Construction Math For Dummies - Page 3 - Architecture & Design - Contractor Talk
Old 03-11-2019, 09:18 PM   #41
Texas Wax's Avatar
Rewards Points: 2,168
Re: Construction Math For Dummies
Originally Posted by Fouthgeneration View Post
T-Wax @#34 Looks like you're 95% there, But, the roof center(ridge) is aways from the line you drew... and the Roof is "rolled" over the ridge area ~ 2 feet, to add to the cost of the roof framing on every one...
Rounded ridge, those dashed lines are what I took as structural ridge beams. Still no matter geometry-math works the same. Just need to frame the round in between-above the structural beams.
Ain't my project. I'll let BlueRidgeGreen call me an idiot or understand where I'm coming from.
I used a construction master calculator once, pissed me off. Just used regular calculator that had sq root function and some quick sketches ... So it's fun once in a while to dust off and stretch the roof figuring-cutting brain cells.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 2 Users Say Thank You to Texas Wax For This Useful Post:
BlueRidgeGreen (03-12-2019), Fouthgeneration (03-11-2019)
Old 03-12-2019, 10:18 AM   #42
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
You are correct Sir.
Rounded ridge.....
LVL's....
BlueRidgeGreen is offline
Old 03-12-2019, 12:25 PM   #43
hdavis's Avatar
Rewards Points: 2,182
3/8" ply for the curve. That should be plenty strong.
hdavis is online now
Old 03-12-2019, 01:51 PM   #44
Trade: Craftsman
Rewards Points: 526
Doubled....it sure will be.
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
hdavis (03-12-2019)
Old 03-12-2019, 07:33 PM   #45
hdavis's Avatar
Doubled? I've made sail boats with 1/4" ply and longer spans between supports, no problem.
I didn't catch that it was doubled..
Edit: Upgrade from plan?
Old 03-14-2019, 04:26 AM   #46
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
I'd lap splice the roof rafters (2 x 10s or 12s ), then cut away the radius needed, a high cross tie? or ridge board in the center, exposed? maybe a timber?
Thoereically you could use the cut offs to make the inside ceiling peak radiuses.
fewer pieces? maybe a extra short curved rafter under the curved plywood to "suck" it down between rafters
No venting on a tar paper shingled roof?
Can you warranty that curved/flat surface?
I don't like near zero overhangs with supertight homes, where does the wet air from behind the walls' Rainscreens get to daylight?
Fouthgeneration is offline
Old 06-28-2019, 04:10 PM   #47
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:11 PM   #48
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:12 PM   #49
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:12 PM   #50
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:13 PM   #51
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:14 PM   #52
Trade: Craftsman
Rewards Points: 526
Old 06-28-2019, 04:16 PM   #53
Trade: Craftsman
Rewards Points: 526
SmallTownGuy (06-29-2019)
Old 06-28-2019, 05:22 PM   #54
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Very,very nice !
fjn is offline
BlueRidgeGreen (06-28-2019)
Old 06-28-2019, 06:17 PM   #55
Trade: Craftsman
Rewards Points: 526
Originally Posted by fjn View Post
Very,very nice !
Thanks Fjn
We’re getting there.
I’ll caption the videos soon and try to give the highlights of each phase.
(Like the elevations on the site plan being off 9’, causing me to have to cut the top of the hillside off....)
Digging into the most complicated mathematics right now with wall framing.
Cheers...
The Following 2 Users Say Thank You to BlueRidgeGreen For This Useful Post:
fjn (06-28-2019), hdavis (06-28-2019)
Old 06-28-2019, 07:03 PM   #56
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
That’s a house ? I thought it was some kind of retail space.
Definitely not a cookie cutter house
Looking forward to updates on the progress of this one
Molon Labe —— King Leonidas of Sparta
Freedom of choice is what you got
Freedom from choice is what you want—— Devo
Idothat is offline
The Following 2 Users Say Thank You to Idothat For This Useful Post:
BlueRidgeGreen (06-28-2019), Fouthgeneration (06-28-2019)
Old 06-28-2019, 08:57 PM   #57
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,228
Looking good! Looks like a lot of fun as well.
Mike.
_______________
Calidecks is offline
Idothat (06-28-2019)
Old 06-28-2019, 11:02 PM   #58
hdavis's Avatar
Great work as usual!
On the left, it looks like you are setting and bracing corner studs. Are you taking a chalk line corner to corner, and using that to stand studs to mark in place, or did you come up with a calculated cut list? Or maybe something different?
Old 06-29-2019, 02:20 AM   #59
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 506
That some kind of weird looking building.
Andy.
Construction Math for Dummies-untitled-1.jpg   Construction Math for Dummies-untitled-2.jpg   Construction Math for Dummies-untitled-3.jpg   Construction Math for Dummies-untitled-4.jpg
ScipioAfricanus is online now
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
Fouthgeneration (06-29-2019), hdavis (06-29-2019)
Old 06-29-2019, 06:28 AM   #60
Trade: Craftsman
Rewards Points: 526
Andy.
That’s pretty close Andy.
ScipioAfricanus (06-29-2019)
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Comprehensive list of construction guides elementbldrs General Discussion 2 08-04-2013 11:05 AM
Deck Construction @ Winery: Review Our Plans? dutchswan General Discussion 14 05-23-2013 12:14 PM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
Top 10 Construction Lien Errors Ed the Roofer Business 7 08-19-2011 10:51 AM
