yourself and your tools down with this:
Shipping is absolutely 100% free if you are an Amazon prime member, lol.
Gary
gbruzze1 is offline
The Following User Says Thank You to gbruzze1 For This Useful Post:
Splinter (08-26-2016)
Old 08-26-2016, 02:50 PM   #5
Ohteah's Avatar
Trade: Carpentry/Exterior Renovations
Rewards Points: 46
Best stuff I've found. Not a ton of open working time with it .
I've seen the trim welder @ Tague lumber, always wanted to try it . Curious about the 2 part epoxy stuff.
Don't paint it dark colors.
Ohteah is offline
Old 08-26-2016, 02:53 PM   #6
Ohteah's Avatar
Rewards Points: 46
Bond & Fill, that's the 2 part stuff , not Trim welder.
Ohteah is offline
Old 08-26-2016, 03:17 PM   #7
LRG WoodCrafting
Leo G's Avatar
I'm not. It's getting delivered. I made the parts list and handed it to the GC. He says it'll be at my shop on Monday or Tuesday.
Just texted the GC. If he tells me, I'll tell you.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-26-2016, 03:20 PM   #8
LRG WoodCrafting
Leo G's Avatar
Gary
No paint. It's already tan in color. The HO approved of the bead and the cove already. What's the acetone do? Melt it down smooth again? Sounds like more trouble than it's worth.
Wonder if I could use that as deodorant? Says Fresh Scent.
I'm not paying for free shipping....
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-26-2016, 03:24 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,746
Is it colored all the way through? Never seen any that wasn't white core.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 08-26-2016, 03:29 PM   #10
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 52
I have never used the Christy's, but the Azek glue works pretty well. We get Azek by the
truckload on some jobs. With only 12' lengths, you shouldn't do too bad with movement.
Some blue tape works well to hold the final joint on site after glue up.
Easy Gibson
Warren is offline
Old 08-26-2016, 03:39 PM   #11
gbruzze1's Avatar
The acetone helps to seal the cells after cutting.
http://www.thisiscarpentry.com/2012/...ions-pvc-trim/
Gary
gbruzze1 is offline
Old 08-26-2016, 03:46 PM   #12
LRG WoodCrafting
Leo G's Avatar
Yup, all the way through.
On a pc of white paper.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-26-2016, 03:50 PM   #13
Rewards Points: 976
Palight color2core would be my guess. I don't think Azek makes that.
Old 08-26-2016, 03:56 PM   #14
LRG WoodCrafting
Leo G's Avatar
Ya, that was it. PVC trim/Azek That's what the GC said initially. But I remember looking at the pamphlet and Palight rings a bell.
Guess I should ask a MOD to change the title, huh?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-26-2016, 04:27 PM   #15
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 791
i have used plumbing pvc glue in the past. I would fill a squeeze bottle with it and it was easy to run a small bead of glue. You have to work quick but i have done fourteen foot porch post with pvc glue by myself.
don't let it run down the sides it leaves a mark
nicko
"Quality work for those who know the difference"
nickko is offline
Old 08-26-2016, 06:29 PM   #16
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,048
Is the stuff like lumber 3/4 being called 1" and 1" being called 5/4? I use versatex and the is the way it is. 3/4 stuff is 20' and 5/4 is 18'. I just use a clear PVC plumbing glue.
Randy Bush is offline
Old 08-26-2016, 06:44 PM   #17
LRG WoodCrafting
Leo G's Avatar
1x is 3/4" unless you are buying it in 4x8 sheets. Then they call it 3/4"
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Randy Bush (08-26-2016)
Old 08-26-2016, 07:18 PM   #18
Rewards Points: 976
You sure it's not the other way around? I've used 5 or 6 brands of PVC and it's always been 18' for 1x and 20' for 5/4.
Old 08-26-2016, 07:23 PM   #19
Geometrist
Warren's Avatar
Rewards Points: 52
We get 18's for 1x and 5/4 in the Azek brand.
Corners come 10' and 20'
Trims are all 16'
Easy Gibson
Warren is offline
Old 08-26-2016, 07:23 PM   #20
LRG WoodCrafting
Leo G's Avatar
The stuff I'm getting comes in 18' lengths and is 3/4" thick (1x)
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Another Azek trim ? (Lone) redwood Carpentry 26 03-08-2015 03:12 PM
Solid color pvc trim WarnerConstInc. Windows, Siding and Doors 24 06-05-2013 06:49 PM
Ben Moore Aura as a trim paint?? Dorman Painting Painting & Finish Work 10 03-19-2013 09:35 AM
Azek trim specialist. redwood Carpentry 12 05-20-2012 02:04 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
