Kitchen Ideas - Architecture & Design - Contractor Talk
Kitchen Ideas
Old 02-26-2017, 06:32 PM   #1
Tom M's Avatar
Rewards Points: 8,370
Kitchen Ideas
Looking for some options on a small split level kitchen layout. Looking to remove the non load bearing wall and add a slider off the back for starters.
Also looking to open a pass through door way by the stairs to open things up.
Its a really small space. Tried to get some ideas on the the internet but hard to compare. Need dining area some where.
Tom M is online now
Old 02-26-2017, 06:36 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 778
Re: Kitchen Ideas
cant open sketch
griz is online now
Robie (02-26-2017)
Old 02-26-2017, 07:00 PM   #3
Tom M's Avatar
Re: Kitchen Ideas
ok PDF
Tom M is online now
Old 02-26-2017, 07:49 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,093
Re: Kitchen Ideas
peninsula to replace non-loadbearing
MarkJames is online now
Old 02-26-2017, 07:59 PM   #5
Tom M's Avatar
Re: Kitchen Ideas
He wants a nook and a dishwasher too... not enough wall space.
Heres an improvement as far as Im concerned.
Tom M is online now
Old 02-26-2017, 08:14 PM   #6
MarkJames's Avatar
Re: Kitchen Ideas
Try something with a peninsula and no pass-through. It might feel open that way, and also give you room for the stuff a small kitchen needs. I just did a small kitchen like that (no pics, sorry).
Edit: maybe they need the stair continuity...ok, forget it.
Old 02-26-2017, 08:41 PM   #7
Tom M's Avatar
Re: Kitchen Ideas
He wanted an open penisula but I think he needs the upper cabinet space more and any kind of stool in front of the penisula kills the dining area.
Tom M is online now
Old 02-26-2017, 09:04 PM   #8
MarkJames's Avatar
Re: Kitchen Ideas
I wish I had my pics. I had an issue with similar tight dining area, but we did a peninsula (countertop) that didn't project into the room more than a foot. No stools in the plan, standard height. Wall cabs went on the wall where you want to do the pass-through. I faced a 36B toward the dining room for added storage. fwiw.
Old 02-26-2017, 09:14 PM   #9
Tom M's Avatar
Re: Kitchen Ideas
I could make the cabinet on the side of the fridge open on top, I can close the fridge with a panel. I may slide the sink to the corner to and swap it with the proposed DW. I hate blind corners.
I also think opening the wall by the stair is a must, the house doesnt flow.
Tom M is online now
MarkJames (02-26-2017)
Old 02-26-2017, 09:45 PM   #10
tjbnwi's Avatar
Rewards Points: 2,100
Re: Kitchen Ideas
If your going to do a corner sink you have to decide a butterfly sink or a simple rectangular sink. Make sure you size the cabinet properly. A butterfly will fit in a 36x36, a rectangle needs 42". Move the dishwasher 9" from the sink cab.
Put the refrigerator next to the stairs down.
Remove non-load wall completely, add peninsula from door wall into the kitchen. This will give you a U shaped kitchen with counter space and a place to eat at the peninsula. The additional base cabinets negate the need for more uppers.
tjbnwi is online now
Old 02-26-2017, 10:05 PM   #11
Tom M's Avatar
Re: Kitchen Ideas
Are you thinking penisula by the stove wall?
Tom M is online now
Old 02-26-2017, 11:00 PM   #12
tjbnwi's Avatar
Re: Kitchen Ideas
Yes. Do a slide-in.
Old 02-26-2017, 11:06 PM   #13
Tom M's Avatar
Re: Kitchen Ideas
That would rob space from that dinning room though.....Hmmmm
I will mess with it tomorrow some more
Tom M is online now
Old 02-26-2017, 11:09 PM   #14
tjbnwi's Avatar
Re: Kitchen Ideas
You can the room by removing the non load wall.
Old 02-26-2017, 11:50 PM   #15
KAP's Avatar
Trade: Custom
Rewards Points: 37,020
Re: Kitchen Ideas
There's a few different options... Are you working with stock cabs at 3" increments or do you have size flexibility?
KAP is offline
Old 02-27-2017, 07:35 AM   #16
Tom M's Avatar
Re: Kitchen Ideas
Of course but as you know there is a certain amount of space needed to slide a chair out from a table. A peninsula projecting less than 3 ft may not be worth it. Although they look so nice. Maybe I will take my option to a designer to consult with them.
Removing the majority of that wall is going to open it up for sure.
@kap stock would be the goal but not glued to it. It would be stupid to renovate then skimp in a place that could have an impact.
Tom M is online now
Old 02-27-2017, 08:25 AM   #17
tjbnwi's Avatar
Re: Kitchen Ideas
If you place the peninsula at the end of the cabinet bank it leaves you 7'2" to the wall. A 30" peninsula would be a great benefit. Increases counter space by 6 square feet.
Slide the table towards the "dropped beam" a little to give a more open feel. 4x4 square pub height table, place it on a diagonal with the cover facing the patio door lined up with the end of the peninsula, shifted towards the kitchen. Rectangular table biased window wall to kitchen, placed away from the peninsula.
Once the wall is gone endless possibilities.
Old 02-27-2017, 08:43 AM   #18
Tom M's Avatar
Re: Kitchen Ideas
Are you saying like this Tom?
Tom M is online now
Old 02-27-2017, 08:49 AM   #19
KAP's Avatar
Trade: Custom
Re: Kitchen Ideas
What is the actual measure from the left corner to the stair wall?
Are they open moving the window?
After you answer those, give me a little bit and I'll post some ideas...
KAP is offline
Old 02-27-2017, 09:10 AM   #20
Tom M's Avatar
Re: Kitchen Ideas
85" and relocating the window or sink was not in the plans specifically
Tom M is online now
New Kitchen and Bath designer out of Ocean City, MD saying hi! KitchenScapes New Member Introductions 9 03-19-2013 11:26 AM
Ideas on for setting cap Captainsls Masonry 15 05-10-2012 09:43 PM
Fresh Kitchen Bartop Ideas fullerbuilt Architecture & Design 9 02-23-2012 10:55 AM
Kitchen CAD Service CB78 Marketing & Sales 5 02-04-2012 05:11 AM
Ideas? TBFGhost Finish Carpentry 25 02-14-2009 01:38 PM
