Sizing A Pole Light Base - Architecture & Design - Contractor Talk
Old 05-31-2012, 01:45 PM   #1
5.4Lariat's Avatar
Trade: General Maintenance
I have some existing 24' steel poles with a 9" bolt circle, customer has sent me some specs on 30' aluminum poles with a 9" bolt circle, is there a formula to determine the base size, while taking into consideration wind load and height? Bases are same bolt circle but with the taller pole I want to make sure my bases are sufficent.
Or if there is no formula can someone reccomend an Engineer in the DFW area that deals in this sort of calcs.
Tristan
*Electrical *Plumbing *HVAC/Refrigeration *Maintenance *Restoration *Power Washing
*Irrigation *Porter / Sweeper *Thermal Inspections
TACLB21374C * M-36648 * TECL19395
5.4Lariat is offline
Base Issue! Knighton Finish Carpentry 55 02-14-2012 06:35 PM
Ridge pole sizing bluebird5 Framing 7 03-01-2011 08:58 PM
power pole disconnect twodogsfab Electrical 26 05-03-2009 08:41 PM
Need a good base molding solution soon! HandyHails Finish Carpentry 16 03-17-2009 06:46 PM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
