Load Transfer Help Requested - Architecture & Design - Contractor Talk
Old 09-05-2015, 08:59 AM   #1
glkirk's Avatar
Trade: General residential building contractor
Rewards Points: 161
Acting as a designer of a two story home on a crawl space, a question has come to mind.
I can't find anything in the IRC 2012 that address this.
In my experience the first floor perpendicular(center of home) walls have very seldom lined up with girder system at foundation.
Often I see where the second story perpendicular (center of home) walls will basically line up with the first floor walls. (I see where it states to not be off more than one member thickness in parallel walls).
The IRCR502.5(1) table, uses variables such as "Roof, ceiling and one clear floor span" etc. for girder spans.
But the floor joist tables do not differentiate that criteria.
Does anyone know why this doesn't seem to matter at the first floor level but very often are lined up at the second floor level?
Or, am I missing something?
Thanks,
Gary
glkirk is offline
Old 09-05-2015, 10:09 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,348
Re: Load Transfer Help Requested
I tried answering but gave up as I am just not understanding the question.
Sorry.
Andy.
ScipioAfricanus is online now
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
glkirk (09-07-2015), greg24k (09-05-2015)
Old 09-05-2015, 10:10 AM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
I was hoping that Andy would have the answer.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
glkirk (09-07-2015)
Old 09-05-2015, 10:13 AM   #4
Sorry.
Andy.
In the IRC, it appears that second story walls need to be aligned directly over first story walls, but first story walls don't need to be aligned directly over beams below the joists. Is that true, and why?
[I think, or thought, that was the question.]
- Bob
glkirk (09-07-2015)
Old 09-05-2015, 12:20 PM   #5
glkirk's Avatar
Rewards Points: 161
It appears that first and second story center walls USUALLY are stacked upon one another. Do you all agree?
It appears that these walls DON'T HAVE TO BE directly over a girder system. Do you all agree?
In Table R502.5(1)-it asks how many center and what kind of center walls are to be included? Do you all agree?
So my question, is: What governs wheather you have to stack walls and if you don't, what governs what size joists and/or other criteria?
I just never saw it in the IRC. Does anyone have any thoughts on this?
Thanks,
Gary
glkirk is offline
Old 09-05-2015, 02:57 PM   #6
kiteman's Avatar
Rewards Points: 16
Bearing walls stack on bearing walls/girders in my experience. Occasional spans on I joist are sufficient sometimes offset from bearing.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
The Following 2 Users Say Thank You to kiteman For This Useful Post:
glkirk (09-07-2015), Jaws (09-05-2015)
Old 09-05-2015, 03:04 PM   #7
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,126
In my experience they stack or they're engineered in new homes.
Half of all people are below average.
Golden view is online now
glkirk (09-07-2015)
Old 09-05-2015, 03:16 PM   #8
General Contractor
greg24k's Avatar
Rewards Points: 7,672
Read further down R602.3.3 Bearing studs.
greg24k is offline
glkirk (09-07-2015)
Old 09-05-2015, 03:22 PM   #9
edward trowelhands
Trade: Diplomat
I have the 2009 book but if you read the whole section it pretty much boils down to always line up bearing walls and girders. Specifically, R502.4 excerpt: Bearing partitions perpendicular to joists shall not be
offset from supporting girders, walls or partitions more than
the joist depth unless such joists are of sufficient size to carry
the additional load"
The Following 3 Users Say Thank You to Golden view For This Useful Post:
fjn (09-05-2015), glkirk (09-07-2015), mikeswoods (09-05-2015)
Old 09-05-2015, 04:39 PM   #10
fjn's Avatar
Trade: mason
Rewards Points: 9,668
That is the way I have interpreted the code for the last 41 years.
fjn is online now
glkirk (09-07-2015)
Old 09-05-2015, 04:44 PM   #11
edward trowelhands
Trade: Diplomat
Besides, common sense (maybe) and building science (definitely) tells us to line things up when you're using span tables that only account for regular live loads.
It's not that difficult to engineer things otherwise, as long as you do just that- engineer them.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
glkirk (09-07-2015), Rio (09-05-2015)
Old 09-08-2015, 12:24 PM   #12
glkirk's Avatar
Rewards Points: 161
Yes, R301.1, pretty much says: everything has to be lined up.
I think I got confused from looking an someone else’s plans where nothing lined up. Then I realized TJIs were being used.
I had never realized that using these new components that through calculations you can also put loads midspan. Along with many other things!
Learn something new every day
Thanks everyone!
glkirk is offline
Old 09-08-2015, 03:50 PM   #13
edward trowelhands
Trade: Diplomat
TGIs are not magic though. Your key word "through calculations" is important.
glkirk (09-13-2015)
Old 09-08-2015, 04:03 PM   #14
Eater of sins.
Thanks to the other posters I think I understand what the question is now and yes, you can off-set the bearing surface of one floor to another, even for braced wall lines.
Code does make allowances for this but your local Building Official may not.
Andy.
glkirk (09-13-2015), Golden view (09-08-2015)
Old 09-08-2015, 05:07 PM   #15
VinylHanger's Avatar
Rewards Points: 8,418
I was thinking about those 60s split levels with the cantilevered livingrooms that jut out about 2 feet on the front of the house. Those aren't lined up.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
glkirk (09-13-2015)
Old 09-08-2015, 05:28 PM   #16
glkirk's Avatar
Rewards Points: 161
Yes, but the IRC addresses cantilevers.
I really like the "Engineered” system because it will allow almost any floor plan imaginable.
And the lumber companies have engineers on staff to lay it out. I always thought only so plumbing doesn’t interfere, but now I see there can be a lot more to it.
glkirk is offline
Old 09-08-2015, 06:22 PM   #17
fjn's Avatar
Trade: mason
I was thinking of those my self. I would say that probably not all were built to code then and possibly most may not meet today's standards.
Here is a chart that weighs in on that topic.
http://publicecodes.cyberregs.com/ic...2_5_par017.htm
fjn is online now
The Following 2 Users Say Thank You to fjn For This Useful Post:
glkirk (09-13-2015), VinylHanger (09-08-2015)
Old 09-08-2015, 07:38 PM   #18
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,183
glkirk: Design from the roof down for structure, Why aren't the new beams lining up with the new walls above?
Design in some excess capacity, don't minimize every structural dimension.
At least you've reached the point of wisdom of knowing you don't know...
I'd suggest a couple of sophomore level engineering texts, and letting a pro review your plans for soundness.
Fouthgeneration is online now
The Following User Says Thank You to Fouthgeneration For This Useful Post:
glkirk (09-13-2015)
Old 09-08-2015, 09:37 PM   #19
glkirk's Avatar
Rewards Points: 161
I would be happy to let anyone see them. Just get me your email addy.
I am always open to constructive criticism.
glkirk is offline
Old 09-08-2015, 10:52 PM   #20
Eater of sins.
I would like to see them.
I will PM you.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
glkirk (09-13-2015)
Hand stack roofs in snow load areas Ninjaframer Framing 25 09-09-2015 11:54 AM
Load Question Roberts Ren Framing 5 09-28-2011 04:20 PM
Load calculation formula? PeterAC HVAC 1 06-19-2011 05:40 AM
In-wall timer load DesignerGuy Electrical 8 01-27-2009 12:08 AM
Load and Haul Crews needed in Texas. mcguirerc Help Wanted or Looking For Work 0 09-23-2008 04:41 PM
