Retractable Stairs - Architecture & Design - Contractor Talk
Retractable Stairs
Old 06-10-2019, 10:00 PM   #1
Smith87's Avatar
Trade: Construction, remodeling
Retractable Stairs
Ok call me crazy but I had a thought. I have a 13’ vaulted ceiling with 9’ walls then I have a 9’ceiling over my kitchen. Here is what I’m wanting to do. I really don’t want to have my stairs coming down in my living space. Is there anyway to stud my loft wall in and in the center have framed stairs that will lay down and then close flush? Drywall each side then clapboard the back of the stairs so it just looks like an accent wall. Any ideas would be greatly appreciated.
Smith87 is offline
Old 06-11-2019, 03:14 AM   #2
Bull Trout's Avatar
Rewards Points: 124
Re: Retractable Stairs
Yes
Bull Trout is offline
The Following User Says Thank You to Bull Trout For This Useful Post:
hdavis (06-11-2019)
Old 06-11-2019, 09:08 AM   #3
hdavis's Avatar
Rewards Points: 2,516
Not and comply with firecode if you're using it as living space.
hdavis is offline
Old 06-11-2019, 12:49 PM   #4
Smith87's Avatar
no just storage. Won’t be finished in
Smith87 is offline
Old 06-11-2019, 12:57 PM   #5
Smith87's Avatar
Not concerned with fire codes and what not. Issue I’m having is how to get them to fold down with out it binding or sticking at the bottom of my 2x6s and will a pulley system even lift them at the angle they will lay. 12’ long which puts me out about 2 1/2 to 3’ at the floor from where they will be attached at the top
Smith87 is offline
Old 06-13-2019, 09:33 PM   #6
Smith87's Avatar
Can’t find a hinge system for the kind of weight involved
Smith87 is offline
Old 06-13-2019, 10:09 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,405
Four one inch or 1.25" semi hemi bearings in cast iron arbors bolted to flat irons drill for structural screw, run a steel shaft through the four bearings..... Available at local Farm stores and better Hdw stores.
Use Garage door springs for counter balance and push button raising an lowering, Hang spring And winch pipe from reinforced rafters.
You could even install the safety laser across where the lower stair lands for accident reduction.
See access stairs to side ports/deck in large ships.
70 degree ship's ladder with stutter steps, three stringers, treads go 1/2 the way across.
Spiral stairs
Or Fire pole?
A ~1000 lb electric/hydraulic forklift mast with a man platform, ~30" x 48-60" home rolled "elevator"
ALWAYS plan from the stairs out when building any multistory building, silly man.
Fouthgeneration is offline
Old 06-13-2019, 10:47 PM   #8
Smith87's Avatar
Lol. I did. I have more than enough room for them. I just wanted something different. Unique. And I must say a section of wall that folds out to stairs is pretty unique. Even still with your ideas I don’t see how they will be hidden flush mount and then still fold out and down without coming into contact with the wall. Zero protrusion hinges would work but I just don’t feel comfortable letting them retain that kind of weight.
Smith87 is offline
Old 06-13-2019, 11:35 PM   #9
hdavis's Avatar
Sometimes you have to have custom hardware made.
hdavis is offline
Old 06-14-2019, 12:00 AM   #10
Trade: Masonry
The hinge point at Second floor level? that is where Rod through the top of the stair assembly goes, cables on lower stringer ends up to ceiling mounted Garage door counter spring(s) and cable winding drums.
To get your 80" top step head clearance, the top of the stairs has to be under the part of the loft with 6' 8" + vertical clearance.
The more "monkey" motion to hide the stairs, = more $$$ less reliable. IMHO.
You need a "landing" space at the bottom of the disappearing stairway too, realy cutting down on the places it can be hung in use if parallel the the rim joist of the loft.
A movable stair that just pushes up to vertical, would easiest with folding handrail, rollers at bottom riser, two wheel in a C channel from Second floor in use to +~6 feet when stored in plumb position? The ladder would block the stairway opening in the upstairs hand railing, when stored
Old 06-14-2019, 03:39 PM   #11
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,612
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
The Following 3 Users Say Thank You to Snobnd For This Useful Post:
KAP (09-05-2019), Pearce Services (01-04-2020), pinwheel (06-15-2019)
Old 06-14-2019, 05:48 PM   #12
Frank Castle's Avatar
Rewards Points: 438
Sno, that's somewhat like the one I built. Mine has less moving parts.
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 8 Users Say Thank You to Frank Castle For This Useful Post:
CPMKW (06-14-2019), Idothat (06-15-2019), KAP (09-05-2019), Pearce Services (01-04-2020), pinwheel (06-15-2019), Rio (06-15-2019), Sisyphus (09-07-2019), TheConstruct (11-24-2019)
Old 06-15-2019, 01:47 AM   #13
Smith87's Avatar
Nice stairs guys and they would work if I had to but I’m wanting to come out of the wall so I basically need twice as much degree of opening
Smith87 is offline
Old 06-15-2019, 04:44 AM   #14
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Guys gave you an idea of what they did.... use it and see if it will it work in your situation.
If you want something different and unique, it would have to be planned, designed and fabricated and that will cost you.
The information you provided I don't think anyone knows what you got there or what you have in mind other than a few ceiling heights.
Good luck
greg24k is offline
Old 06-15-2019, 07:08 AM   #15
rrk's Avatar
Rewards Points: 3,504
I guess not many remember Bessler Stairs
http://www.bessler.com/bessler-stair...0-attic-stairs
rrk is offline
Rio (06-15-2019)
Old 06-15-2019, 12:11 PM   #16
Smith87's Avatar
Good luck
a vertical wall mounted access “door”, that just lays out to become stairs that are covered with something like clapboard so it looks like just an accent wall when it is closed
Smith87 is offline
Old 06-15-2019, 12:17 PM   #17
Smith87's Avatar
I would post pictures of what I mean but they won’t upload
Smith87 is offline
The Following User Says Thank You to Smith87 For This Useful Post:
hdavis (06-15-2019)
Old 09-05-2019, 09:49 AM   #18
kigiin's Avatar
Trade: Handyman
Rewards Points: 2
Reminds me of stairs to an attic.
kigiin is offline
Old 10-05-2019, 11:36 PM   #19
Rewards Points: 438
Hey Smith87, you ever get this figured out?
Here's another I stumbled upon.
The Following 6 Users Say Thank You to Frank Castle For This Useful Post:
AustinDB (10-07-2019), B.Johnson (10-06-2019), mrcat (10-06-2019), Pearce Services (01-04-2020), Rio (10-06-2019), Sisyphus (10-06-2019)
Old 11-23-2019, 09:56 PM   #20
Steve Bosnick's Avatar
Trade: Elevator Service Contractor
Rewards Points: 4
What did you end up going with?
Steve Bosnick is offline
