Garage - Rafters Upgrade - Architecture & Design - Contractor Talk
Old 10-02-2010, 05:39 PM   #1
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
I had a customer I did a project for ask me about her garage. You can see in the pictures and from the measurements most of the details. It has 2 x 6 - 24OC Rafters with no collar ties. One side is bearing on an exterior wall, one side is lag screwed into the Roof Trusses. She wants to make it walkable with more storage and a attic ladder. Two engineers told her its not possible because there is not bearing wall/support on both sides. Can't be done. I am thinking they are wrong but do they know something I don't. Any ideas how you would do it. I have a few idears but engineers are smarter than the rest of us.
Garage - Rafters Upgrade-ramlin-garage.jpg   Garage - Rafters Upgrade-img_0011s.jpg
Keeyter is offline
Old 10-02-2010, 05:47 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 211
Re: Garage - Rafters Upgrade
Possible? Yes. Economically feasible? Probably not. That roof in my opinion is engineered to the minimum already, without any added loads.
Easy Gibson
Warren is offline
Old 10-02-2010, 05:53 PM   #3
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
festerized is offline
Old 10-02-2010, 06:08 PM   #4
Keeyter's Avatar
Rewards Points: 851
Originally Posted by festerized View Post
That was my initial suggestion, she wants a plank ceiling to the garage so she didn't like the idea at first. I told her we could box it out and false box to add symmetry.
Oh I forgot the depth the other direction is 25' Currently the Rafters up there are 20'4" which is an odd size.
Keeyter is offline
Old 10-02-2010, 06:13 PM   #5
Geometrist
Warren's Avatar
Rewards Points: 211
Why is that an odd size?
Easy Gibson
Warren is offline
Old 10-02-2010, 06:14 PM   #6
David Festa
festerized's Avatar
It can be done but you have to remove & replace the rafters.
The engineer will probably increase rafter size, spacing & pitch, not to mention I would do a post & beam ridge like this one
Old 10-02-2010, 06:20 PM   #7
Keeyter's Avatar
Rewards Points: 851
Cost effective buying larger 2 x's for the extra couple inches.
Keeyter is offline
Old 10-02-2010, 06:34 PM   #8
David Festa
festerized's Avatar
The alternative is rip the whole thing down and start over.
If it was my project I would use 1 x 11 7/8 micro lambs for rafters, 3 x 14 post & beam ridge and install liners like these under each rafter/collar tie connection.
Old 10-02-2010, 06:36 PM   #9
David Festa
festerized's Avatar
FYI I posted the wrong pic, but the concept is the same. On a steeper pitch you can install liners under each collar tie
Old 10-02-2010, 06:37 PM   #10
Geometrist
Warren's Avatar
Rewards Points: 211
Which also means replacing the garage door header as well. If I am going that far,I might look into attic trusses. Like I said before, anything can be done with unlimited funds, but I bet that's not the case here.
Easy Gibson
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
festerized (10-02-2010)
Old 10-02-2010, 06:51 PM   #11
Keeyter's Avatar
Rewards Points: 851
Your saying just leave it, add the liners, which I am assuming is the structural equivalent to sistering. I was intending to use 14" Lams. The Roof is already 16OC but not what is gonna be the ceiling/attic floor. They "wanted" to be able to throw patio furniture and grill and such up there.
Garage - Rafters Upgrade-img_0001s.jpg   Garage - Rafters Upgrade-img_0006s.jpg
Keeyter is offline
Old 10-02-2010, 06:54 PM   #12
David Festa
festerized's Avatar
No,
Im saying remove rafters and start over. But this time ad liners. It still has to be engineered.
As Warren suggested it would be cost effective to use trusses
Old 10-02-2010, 07:02 PM   #13
Keeyter's Avatar
Rewards Points: 851
No,
Yet another reason for me to stay away from structural jobs and stick to my interior finish work. I knew it wasn't gonna be a quick, easy, or cheap fix, but i was hoping to get by with a beam to transfer the load.
Keeyter is offline
Old 10-02-2010, 07:09 PM   #14
David Festa
festerized's Avatar
In the end its worth it
Garage - Rafters Upgrade-dscf1839.jpg   Garage - Rafters Upgrade-peter-sykes-day-1-001.jpg   Garage - Rafters Upgrade-peter-sykes-day-2-008.jpg
Old 10-02-2010, 07:20 PM   #15
Geometrist
Warren's Avatar
Rewards Points: 211
We recently did a job in which we almost totally re did a detached garage. The slab was good, the door was good, but beyond that not much else. The rear wall had settled and was also short like in the posters pic, the side walls were wavy. We sistered studs to make all the walls the same height, pulled off all the siding and roofing, and installed new trusses. We were able to leave the door on during the whole process. He probably spent almost as much as for a new garage, but he had no choice other than to tear it all down.
These are the before pics. Sadly I have no after pics but it did turn out nice.
Garage - Rafters Upgrade-123109-035.jpg   Garage - Rafters Upgrade-123109-037.jpg   Garage - Rafters Upgrade-123109-041.jpg
Easy Gibson
Warren is offline
Old 10-02-2010, 09:15 PM   #16
Keeyter's Avatar
Rewards Points: 851
Thanks for your input gents! I do appreciate it, the customer may not like the outcome - but hey. Thanks Again
Keeyter is offline
Old 10-12-2010, 10:37 PM   #17
Keeyter's Avatar
Rewards Points: 851
Engineer okay'd the current roof with three 25' Micros, Left-Center-Right. I think that may be overkill, but hey now i can frame it with 2 x 4's instead of 12's
Keeyter is offline
Old 12-07-2010, 10:06 PM   #18
Keeyter's Avatar
Rewards Points: 851
Don't let the lifts fool you, I threw this bad boy on my shoulder
Garage - Rafters Upgrade-img_0077.jpg   Garage - Rafters Upgrade-img_0081.jpg   Garage - Rafters Upgrade-img_00878.jpg
Keeyter is offline
Old 12-07-2010, 10:14 PM   #19
Keeyter's Avatar
Rewards Points: 851
Sprayed texture, Painted, Epoxy on Floor, and still to come, TV's Cabients, Work Bench
Its a garage by the way.
Garage - Rafters Upgrade-img_0089.jpg   Garage - Rafters Upgrade-img_0105.jpg   Garage - Rafters Upgrade-img_0110.jpg
Keeyter is offline
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
prestressed concrete for garage floor with basement below shopman Masonry 41 08-27-2010 02:32 PM
Garage problems.... nwksremodeler Remodeling 29 05-12-2010 02:55 PM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 11:33 AM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
