Can I Substitute CVG For Select Structural? - Architecture & Design - Contractor Talk
Unread 02-25-2019, 11:10 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 702
If a beam calc calls for a Select Structural doug fir beam (in my case 4x10) can I substitute a CVG grade? CVG is not grade stamped, but I think without a doubt it's superior to select structural - having zero knots, and tighter grain.
Is there any documentation or code reference that confirms this?
Golden view is offline
Unread 02-25-2019, 11:27 PM   #2
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
Re: Can I Substitute CVG For Select Structural?
I think you'd have to get it graded if your inspector is an @ss
jhark123 is offline
The Following 2 Users Say Thank You to jhark123 For This Useful Post:
Calidecks (02-27-2019), griz (02-28-2019)
Unread 02-25-2019, 11:28 PM   #3
jhark123's Avatar
BTW wouldn't a glulam be cheaper than a cvg beam?
jhark123 is offline
Unread 02-25-2019, 11:43 PM   #4
diplomat
Rewards Points: 702
Yes, much cheaper. Also cheaper than select structural.
Unread 02-26-2019, 12:19 AM   #5
jhark123's Avatar
This has glulam to select struct. substitution tables: https://rosboro.com/wp-content/uploa...-or-Lumber.pdf
jhark123 is offline
Unread 02-26-2019, 12:34 AM   #6
diplomat
Rewards Points: 702
Just to be clear, I don't want a glulam. I want the look of CVG fir. So I calced it with SS assuming that was closest. #1 isn't enough.
Unread 02-26-2019, 12:46 AM   #7
diplomat
Rewards Points: 702
Honestly, I think my supplier doesn't know what he's talking about. I don't think he is really quoting me CVG 4x10.
Unread 02-26-2019, 02:30 AM   #8
hdavis's Avatar
Rewards Points: 2,152
There is no documentation or code reference that would allow it that I know of.
hdavis is online now
Golden view (02-26-2019)
Unread 02-26-2019, 06:39 PM   #9
Talking Head
EthanB's Avatar
Rewards Points: 390
Select Structural and glulams aren't apples to apples but a premium grade doug fir glulam with clear wood inserts is going to cost a lot more. In your area getting a 4x10 select struct should be a piece of cake. We go through trailer loads of it and it all comes from your neck of the woods. I've never seen doug fir specified as CVG.
Planer.....
EthanB is offline
Unread 02-26-2019, 07:19 PM   #10
diplomat
Rewards Points: 702
Interesting. Maybe they send it all your way. The 4x10 is the difficult piece of the puzzle.
And all high end fir trim here is CVG fir. But seldom timbers.
Here's what I have:
Glulam: $70
#1 fir: $75
C&btr: $175
#1 fir doesn't quite calc but ss does easily and is very close to the glulam.
Unread 02-26-2019, 08:02 PM   #11
hdavis's Avatar
Some mill out there must sell ss cvg.
Unread 02-26-2019, 08:14 PM   #12
diplomat
Rewards Points: 702
I'm sure. I need to find an architectural timber supplier. I'm kind of just surprised my good lumber yard can't figure it out. My rep is usually amazing.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Bull Trout (03-12-2019), hdavis (02-26-2019)
Unread 02-26-2019, 08:17 PM   #13
hdavis's Avatar
Just looking around, bear creek lumber in washington may have something under ss, they seem to specialize in architectural stuff.
Golden view (02-27-2019)
Unread 02-26-2019, 08:18 PM   #14
diplomat
Rewards Points: 702
Semi unrelated, but I know a building owner who got a 14x24x24' beam. Completely clear.
hdavis (02-26-2019)
Unread 02-27-2019, 12:11 AM   #15
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,024
Canyon in Everett WA sends out structural beams that look like CVG. I do a happy dance whenever my yard sends me stuff from Canyon instead of the regular mills.
http://www.canyonlumbercompany.com/kdtimbers.shtml
SPG is offline
The Following 3 Users Say Thank You to SPG For This Useful Post:
Golden view (02-27-2019), hdavis (02-27-2019), Rio (02-27-2019)
Unread 02-27-2019, 06:37 PM   #16
rblakes1's Avatar
Rewards Points: 3,596
I'm jealous of you guys that can get cvg easily. Last time I priced it out, I think I was quoted $8/ ft. with about a 2 week lead time
Edit- for 1x6
-Rich
rblakes1 is offline
Unread 02-27-2019, 10:09 PM   #17
diplomat
Rewards Points: 702
Edit- for 1x6
-Rich
It's not cheap anywhere.
Bull Trout (03-12-2019), griz (02-28-2019)
Unread 02-27-2019, 10:16 PM   #18
rblakes1's Avatar
True, but it's at least more local and common in your area.
When I was looking into it, I could've driven up to Leo's supplier and gotten it cheaper than down here. And that included gas, tolls, and drive time
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Unread 02-27-2019, 11:11 PM   #19
Talking Head
EthanB's Avatar
Rewards Points: 390
You could try a local timber frame outfit or look for a smaller mill that will sell you direct. I haven't seen a lumberyard that really has a source for timber. Even their distributors have a pretty high markup from the mills and very limited supply for grades other than #1 fohc.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Golden view (02-28-2019)
Unread 02-28-2019, 09:06 AM   #20
Designer/Contractor
Rio's Avatar
Rewards Points: 466
Maybe you can get a civil or structural engineer to visually grade it and okay the design, an added expense but might be a solution.
Rio is online now
The Following 2 Users Say Thank You to Rio For This Useful Post:
Golden view (02-28-2019), griz (02-28-2019)
Insurance company says flooring is structural??? MorseRebuilds Business 5 06-13-2017 06:35 PM
Structural issues Camling Framing 4 02-16-2013 06:50 AM
How many actually involve a Structural Engineer on Projects rdr8887 General Discussion 32 07-24-2012 06:49 PM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 07:57 PM
