Looks Like Trump Is Cutting Epa Funding - Page 2 - Lead RRP Discussion - Contractor Talk
Old 01-31-2017, 11:07 PM   #21
RedAdobe's Avatar
Trade: Sparks
Rewards Points: 138
Re: Looks Like Trump Is Cutting Epa Funding
as he said for every new reg there must be 2 eliminated.
How about we try that with politicians, lawyers and paper pushers
Some other EPA stupidity.....they went after wood stoves and fireplaces, I can see it in metro areas to a point in higher elavations where inversion happens seems like 4500 ft above sea lvl ( I suppose ) but no it's on everyone.
HOWEVER millions of acres of wildfires happen every year in the south west ( and south now) and lots a BS rules / regs on clearing fire prone areas.
didnt take mo but a couple mins of this:
https://www.epa.gov/burnwise/ordinan...ing-appliances
I grew up out in the country and know a good old pot belly with fresh air duct can burn clean and efficient after start up ( fresh air ducting from outside helps alot )
_________________________________________________
as for LEAD and asbestos
don't chew on old painted surfaces, Dont scratch the fireproofing or insulation on pipes, so on so forth.
There are more dangers blowing around in the dirt daily , tested decades ago in NM and Nevada
RedAdobe is offline
The Following 2 Users Say Thank You to RedAdobe For This Useful Post:
hdavis (02-01-2017), VA Remodeler (01-31-2017)
Cutting Hardwood tileman2000 Flooring 28 02-10-2012 09:14 AM
Cutting through 3' of concrete H&S Excavation Commercial Construction 9 12-29-2011 12:48 AM
Glass tile cutting Aaron Tritt Tiling 13 06-06-2011 01:46 PM
Problem cutting in bad drywall job tripster Painting & Finish Work 23 02-10-2011 10:33 AM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 10:54 AM
