Help With Sketchup 17 - Architecture & Design - Contractor Talk
Old 04-03-2018, 08:20 PM   #1
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 212
So I've been using SU 15 for a couple years, use it all the time to do a simple post layout for decks and pole barns. Like this:
Attachment 444890
To get the pole locations, I've been simply drawing a line along the perimeter line, and a little "bump" appears that then represents my pole, which I can then dimension to, and see where windows and doors should go, so on and so forth.
I just got a new PC, so decided I'd get SU 17, and all seemed cool, until I went to create a layout for a new barn. HORRORS!!! I can't see my little "bump" when I drew a line! The line is there, because I can dimension to it with the dimension tool, I just can't SEE it which is going to be a major pain.
If I open one of my old layouts with SU17, I can make new lines along the existing lines, and they show up just fine, so I'm guessing some setting or something is different, but I've been messing with it for an hour and can't figure it out.
Any suggestions?
Thanks
Paul
mrcat is online now
Old 04-03-2018, 08:37 PM   #2
mrcat's Avatar
Rewards Points: 212
Re: Help With Sketchup 17
"Clears throat" I figured it out. I knew I would as soon as I asked for help, that's how it always goes.
It's in styles, I had to turn endpoints on.
mrcat is online now
The Following User Says Thank You to mrcat For This Useful Post:
Rio (04-04-2018)
Designing With Sketchup CharlieDelta General Discussion 7 12-13-2016 07:47 AM
Sketchup + layout for residential home drawings. JT Wood Drafting & CAD Forum 13 02-12-2014 05:03 PM
Cutlist Plus Fx and Cutlist 4.1.1 Sketchup plugin CENTERLINE MV Technology 6 05-05-2013 09:42 PM
Sketchup help carpenter uk Technology 1 01-31-2013 06:46 PM
Sweet sketchup keyboard BCConstruction Technology 14 06-08-2012 12:51 PM
