42" Entrance Door..manufacturer? - Page 2 - Finish Carpentry - Contractor Talk
Old 12-21-2013, 04:49 PM   #21
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Re: 42" Entrance Door..manufacturer?
Give me 3/4 of an hour......
Transit....
You guys are incredible......
B,
PrestigeR&D is offline
Old 12-21-2013, 04:52 PM   #22
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Transit....
B,
Maybe Warner or Jack can lend you some machines if the door won't fit in your 18" DeWalt planer.
Inner10 is offline
The Following User Says Thank You to Inner10 For This Useful Post:
VinylHanger (12-22-2013)
Old 12-21-2013, 05:10 PM   #23
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I'm with Brian on this one.. Some things are worth trimming the bottom line a little bit for. Like time, expertise, warranty, etc..
I have a job bid out for adding a commercial overhead door. I could source the door and do the install myself, or sub that part to an overhead door company and let them handle any warranty issues.
I'm going with the latter
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
PrestigeR&D (12-21-2013)
Old 12-21-2013, 05:32 PM   #24
Inner10's Avatar
It's different when there is a big-ass coil spring involved.
Inner10 is offline
Old 12-21-2013, 05:52 PM   #25
rrk's Avatar
Rewards Points: 3,452
I have seen about 8-10 $10k doors, if something is wrong with them they usually don't get fixed they get replaced. If a panel cracks they want the whole door replaced, not just the panel to be replaced or crack to be glued.
The risk of a small problem causing a big headache is not worth the trouble. Too much money riding on 1 item.
rrk is online now
TimelessQuality (12-21-2013)
Old 12-21-2013, 05:52 PM   #26
Wood Craftsman
Arrow
It's not a Dewalt....ask Leo what I have........
This reminds me of the cabinets built on site topic........
Not ridiculing,...but that is no way to profit,...that is unless your shop is designed and built around pumping some serious material through your machinery,,,,,,,,
It's all about numbers......
Jeld- Wen,,,,,,,....forget it... did you look at the opulent doors from the hyperlink.....
Come on guys....
I would love to extrapolate on this but there is no way it is happening in this room......
B,
Old 12-21-2013, 05:59 PM   #27
Inner10's Avatar
B,
I was just trying to yank your chain...I'm sure you have some turn of the century monster in your shop.
Inner10 is offline
Old 12-21-2013, 06:04 PM   #28
Wood Craftsman
Arrow
Yes I do,.....they all. Have "BALL BEARINGS".., are green and most have OLIVER.tags.....
That should piss Darcy off ......
B,
Old 12-21-2013, 06:10 PM   #29
Inner10's Avatar
No flat belts and babbitt bearings?
Inner10 is offline
Old 12-21-2013, 06:12 PM   #30
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,744
I like oliver parts.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-21-2013, 06:32 PM   #31
Wood Craftsman
Arrow
Your a pimp as far as Oliver is concerned ........
B
Old 12-21-2013, 09:01 PM   #32
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
These guys are about 2 miles from my shop.
I have not done business with them but they are widely known, in this area at least, for making a very good door.
http://www.libertyvalleydoors.com/custom_doors.php
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
PrestigeR&D (12-22-2013)
Old 12-22-2013, 02:59 PM   #33
Wood Craftsman
Question
Thank you Guss,...
So,
What I would like to know is why some of you think it would be better to make it myself,- if I had the machinery.........
B,
Old 12-22-2013, 03:33 PM   #34
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
never heard of them... most of the doors i deal with are Peter Kohler doors. the occasional Norwood or Anderson
the only issue ive seen with the kohler doors were on a 42" solid cherry entry door,, issue being the guys at the plant didnt use the correct size drill bit to predrill for the hinge screws.. the door jamb split because of it. no one noticed it until well after it was installed because the door had side lights.. on high end doors we inspect them as they come off the truck for damage but no one picked up on it as we would have had to open the door before it was installed...
big wigs from the plant came and inspected it do to the high price tag on it. if memory serves correct they sent out a technician who could only inject epoxy into the cracked jamb and they gave the h.o a rebate
woodworkbykirk is offline
Old 12-22-2013, 03:39 PM   #35
Gus Dering's Avatar
Don't put me in that camp.
Unless you can build laminated stiles and rails and veneer them, why bother taking the conversation any further?
No way would I want the warranty issues involved with a solid wood entry door.
Its hard enough to make money building custom items once, impossible building the second one for free.
Old 12-22-2013, 04:03 PM   #36
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
Originally Posted by Gus Dering View Post
Don't put me in that camp. Unless you can build laminated stiles and rails and veneer them, why bother taking the conversation any further? No way would I want the warranty issues involved with a solid wood entry door. Its hard enough to make money building custom items once, impossible building the second one for free.
Very true.
NINZAN STUDIO is offline
Old 12-22-2013, 05:13 PM   #37
fugsly's Avatar
Trade: general
Rewards Points: 71
And what is so hard abiut that? Lamination takes some time, but at least you are giving a quality product, plus the 1/4 veneers we use are then grain matched, unlike so many production doors
fugsly is offline
Old 12-22-2013, 06:26 PM   #38
Wood Craftsman
Lightbulb
I know your intentions are well intended and I appreciate the input ,-but I think you may want to look at the hyperlink in my post.
B,
Old 12-23-2013, 03:13 PM   #39
Inner10's Avatar
Thank you Guss,...
So,
B,
Because I thought you were a wood worker...
Inner10 is offline
Old 12-23-2013, 03:27 PM   #40
Wood Craftsman
Arrow
I am, I am also a business man......
B,
Requirement for bedroom with separate entrance? CarpenterSFO NEC Discussion 2 04-24-2013 07:23 AM
Gate Entrance bfuller Masonry 7 04-12-2013 12:57 PM
Closing in Basement entrance. Questions Pheasant89 Masonry 3 08-28-2011 07:36 PM
Basement Entrance basement Masonry 2 05-13-2009 09:50 PM
Basement entrance rbsremodeling Excavation & Site Work 41 09-13-2008 12:14 PM
