Older Homes, And The Lead Paint Deal - Lead RRP Discussion - Contractor Talk
Old 11-16-2018, 07:46 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Again, searched forum thinking I'd already seen it here a couple years before but maybe not...
About every decade, I end up on an older home; painting, maybe wall repair.
Is it true that 6 square foot must be disturbed before I must be certified and formally treat the stuff as "EPA Certified"? Are there other agencies involved or rules that apply? I'm simply caulking, puttying, priming, and painting over the existing wood trim, or coating walls - not removing walls, etc. I can't recall ever coming close to disturbing this footage on a pre-1978 home.
Obviously I don't want anyone to suffer from lead poisoning, especially children... but where, or is there risk when you go to do a residential interior repaint, and it is not peeling or lifting to begin with? And the project is basically tight.
How can the painter get in trouble when simply going out to an old home, where there happens to be lead based paint? (local building inspectors?)
And what if you come in on a job after another contractor already sanded the surfaces, primed or stripped surfaces that you are called to come in and prime and paint over? Is it strictly "must disturb 6 sq ft" in order to get into big trouble?
artinall is offline
Old 11-16-2018, 08:07 PM   #2
VinylHanger's Avatar
Rewards Points: 14,096
Re: Older Homes, And The Lead Paint Deal
Technically you can't even look at or quote an older house if you aren't certified. You don't have the certification to use the swab to see if it is lead paint.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
sparehair (11-18-2018)
Old 11-16-2018, 08:15 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
1978 is the cut off date.
Randy Bush is offline
Old 11-16-2018, 08:18 PM   #4
hdavis's Avatar
Rewards Points: 4,372
Not true.
hdavis is offline
Golden view (11-16-2018)
Old 11-16-2018, 08:27 PM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
That's often what's thrown around but even the EPA booklet you have to give to your client doesn't read that way.
Federal law requires contractors that disturb painted surfaces in homes, child care facilities and schools built before 1978 to be certified and follow specific work practices to prevent lead contamination. Always ask to see your contractor’s certification.
Federal law requires that individuals receive certain information before renovating more than six square feet of painted surfaces in a room for interior projects or more than twenty square feet of painted surfaces for exterior projects or window replacement or demolition in housing, child care facilities and schools built before 1978.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
artinall (11-16-2018), hdavis (11-16-2018)
Old 11-16-2018, 08:29 PM   #6
hdavis's Avatar
If somebody else sanded and primed, that isn't your problem.
Don't sand. Don't score anything with a knife. Don't hammer on anything.
Doing patches, sponge sand. Wall prep by cleaning is fine.
What they don't tell you is hammering on a board or wall could be interpreted as disturbing the entire board or wall.
If you have more specific questions, ask.
The 6 sqft is only used to trigger compliance requirements. You can do interior patch prep and paint using methods that disturb 0 sqft. The first thing to go is using sbrasives in patching and prep / paint.
hdavis is offline
Old 11-16-2018, 09:20 PM   #7
Randy Bush's Avatar
This is taken from the EPA site . While I think the whole RRP thing is a joke, I think one needs to be careful when working on older homes. Like hdavis said no sanding , cutting or anything, although I disagree with if someone else did it is not your problem. Probably a gray area until they are looking to nail you.
Older Homes, and the Lead Paint Deal-20181116_185905-1657-.jpg   Older Homes, and the Lead Paint Deal-20181116_185822-1656-.jpg
The Following User Says Thank You to Randy Bush For This Useful Post:
Rio (11-16-2018)
Old 11-16-2018, 09:50 PM   #8
artinall's Avatar
https://www.epa.gov/lead/renovation-...am-contractors
At first it says:
Firms that require certification
"In general, anyone who is paid to perform work that disturbs paint in housing and child-occupied facilities built before 1978 must be certified"
But then:
"The following housing or activities are not covered by the rule
Minor repair and maintenance activities that disturb 6 square feet or less of paint per room inside"
Which seems self-negating -- having certification is stated as a generality, and seems to apply when 6 foot or more is disturbed.
artinall is offline
Old 11-16-2018, 09:57 PM   #9
It is an arbitrary rule. Then some states like ours have their own interpretation. Then it also comes down to what the meaning of is is most of the time.
Old 11-16-2018, 10:10 PM   #10
hdavis's Avatar
That's correct, 6 sq ft or less does not require cimpliance with the law.
Have documented procedures dealing with patch prep and paint in older hones which disturbs 0 old paint.
Theoretically, there could be an issue if you came in on a projects and disturbed any when the rule has already been triggered. It's open to interpretation.
HOs are exempt, so they csn sand, saw, and bang away.
BTW, I received certification with a perfect score. I also have a copy of the EPA enforcement manual somewhere, and have read it, and some relevant EPA interpretations which have come along.
Having been trained, the fines I face for noncompliance are much stiffer than those who aren't trained and are unaware. Even so, I've been able to adjust so interior patch and paint do not trigger compliance.
hdavis is offline
Old 11-16-2018, 10:19 PM   #11
hdavis's Avatar
Each state can have it's own statute, it has to be as restrictive as the federal statute. The intetpretations aren't arbitrary, but there are some gray areas. One example would be cutting a piece of painted trim. The entire area of that piece is the area. OTOH, if you drill a series of very small holes in it until it's in 2 pieces, it's only the drilled area. Driving a nail through it, it's the entire area of the piece. Not necessarily so with driving a scew in.
hdavis is offline
Old 11-17-2018, 06:26 AM   #12
artinall's Avatar
Do state statutes prevail? Or, can national EPA standard apply at the same time?
I can see where documenting individual patch/sand spots could quickly prove too difficult...working areas not showing on pictures, etc. Then there is the question of how can anyone else know besides the painter what exactly was done at the time and by who?
If someone else has been on the job 1st, then certain, many, or most, doors and trim could have been stripped first. Or sanded. Showing this after the fact could be next to impossible especially if re-priming was already done before pics taken. Then, the question of what primer type was used after the stripping, etc..
artinall is offline
Old 11-17-2018, 11:40 AM   #13
KAP's Avatar
Trade: Custom
Rewards Points: 40,712
Easier to read...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
Randy Bush (11-17-2018), Rio (11-19-2018)
Old 11-17-2018, 12:20 PM   #14
I would assume it only has to do with what you are working in. If I go in and am just painting preprepped surfaces, it doesn't come into effect. Or even if I am just covering old lead paint and not hard prepping it.
I can use TSP substitute and wash it down and degloss then prime and paint, and it doesn't activate the protocals.
Old 11-17-2018, 12:43 PM   #15
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 16
I don't know a single contractor, painting or otherwise that even pays attention to these laws.
pinwheel is offline
The Following 3 Users Say Thank You to pinwheel For This Useful Post:
Calidecks (11-18-2018), Irishslave (11-19-2018), Tom M (11-19-2018)
Old 11-17-2018, 05:03 PM   #16
hdavis's Avatar
If your work practices don't trigger it, it isn't a problem.
hdavis is offline
Old 11-17-2018, 05:06 PM   #17
hdavis's Avatar
Most of the buildings up here are pre 1978. Exterior repaints tend to be under RRP. All the larger paint contractors seem to.
hdavis is offline
Old 11-17-2018, 05:19 PM   #18
hdavis's Avatar
They apply at the same time. Most states just adopted the federal statute. Maine tweaked it a little bit.
Under the federal statute, I can go scrape my 88 yo Mom's house, and as long as I'm uncompensated, I don't have to comply with any of that.
State statute just says anyone except the HO has to comply.
hdavis is offline
Old 11-17-2018, 07:11 PM   #19
artinall's Avatar
Please clarify what you mean by hard prepping.
I see doors and trimmed already stripped and with some already sanded (partly or all). I see no problem with doing priming, caulking, putty and paint on these surfaces.
If a piece of trim has been already completely stripped down, I don't see a problem priming onward, but again, somebody else not be able to tell the diff.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
hdavis (11-18-2018)
Old 11-17-2018, 07:47 PM   #20
Sean
SLSTech's Avatar
Trade: Principal / Owner
Yes there are numerous ways around it but document, document, document - proper scope of work with contract is your best defense along with pictures.
Be sure you know the exemptions, especially regarding demo...
http://thehtrc.com/2012/epa-rrp-enfo...ctions-impacts & http://thehtrc.com/2010/rrp-620-exemption-limits might help you on some of this - granted some are older pieces but to my knowledge not much has changed
As for other agencies - OSHA is big followed by HUD --- there should be a link to OSHA in the related articles section or linked in one of the pieces
SLSTech is offline
