Adding Sketchup Model To Photo - Architecture & Design - Contractor Talk
Old 11-17-2013, 08:07 PM   #1
rrk's Avatar
Rewards Points: 3,518
What is the easiest way to add or layer a sketchup model to a photo? I did it once and it was fairly easy, but I don't remember how I did it.
I want to show a model of a small over hang how it would look on a customers house
rrk is offline
Old 11-17-2013, 08:11 PM   #2
duburban's Avatar
Trade: building
Rewards Points: 1,776
Re: Adding Sketchup Model To Photo
Do you have adobe Photoshop? I don't know where to start otherwise.
duburban is offline
Old 11-17-2013, 08:15 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 11,486
Import the photo and then draw on it? Pretty simple. There are other ways but are harder and more time consuming using photo-match etc..
Cole is offline
Old 11-17-2013, 08:19 PM   #4
rrk's Avatar
The scale would be wrong, wouldn't it
Right now I have the model and the photo just have to add 1 to the other.
I may just try to add the model to the photo an then scale it.
When I did it it was easy but not easy enough that I remember it
rrk is offline
Old 11-17-2013, 08:37 PM   #5
duburban's Avatar
Trade: building
So what program are you using?!
duburban is offline
Old 11-17-2013, 08:48 PM   #6
Mod / ArchiBuilder
Cole's Avatar
You can scale the photo in Sketchup once imported. If you know some or one measurement/dimension in the photo, it's very easy to do.
Cole is offline
Old 11-18-2013, 09:16 PM   #7
rrk's Avatar
Sketchup Pro 2013 the new one
rrk is offline
Old 11-18-2013, 09:22 PM   #8
rrk's Avatar
How do you scale the photo? I just scaled the model and it worked but somehow I lost the textures between the model view and the photomatch view. I must have a setting incorrect.
My brain must be going, I used to be able to do it easily but now, ..... so sad
They made a couple of changes in pro 2013 which should not have thrown me off but it did
rrk is offline
Old 11-18-2013, 09:42 PM   #9
duburban's Avatar
Trade: building
I see what your doing now. I normally would export my model into the photo using photoshop. With photoshop I would isolate the model and layer it over the photo stretching it to fit the given proportions of the photo.
If your only using sketchup then you should do a search on adding background to model tutorials. In that case the photo is added to a vertical surface and you can pull that surface around to make the proportions right.
duburban is offline
Old 11-25-2013, 12:06 PM   #10
Metal Stud Framer
Zendik's Avatar
Trade: Commercial Construction, Metal Stud, Drywall & Aco
Rewards Points: 152
Easiest way?
Send it to me.
Zendik is offline
Neat photo of dry well for sewage Oconomowoc Plumbing 16 10-12-2013 03:04 PM
Need to identify brand of material in photo jacksonsfo Roofing 21 09-29-2013 06:22 AM
Adding a keystone to brick arches post-construction marphtwo Masonry 24 04-15-2013 06:04 AM
Shell House model bubbatn Marketing & Sales 7 12-30-2008 10:19 AM
adding 12" to casions Jarrow Construction 0 08-18-2008 05:48 AM
