Need Deck Estimate Input - Marketing & Sales - Contractor Talk
Old 03-28-2019, 07:23 PM   #1
creekguy's Avatar
Trade: REMODELING
Rewards Points: 12
im here in west central indiana ,iv got a deck estimate im working on for a 16'x22' two level ground deck all pt wood on a 10 degree slope,the material is approx. $2400 .20 mile drive one way and a STEEP drive way.iv got two laborers for $13 an hour and ill have to be there the whole time ,so im thinking $2400x3 =7125.00.should take about a week,and theres a couple weird tweeks i have to figure out but nothing major.
whats everyone think about my price?
creekguy is offline
Old 03-28-2019, 08:10 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 886
Re: Need Deck Estimate Input
$85,000
Big Johnson is offline
greg24k (03-31-2019)
Old 03-28-2019, 08:37 PM   #3
TheConstruct's Avatar
Rewards Points: 1,440
10 slope? Sounds like a two tier ramp.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
cedarboarder (03-30-2019)
Old 03-28-2019, 08:42 PM   #4
Amazing your material costs are that low. Off the top of my head I'd be 2 or 3 times that.
Old 03-28-2019, 08:53 PM   #5
VinylHanger's Avatar
Rewards Points: 11,668
You are going to work all week for 2 grand?
I mean, sure, I've done it many times, even less. But not on purpose.
VinylHanger is offline
The Following 6 Users Say Thank You to VinylHanger For This Useful Post:
B.Johnson (03-30-2019), Calidecks (04-01-2019), greg24k (03-31-2019), Justin Rhoades (08-13-2019), pathbuilder (03-29-2019), SmallTownGuy (04-02-2019)
Old 03-29-2019, 08:44 PM   #6
pathbuilder's Avatar
Rewards Points: 456
Don't forget permit fee, dump or dumpster fee, overhead for that week over 52 weeks, your own profit, contingencies on material, material waste, contingencies on labor, marketing materials for this job, extra time running to the yard, couple new blades, and putting extra $ into a reserve account for if/when next recession hits. Is that all covered in your price?
Sent from my Pixel 3 XL using Tapatalk
pathbuilder is offline
The Following User Says Thank You to pathbuilder For This Useful Post:
Old 03-29-2019, 09:07 PM   #7
hdavis's Avatar
Rewards Points: 2,156
Make sure you have the materials cost figured out. From there 2.6X materials and adjust up for contingencies.
Your 3X may be OK, no way I can call your contingencies
hdavis is online now
Old 03-30-2019, 09:02 AM   #8
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,114
In before anyone else .......
I'd go about tree fiddy.
Fishindude is offline
The Following 3 Users Say Thank You to Fishindude For This Useful Post:
hdavis (03-30-2019), pathbuilder (03-31-2019), SmallTownGuy (03-31-2019)
Old 03-30-2019, 11:03 AM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,012
So, you bid jobs by taking your material estimate, and tripling it?
Not a good way to bid.
Did you account for footings?
And are you a Contractor, or some kind of Service Provider?
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Old 03-30-2019, 11:26 AM   #10
hdavis's Avatar
I just wonder how in the world it takes 3 guys a week to do that. Nothing indicates it's complicated.
I could spend 2 weeks building that solo, but I'd be on the phone most of the time.
Old 03-30-2019, 02:21 PM   #11
Gumshoe's Avatar
Trade: Painter
Rewards Points: 128
You'll be bankrupt in 6 months with bottom-feeding prices like that.
Gumshoe is offline
Old 03-30-2019, 04:17 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,391
A 13$/hr tender would only see ~ minimum wage here in Iowa....on the check...
NO ONE will block tend for less then 15$/hr, the two handed get 18$+
Are you paying your help as sub-contractors?
How does the drive way angle effect deck/Patio cost? Hand carry everything into the work area?
Air nailed deck boards?
Fouthgeneration is offline
Old 03-30-2019, 04:45 PM   #13
Rewards Points: 886
The price should be somewhere between $350 and $85,000.
Old 03-30-2019, 05:43 PM   #14
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,360
I'll say I did a deck on a grade, not sure of the angle,...got my ass kicked...
Labor was 50-60% more than I figured.
Steve
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 03-30-2019, 07:11 PM   #15
hdavis's Avatar
Try this the other way around. 3 guys one week = 120hrs. $60 an hour gross. You provide materials for free.
Old 03-31-2019, 07:37 AM   #16
woodspike's Avatar
Rewards Points: 724
your gonna go bankrupt if you don`t just use your balls , and think about it , every time you bid.
walk thru your whole job , step at a time , how much just to excavate , and layout
how much just to set the posts in cement
how much to set your runners/joists/supports/
how much to install decking
your basically doing a lot of small jobs to complete the big job
if your not sure of your timing , if you trust one of your guys enough , talk with him , not about numbers , but say " ok. how long do you think you guys will take for the digging / the setting the posts/ the actual decking?
come on buddy , figure it out.
if something goes wrong , and it takes a couple days longer , will you still make a profit?
or would you end up behind the 8-ball?
you just don`t want to end up , where if it takes a day or 2 longer , your paying out of your own pocket.your just losing some profit , but still have some profit
woodspike is offline
The Following 2 Users Say Thank You to woodspike For This Useful Post:
hdavis (04-02-2019), SmallTownGuy (03-31-2019)
Old 03-31-2019, 08:05 AM   #17
General Contractor
greg24k's Avatar
Rewards Points: 8,478
"Tree Fiddy" pet SF you will never go wrong.
greg24k is offline
Old 04-01-2019, 12:30 AM   #18
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,048
Mike.
_______________
Calidecks is online now
Bull Trout (04-01-2019), greg24k (04-01-2019), Navigatorgt (08-17-2019)
Old 04-01-2019, 12:37 AM   #19
back doors to hell put in
Irishslave's Avatar
Rewards Points: 506
16'x22' is $11,264 minimum, no way I'd do a deck that big for 7k
Irishslave is offline
Old 04-01-2019, 12:40 AM   #20
GC/carpenter
Calidecks's Avatar
Of the top of my head that deck would cost close to 18k and that doesn't include any railing. Composite of course.
Mike.
_______________
Tiled deck pschieuer Construction 16 10-21-2015 03:16 PM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
Deck Fire greg24k General Discussion 8 10-10-2012 12:19 AM
