59 Degree Crown Spring Angle For 10' Ceiling? - Finish Carpentry - Contractor Talk
Old 05-02-2015, 03:43 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
This is the steepest spring angle crown I've ever come across and was wondering if it's common.
10' ceilings. 7-1/4 crown. Spring angle comes to 58.8 the way the crown should look on the back side.
I know the common 38,45,52 common angles. Is 59 degrees common for tall ceilings?
Lewis Carpentry
Spencer is offline
Old 05-02-2015, 04:15 PM   #2
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Re: 59 Degree Crown Spring Angle For 10' Ceiling?
You need a hold of TT's DVD for install of crown if not wanting of much putty or caulk when trying to coping of that.
:sly::sly::sly::sly: sorry, couldn't resist.
mnld is offline
The Following 3 Users Say Thank You to mnld For This Useful Post:
EricBrancard (05-02-2015), m1911 (05-02-2015), Youngin' (05-03-2015)
Old 05-02-2015, 04:53 PM   #3
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 228
Looks like it's upside down. Just seems to make more sense if the wall and ceiling labels were reversed.
EricBrancard is offline
The Following 8 Users Say Thank You to EricBrancard For This Useful Post:
98crewcab (05-03-2015), greg24k (05-04-2015), PrestigeR&D (05-03-2015), Rio (05-02-2015), rrk (05-02-2015), Texas Wax (05-03-2015), WarnerConstInc. (05-02-2015), Warren (05-02-2015)
Old 05-02-2015, 04:57 PM   #4
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Agreed. But I'm not a designer.
Justin, get over here...
Xtrememtnbiker is offline
Old 05-02-2015, 05:03 PM   #5
Rewards Points: 228
Just by looking at the angle and the contours it should be reversed. The way he has it now puts the terminating profile in the wrong spot. Plus I can't imagine a moulding with so much projection and so little drop.
The Following User Says Thank You to EricBrancard For This Useful Post:
rrk (05-02-2015)
Old 05-02-2015, 05:08 PM   #6
Rewards Points: 340
I agree. My comment was meant to indicate I'm not very educated on how trim profiles work, but my gut thinks it looks odd that way.
Old 05-02-2015, 05:10 PM   #7
Joemack1's Avatar
Rewards Points: 382
Most crown has the fancy part along the wall not the ceiling. Spencer I think you need to reverse it.
Joemack1 is offline
Old 05-02-2015, 06:03 PM   #8
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
What is a "spring angle"?
I need more tools.
summithomeinc is offline
Old 05-02-2015, 06:05 PM   #9
Rewards Points: 228
The angle of the crown between the wall and ceiling. Most common angle and what most miter saw detents are setup for is 38 deg.
Old 05-02-2015, 06:05 PM   #10
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,738
There are lots of spring angles other than 38 and 45. There are 2 different Windsor One profiles that I see regularly that have angles of 35 and 50. The odd angles are one of the reason I like to cut in position. I don't need to know/care what the angle is in order to cut it.
In the orientation you have it it can be coped but you might have some trouble cutting it in position. In the other orientation it can be cut in position but is uncopable because the round beads will drop below horizontal. Like others said the beads usually go at the top and the small round over is a terminating profile.
People that design uncopable mouldings like that have never installed or seen installed a single piece of crown. The titles are usually something like "architect" or "interior designer" but most of us usually refer to them as "idiot".
Justin Huisenga is offline
The Following User Says Thank You to Justin Huisenga For This Useful Post:
rrk (05-02-2015)
Old 05-02-2015, 06:21 PM   #11
Ok..Now I'm feeling really dumb...If the wall is plumb and the ceiling level...Wouldn't the angle be 90 deg.?
Know of any good books or other references that explain all this? When I cut crown (rarely) I set it in the saw the way it goes on the ceiling and cut it at 45 deg.
I need more tools.
Old 05-02-2015, 06:25 PM   #12
Rewards Points: 228
So when you are setting your crown on the saw to cut it on a 45, the angle that it's sitting at is the spring angle.
Think of the assembly as a right triangle. The wall and ceiling are the legs and the crown is the hypotenuse. The angle of the wall leg and hypotenuse is the spring angle.
summithomeinc (05-02-2015)
Old 05-02-2015, 06:25 PM   #13
Rewards Points: 340
ok..now i'm feeling really dumb...if the wall is plumb and the ceiling level...wouldn't the angle be 90 deg.?
Know of any good books or other references that explain all this? When i cut crown (rarely) i set it in the saw the way it goes on the ceiling and cut it at 45 deg.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 05-02-2015, 06:30 PM   #14
A picture really is worth a thousand words.
I need more tools.
Old 05-02-2015, 06:41 PM   #15
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Looks upside down, but either way, don't forget to celebrate the cope with silicone...
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Agility (05-02-2015)
Old 05-02-2015, 06:47 PM   #16
Designer/Contractor
Rio's Avatar
Rewards Points: 190
EB's right, just proportion wise it wants to go the other way.
Rio is offline
Old 05-02-2015, 07:51 PM   #17
rrk's Avatar
Rewards Points: 2,810
Not knowing how crown is supposed to be positioned could be a problem
That would have been funny to put up a ton of crown upside down
rrk is online now
Old 05-02-2015, 08:21 PM   #18
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
This wouldn't have been the first time crown has been installed upside down. :-)
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Old 05-02-2015, 08:27 PM   #19
rrk's Avatar
Nope nor the last, a condo that I do some work in had 3 floors 300 lf each of 8" crown installed upside down. Architect nearly had a stroke, none of the installers spoke English. They just nodded their heads when he asked then if they knew what they were doing.
rrk is online now
Old 05-02-2015, 08:41 PM   #20
m1911's Avatar
Seen it done many times before.
Had one customer wanted me to put crown upside down in all the rooms to match the one room that someone installed the crown upside down. She had no clue it was upside down, nor did the person that installed it obviously. I couldn't bring myself to do it, so I convinced her to rip it out and let me start over. I fixed it for free, but I charged her for materials and labor.
m1911 is offline
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
Bullnose on vaulted ceiling crown..... kevbo Finish Carpentry 15 04-22-2013 06:34 AM
right angle drill/driver Rich D. Tools & Equipment 16 06-29-2012 03:06 PM
Need help on Crown Molding on Trey Ceiling pcumming Finish Carpentry 52 01-31-2010 08:42 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
