Snow Load Calculator - Architecture & Design - Contractor Talk
Old 12-28-2013, 10:09 PM   #1
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Finally finished up the snow load calculator. Moved it to this page:
http://design.medeek.com/resources/s..._calculator.pl
Give it a whirl and let me know what you think.
I wish there was an easy way to calculate the ground snow loads for a given location but unfortunately there is not.
medeek is offline
The Following 2 Users Say Thank You to medeek For This Useful Post:
jar546 (06-03-2014), Kent Whitten (12-28-2013)
Old 12-28-2013, 11:51 PM   #2
mski's Avatar
Trade: home improvements
Rewards Points: 502
Re: Snow Load Calculator
I put in the info, agree to the terms and click submit and it comes back I'm "forbidden to access page"
mski is offline
Old 12-29-2013, 07:52 AM   #3
We Put Poles In Holes
baerconstructio's Avatar
Trade: Post Frame Builder
Rewards Points: 325
I get wepage not available.
baerconstructio is offline
Old 12-29-2013, 08:02 AM   #4
Have Trowel, Do travel
brunothedog's Avatar
Trade: Artisan
Rewards Points: 1,188
this is what i learned:
First we must differentiate between fresh snow, old snow and compact (wet and watery) . The first has a weight ranging between 80 and 200 kg / cu m (cubic meter), the second between 200 and 500 kg / cu m, while the third can be up to 800 kg / cu m. The ice on the other hand is around 900 kg / cu m.
That said, how much they weigh, for example, 20 inches of new snow over an area of ​​one square meter? The calculation is simple: height in meters x specific gravity.
In our case, such as taking specific weight 100 kg / cubic meter, there will be 0.2 meters x 100 lbs = 20 kg (per square meter).
If we wanted to estimate the weight of 60 inches of old snow and wet, should be done for 0.6 meters 400 kg = 240 kg (always per sqm). Almost like having 3 adult men for every square meter. With this load, you're sure that your roof will remain firmly?
I used to love the days when you could look at an unattended bag on a train or bus and think to yourself...'Iím going to take that.'
brunothedog is offline
Old 12-29-2013, 12:49 PM   #5
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Fixed a small bug in the html formatting this morning. Try it now, tell me if you have any problems.
The intent of the snow load calculator is to give you the appropriate balanced and unbalanced snow load as per the ASCE 7-10. What is required is the ground snow load and some general information about your roof. It all pretty much follows a very simple algorithm set out in chapter 7 "Snow Loads".
medeek is offline
Old 12-29-2013, 09:41 PM   #6
mski's Avatar
Rewards Points: 502
Works now.
mski is offline
Old 01-06-2014, 12:19 PM   #7
medeek's Avatar
Trade: Engineer
Rewards Points: 262
For the State of Utah I've added this map:
http://design.medeek.com/resources/s...snowloads.html
medeek is offline
Old 01-09-2014, 03:25 PM   #8
medeek's Avatar
Trade: Engineer
Rewards Points: 262
For the State of Montana I've added an interactive map that acquires it data from the Snow Load Finder from the University of Montana:
medeek is offline
Old 01-15-2014, 11:15 AM   #9
TrulyNoble's Avatar
Trade: residential remodeling
Rewards Points: 14
This is pretty neat. Thanks. I just came on this site yesterday and the posts have been pretty interesting so far.
TrulyNoble is offline
Old 01-19-2014, 02:17 PM   #10
medeek's Avatar
Trade: Engineer
Rewards Points: 262
I've recently spent some time on looking at the snow load requirements of the ASCE 7-10 and the various state modifications to the IBC and IRC. Obviously this is a gargantuan task, to summarize all this data and present it in a usable fashion. I have managed to chip away at a few states that have standardized snow load data or equations. The latest state I've tabulated is New York State:
My map of the ASCE 7-10 ground snow loads is still unfinished, not because I cannot finish it but because I am currently waiting on a response back from the ASCE licensing division about the reproduction of the data presented in Fig. 7-1 (ground snow load map). Reproducing or displaying a scanned version of the map seems to be less of a concern that creating an accurate electronic version of the map that is much more useful to the general public and engineering community.
I am summarizing each States snow load requirements on this page:
As you can see I've only just started. Some states such as Colorado let the local jurisdictions (City and County) set their own snow load requirements so creating a map for the entire state is more difficult but not necessarily impossible. Some states such as Oregon have developed much more sophisticated online systems, I applaud their efforts.
medeek is offline
Old 01-22-2014, 11:49 PM   #11
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Oregon Snow Load map is up. This one, like the Montana Map, connects to the snow load database hosted by the SEAO. It also compares the retrieved value against the 20 psf snow load minimum as well as checks the modeled elevation against the actual site elevation and flags the user based on these checks.
The advantage to using this tool is that you don't need to know the lat. and long. off hand, just click on the map and it does the rest.
Also added in tile roof surface to the calculator by request from a California native.
medeek is offline
Old 02-06-2014, 02:27 AM   #12
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Just completed the Ground Snow Load Map tonight.
Digitizing it, so that it was accurate, took far longer than I had planned on but once I was underway I wasn't about to stop.
Note how most of the western US requires case studies, hence many of these states have their own snow load maps and research to back them up.
medeek is offline
Old 02-16-2014, 06:55 AM   #13
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Interestingly I had a company that manufacturers and installs solar panels contact me regarding the ASCE ground snow load map. They were wondering if there was a way so that their website could send an http request to the map with a latitude and longitude and have it kick back the snow load. Since the map is already in digital format you would not think this would be hard to do. So I got thinking about how I could build a program that given a certain lat and long would automatically click on the map and then fire back the elevation, snow load, etc...
The only problem is google maps implementation of the KML layer does not allow this transmittal of information. So I basically banged my head against the wall for almost 2 weeks trying to do the impossible. However, I was not ready to throw in the towel just yet. Since the KML data is just plain text, (coordinates) I thought there must be some way to analyze this data and determine if a given location is within a certain polygon and if it is then be able to assign that polygon description (ASCE snow load details) to a variable which is then delivered to the client. Turns out this is called the point in the polygon problem and it is well documented:
http://en.wikipedia.org/wiki/Point_in_polygon
So I was about to write an algorithm for ray casting which would have taken some time. Then I thought maybe someone else has done this before and sure enough I found a couple of good perl modules that handled this nicely and I narrowly avoided reinventing the wheel. Just a few lines of Perl later and I had managed to create a nice little API for the ASCE ground snow load data:
http://design.medeek.com/resources/medeekapi.html
medeek is offline
Old 02-27-2014, 02:26 AM   #14
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Just put up an interactive map for Basic ASCE and IRC wind speeds:
http://design.medeek.com/resources/w...indspeeds.html
If your designing a residential structure then the IRC 2012 value is the appropriate Basic Wind Speed.
medeek is offline
Old 03-29-2014, 08:36 PM   #15
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Vermont Ground Snow Loads Map is now complete:
This zone map defines ground snow loads by township and city boundaries and is derived from the zone map on page 48 of the 2012 Vermont Fire & Building Safety Code.
Vermont is a small state so the KML for this map was relatively easy to create.
medeek is offline
Old 04-02-2014, 06:22 AM   #16
Max00's Avatar
Trade: Flooring & Roofing
I went through your snow load calculator it works really well.Thanks for sharing....
Max00 is offline
Old 04-02-2014, 07:27 AM   #17
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Works great.
Good job..
jaydee is offline
Old 04-08-2014, 11:26 AM   #18
medeek's Avatar
Trade: Engineer
Rewards Points: 262
Currently working on the Idaho Ground Snow Load Map. This one employs isolines which give a normalized ground snow load which when multiplied by the elevation gives the ground snow load. Still a work in progress:
medeek is offline
Old 06-03-2014, 09:33 AM   #19
medeek's Avatar
Trade: Engineer
Rewards Points: 262
The snow load calculator has now been upgraded with a PDF report output, which is really nice for printing out hard copies.
I will probably do the same PDF report format for the wind, seismic and ground snow load maps as time allows.
medeek is offline
Old 06-03-2014, 12:56 PM   #20
Educator of Codes
jar546's Avatar
Trade: Construction Aficionado
Rewards Points: 164
Excellent job on this. Myself and a few other plan reviewers will put this through the paces to see if we can find any quirks in it. Very useful indeed.
Thank you!
"The more I learn, the more I realize just how much I don't know" "It's OK to eat some humble pie every know and then. It has what you need in nutrients"
jar546 is offline
Snow coming through roof vents pardyc Roofing 43 02-01-2013 04:33 PM
raised wall safety covers and snow POOLMANinCT Pool Construction & Enclosures 2 12-29-2008 08:11 PM
The pros running things in Illinois know how to deal with the snow. mickeyco Off Topic (Non Trade) 22 12-23-2008 01:40 AM
Snow shovels mdshunk Tools & Equipment 30 10-27-2008 04:10 PM
Load calculator PaulJ Electrical 1 03-31-2008 06:18 AM
