Residential Sprinkler System Negating Fire Rated Partitions? - Architecture & Design - Contractor Talk
Old 07-13-2012, 10:45 PM   #1
Dogtown's Avatar
Trade: Electrician, remodeling
I have recently had a set of take-offs and a code review done by my architect in Pennsylvania. The building consists of two original units, separated by an 8" brick firewall. At some point, someone did a shoddy job of dividing one of the units into two new dwellings (probably in the early 1940s, judging by the 3/8" plaster on lath, not typical to original 7/8" plaster throughout.
My architect is specifying a sprinkler system throughout both units, so we don't have to make the existing partition fire rated. I've done the math, it is cheaper, IBC says it's kosher, but has anyone out there used this solution successfully?
Dogtown is offline
Old 07-14-2012, 05:53 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Residential Sprinkler System Negating Fire Rated Partitions?
What's the IBC code reference?
-John
slowsol is offline
Old 07-15-2012, 05:58 PM   #3
Dogtown's Avatar
I'm not sure yet, the architect just mentioned it as an option, but didn't give me the section reference.
Dogtown is offline
Old 07-15-2012, 09:25 PM   #4
Astrix's Avatar
Trade: Insurance Broker - Commercial Construction
Rewards Points: 666
I am not sure I understand what you mean by "using this solution successfully"? If permitted by code, and code is followed, then it would be a successful option.
Perhaps the attached document will be helpful to you.
BTW, the owner of the building will qualify for lower insurance rates if the building is sprinklered; on average between 2% to 5%, but sometimes as high as 10%.
File Type: pdf NMHC BC Update - 2009 IFC and Apt industry.pdf (120.9 KB, 1629 views)
Astrix is offline
Old 07-15-2012, 09:58 PM   #5
Dogtown's Avatar
Astrix,
Thanks very much for this link. This is very helpful! I think it will come down to making the sprinkler system strictly adhere to code. Awesome insight, I appreciate it !!
Dogtown is offline
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
Residential Fire Sprinkler Systems e21pilot Plumbing 0 10-29-2011 01:33 AM
OSHA acts to protect residential roofing workers Grumpy Roofing 20 04-29-2011 05:10 PM
Maryland DQI (Designated Qualified Individual) Services - Fire Sprinkler Contractors jrhelwig Contractor Licensing 0 07-11-2010 11:25 AM
fire system rbring New Member Introductions 1 06-11-2010 12:47 AM
