3D Math. Raising A Floor To Ceiling Refridge Cab - Page 2 - Architecture & Design - Contractor Talk
Old 08-16-2013, 07:56 PM   #21
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 13,887
Re: 3D Math. Raising A Floor To Ceiling Refridge Cab
Nope, can't do that.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-16-2013, 09:04 PM   #22
KAP's Avatar
Trade: Custom
Rewards Points: 35,488
If you don't want seams, I don't see any other way but skinning and site-spraying the sides... just have it prepped ahead...
Other option is if you are doing furniture grade, you could add a base to the sides for the unit to sit on that it inserts into... lift and slide after securing it to floor... fill and site spray the seam (or touch-up brush)...
You could also use the side-panel option, but one other thing you could add is a decorative trim on the corners...
You could also Increase the crown molding size and box/slide it into place...
KAP is online now
Old 08-16-2013, 10:39 PM   #23
tjbnwi's Avatar
Rewards Points: 4,332
I entered a rise of 96-1/2" a run of 25-5/16", returns a diagonal of 99-3/4". That is how I figure the diagonal.
tjbnwi is offline
Old 08-16-2013, 10:53 PM   #24
LRG WoodCrafting
Leo G's Avatar
You mean a rise of 96 1/2.
You can't have the opposite and the hypotenuse the same length unless the adjacent side is zero. Then all you have is two overlapping lines.
Plus you are only thinking 2D.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-16-2013, 11:00 PM   #25
hdavis's Avatar
Rewards Points: 4,998
OK, so cut out the floor under where the adjoining cabinets will be, stand it up, slide it over, repair floor, put in the rest of the cabs. If the joists go the right way
Could make it easy for plumbing...
hdavis is online now
Old 08-16-2013, 11:02 PM   #26
LRG WoodCrafting
Leo G's Avatar
That'll get my gears turning tonight.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-16-2013, 11:24 PM   #27
hdavis's Avatar
Nothing like creative destruction...
Old 08-16-2013, 11:25 PM   #28
tjbnwi's Avatar
Yep, miss typed the rise. I have fixed it.
2D or 3D the hypotenuse is the same. The width does not affect the diagonal.
Can you leave the back off just the upper cabinet, slot the ceiling, stand the cab up then install the back on the upper? You may have to stand the cab then rotate it in place depending on joist direction.
tjbnwi is offline
Old 08-17-2013, 09:22 AM   #29
LRG WoodCrafting
Leo G's Avatar
I'm doubting the sheetrocker would want me to do that.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-17-2013, 11:14 AM   #30
Willin's Avatar
Trade: Retired
Rewards Points: 442
All in pieces, all prefinished, came out OK
Willin is offline
Old 08-17-2013, 11:21 AM   #31
LRG WoodCrafting
Leo G's Avatar
Stained vs painted. I wouldn't care much with a stained cabinet. You can hide the joints pretty well. With painted, especially white, you see everything.
What I'll end up doing is gluing up the FF but not the removable side. Put pocket screws in the bottom side of the deck and the topside of the top. Paint the cabinet and then put it apart at each step so I don't get a thick bridge of paint over the FF joint. After I install it I'll fill what gap/crack remains with crayon or blendal stick. It'll be hard to see the joint, but an experienced eye will catch it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-17-2013, 11:56 AM   #32
KAP's Avatar
Trade: Custom
Leo, if you are that concerned about where the panel meets up with the face-frame, why not make it part of the design and use a v-groove bit...
It would eliminate the issue, make it easy to assemble... problem solved... very common on painted cabs...
KAP is online now
Old 08-18-2013, 07:09 PM   #33
bconley's Avatar
Trade: Kitchen and bath design+remodel
Install it in pieces and then paint it (or re-paint) in place
bconley is offline
Old 08-18-2013, 08:12 PM   #34
LRG WoodCrafting
Leo G's Avatar
I know the bit. Not happening.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-18-2013, 08:48 PM   #35
KAP's Avatar
Trade: Custom
Not a fan of it myself (never used it, just have seen it on many painted cabs over the years)... just trying to give you options since apparently you can't spray onsite, which is really the answer... skin in and spray it after assembly.... I gave you other options, but no response on those... there's not much you could do beyond these considering materials choices and site conditions...
Best of luck... 8^)
KAP is online now
Old 08-18-2013, 08:58 PM   #36
LRG WoodCrafting
Leo G's Avatar
Ya, I know. Stuck with assembling it on site. It'll look fine, just hate dealing with assembly on site when I can do it more efficiently in the shop.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-19-2013, 06:49 AM   #37
rrk's Avatar
Rewards Points: 2,002
Will there be room to get in there to install pocket screws on the top? 3" space 25" away, angled up might be tricky
rrk is online now
Old 08-19-2013, 06:54 AM   #38
LRG WoodCrafting
Leo G's Avatar
4" top rail that has a 3/4" top at the bottom of the rail leaves 3 1/4" of space to play in. Shouldn't be an issue.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-19-2013, 05:16 PM   #39
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Lightbulb
I thought I would help out here with a motivational video............
http://youtu.be/H7AthbqkW68
B,
PrestigeR&D is offline
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
Wood framing/furring for suspended drywall ceiling akm Carpentry 30 04-24-2013 09:42 PM
Weird wiring numbers on a ceiling fan? DemRem Electrical 15 04-17-2013 01:34 AM
Raising a 78-inch ceiling (entire house) LetItBeLEED Framing 38 08-19-2009 12:03 PM
