Construction Math For Dummies - Page 8 - Architecture & Design - Contractor Talk
Old 09-28-2019, 10:07 AM   #141
hdavis's Avatar
Rewards Points: 268
Re: Construction Math For Dummies
The basic issues are getting moisture out of the structure (Showers, cooking, cleaning, etc.) and preventing condensation in the roof structure. I don't know your climate, but SLSTech has good info on his website, or you could PM.
Which opens up a discussion of HVAC and how airtight this will be....
hdavis is offline
Old 09-28-2019, 10:13 AM   #142
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
Exactly.
Time to get into this deep.
Been thinking about it.
2 fireplaces.
Range hood.
Pressure balancing....
EERV.....
Less concerned about internal moisture.
My main issue would be condensation.
SLS was exactly who I had in mind.
Buildingscience has some great stuff on the topic too.
BlueRidgeGreen is offline
Old 09-28-2019, 10:25 AM   #143
Trade: Craftsman
Rewards Points: 526
https://www.buildingscience.com/docu...r-all-climates
Old 09-28-2019, 11:39 AM   #144
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Originally Posted by BlueRidgeGreen View Post
Brings up another question.....
I had planned on spray foam for the entire roof profile.
Trying to save some money, and realizing I have plenty of space.....I am considering just a flash coat of spray foam and then like 16” of fiberglass.
What are my issues with a non-vented roof?
(Standing seam over full water and ice...)
Can I get away with only an inch or two of closed cell?
I probably wouldn't. Could flash with 2" off CC and then build to R value with OC for 1/2 the price after that. Or vent it.
EricBrancard is offline
Old 09-28-2019, 11:55 AM   #145
hdavis's Avatar
Rewards Points: 268
Exactly.
2 fireplaces.
Range hood.
EERV.....
You already know the ventilator takes care of the interior moisture, or is supposed to. I have experience with up here, Texas, but not Virginia, and none with ventilator based control.
I do know everything can be great, and if someone compulsively mops the floor there can be problems....
hdavis is offline
Old 09-28-2019, 06:03 PM   #146
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,941
Heat gain and loss wise you have ~475' of ~10' high walls, If built on a Square plan would yeild a 13,000 sq. ft. home....
I can't see just one ERV giving good service unless all the moisture sources are near each other.
This might be a good place for the use of whole room blown in expanding foam to seal missed holes/leaks in the air barrier, see JLC article.
Your Hvac person needs a sharp pencil, several mini-splits like an old ranch style motel? maybe a whole home forced air system for filtering and temperature leveling as the Sun beats down on thousands of sq. ft of walls?
Definitely use foil faced insulation on any sun exposed walls.
I hope there is a utility tunnel under the hallway for MEP . Hind sight is kicking in again...
No one worried about energy use or waste would ever build something of this shape where heating and cooling is required.... so expecting "normal" energy consumption is insane in my opinion, At some point the monthly savings won't ever cover the future value of the funds spent to lower it to a "normal" range for this size of home, Sq. Ft. wise.
You can teach a Bear to Dance, but it will never dance well.
It looks like a well built Bear though....
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
BlueRidgeGreen (09-28-2019)
Old 09-28-2019, 07:18 PM   #147
Trade: Craftsman
Rewards Points: 526
I have a nice conditioned crawl for everything.
6’ section for the HVAC units....
Minimum of 3’6” throughout.
Opening up two (or more) hatches into the crawl at the central hall for ease of MEP rough in.
There was no HVAC engineering.
I have a guy who is exceptional, but I’m getting pushback from the Architect.
My guy wants one central multiple zoned forced air system and mini splits serving the furthest ends.
Budget....
Looks like this will be another corner cut.
(They throw money at the “art”, but want to economize on the practical stuff.
Driven by the (lead) Architect. )
Have I told you guys about the axonometric “sunshades” (that don’t really shade anything) that I’m trying to axe in favor of more efficient HVAC ?
It is what it is.
I had my HVAC guy meet with the client and I before the Archys arrived.
Best I can do.
If he wants to follow them down that path despite my objections.....
I keep cashing checks and nudging the ball in the right direction when I can.
I appreciate your thoughts man.
Keep em coming.
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Fouthgeneration (09-28-2019)
Old 09-28-2019, 07:41 PM   #148
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Flash and batt works as long as it is thick enough to get the dew point in the foam layer. I’m not sure what zone you are in. Here in Massachusetts I did 3-4” of closed cell and the rest dense pack cellulose for my hot roof.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Old 09-28-2019, 07:49 PM   #149
Box Builder
Rewards Points: 6
Did you guys do any air sealing during the framing phase? Acoustical sealant, taping, gaskets etc? Do you have a goal ACH#? An ERV is a good way of idea if it is a fairly tight house. A fireplace in any kind of newer airtight building is just a bad idea in my opinion though.
Old 09-28-2019, 08:40 PM   #150
hdavis's Avatar
Rewards Points: 268
Fireplaces in old houses are a bad idea, nobody needs that loss of conditioned air 24/7/365.
Airtight stoves are pretty awesome.....
hdavis is offline
Old 09-28-2019, 08:58 PM   #151
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 14
And an oxymoron.
But yes, worlds better than a fireplace for more than one reason.
I abhor the thought of a house so tightly built that you need machinery to keep from suffocating. Sheesh.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
griz (09-28-2019), hdavis (09-29-2019)
Old 09-28-2019, 09:00 PM   #152
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Originally Posted by Tinstaafl View Post
And an oxymoron.
sorta like living in a refrigerator...
griz is offline
Tinstaafl (09-28-2019)
Old 09-28-2019, 09:06 PM   #153
Rewards Points: 986
And an oxymoron.
I have to remember to close my exterior doors with a lot less force if there’s a window open in my house. It’s almost like having one toilet in the house without a soft close seat and forgetting that it’s that one when you close it.
Old 09-28-2019, 09:15 PM   #154
Trade: Masonry
Haven't built a fireplace on my own with out "outside" air feed pipe ever...
add a chimney pot top spring loaded damper to tighten up when cold...
and always install a Natural Gas(L.P.) pipe for a gas log/ starter. and you can use it to keep the house from frost damage when the power is out for a week or more.....
Where do you cook the neighbors post zombie apocalypse, if you don't have a working fireplace?
My eyes got tired walking the 125' hallway... did you lose any weight walking around the large footprint of home?
The introduction of chimneys into the peasant's huts and bungalows lengthened their dwellers lifetimes by keeping most of the smoke out their lungs and G.I. tracts, the downside being the home was now more vermin friendly and thatched roofs didn't last as many years with out the daily smoke treatments....
Old 09-29-2019, 08:27 AM   #155
Box Builder
Rewards Points: 6
IMO any kind of wood burning device in a modern home should be positioned so it’s combustion air is outside the building envelope or at least not in conditioned space.
Old 09-29-2019, 08:41 AM   #156
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 22
Really depends on your climate zone. We have done 3" of closed cell to the roof deck before swicthing to fiberglass. Important that it is unfaced. You want the dew point to happen in the foam. Foam guy needs to know his stuff. Shouldn't build up a lot of thicknedd all at once.
Sent from my SM-T380 using Tapatalk
overanalyze is online now
BlueRidgeGreen (09-29-2019)
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Comprehensive list of construction guides elementbldrs General Discussion 2 08-04-2013 11:05 AM
Deck Construction @ Winery: Review Our Plans? dutchswan General Discussion 14 05-23-2013 12:14 PM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
Top 10 Construction Lien Errors Ed the Roofer Business 7 08-19-2011 10:51 AM
