Working In The Cold Weather - General Discussion - Contractor Talk
Old 12-13-2009, 11:00 PM   #1
Cjeff's Avatar
Trade: Renovations
Hey guys been reading the forum for a while an decided to join.
I am in Saskatchewan Canada, which is to say I work in the cold. In the -30c range here now with -40's for wind chill. (-30c is -22f -40c is -40f )
Any tricks tools for cold weather?
I now use fishing gloves. 'Bushline' is the brand. they are the green ones from Wall-mart. Used them in -20c all day and my hands warm. Plus I can handle nails/screws with them on. I used to use a 'liner' glove on my nail hand and 2 on the hammer/drill hand.
Also got a balaclava that snowmobiler's use. Some high tech material. Used it tonight outside in -28 for over an hour and my face was really warm. Still use a fuzzy hat as this is usually worn under a helmet and is not warm on the top. Really thin material there.
Any other tricks?
Cjeff is offline
Old 12-13-2009, 11:48 PM   #2
Teetorbilt's Avatar
Rewards Points: 2,000
Re: Working In The Cold Weather
-40?? in whatever, I'd be sitting on a log inside the fireplace!
We just had a cold front pass through and went into the 50's F for almost two days. I had to wear a jacket, long pants and shoes w/socks, hated every minute of it. Back to T-shirt, shorts and flip-flops now, life as it should be.
Look into hunting gear, they even have electrically heated underwear now.
Albert Einstein
Teetorbilt is offline
Old 12-14-2009, 12:01 AM   #3
Dig with BIG TOYS
digdeep516's Avatar
Trade: Landscape, Masonry, Site Prep... the grunt work
Rewards Points: 75
damn... -40 and i thought -5 was bad enough... when its that cold i guess double up on the thermals, i wear underarmour as a base layer for hunting and when its cold i use it for work... but damn teetorbuilt was right id be scared to walk out the door if it was that cold... but you should look at cabelas.com for hunting appareal that could be helpful... and i know carrhart makes some nice outerware for **** like that.
digdeep516 is offline
Old 12-14-2009, 02:21 AM   #4
Astrix's Avatar
Trade: Insurance Broker - Commercial Construction
Rewards Points: 666
I get to work in a nice climate-controlled office environment, but the husband (drywaller) used to work unheated new housing. They'd bring portable heaters along. Layering also is a key - double up on the thermal longjohns and long-sleeved undershirts. Balaclavas work great. Gloves were always a problem - in order to get ones that would be warm enough, they would be too thick to work comfortably in. Then he got these little heat packs that you can put in gloves; the type where you've got to crack something on the inside and then there is a chemical reaction which keeps the packet warm for a couple of hours. He could then wear those with regular gloves. Fortunately, the "old man" is semi-retired now and doesn't work in the cold weather anymore.
Astrix is offline
Old 12-14-2009, 08:47 AM   #5
Cjeff's Avatar
Trade: Renovations
I try not to do exterior work when it is -25c or below.
Actually -20c and sunny with no wind is not a bad day.
-10c , cloudy and windy can be miserable.
Cjeff is offline
Old 12-14-2009, 09:04 PM   #6
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
I dont have much advice you are getting into some temps where i would not work, but I wear lots of layers nothing tight or stiff
trying diffrent things is important everybody seems to have a diffrent system
I am a big fan of wool bibs
but i do want to know what kind of guns and staplers you are running in those temps
nailkiller1 is offline
Old 12-14-2009, 09:20 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,877
Don't know, don't care. Sorry, but I'm not working in anything below -5F. This is why I have a shop. 62F in the winter and kinda hot in the summer.
I don't consider it to be cold until it is about 20F And I usually wear my fall jacket up until that temp. Winter coat below.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-14-2009, 09:23 PM   #8
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Make that 2 of us!!!
Framer53 is offline
Old 12-14-2009, 09:49 PM   #9
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
If you want warm clothes for them kind of temps then you wanna look at Ski/Mountain wear. The tech in some of this kit is extremly advanced. They make heated boots, Heated gloves, Heated Socks, Heated base layers and have some of the most advanced fabrics avalible.
BCConstruction is offline
Old 12-15-2009, 12:21 AM   #10
Cjeff's Avatar
Trade: Renovations
The compressor and nailer do not like it much. Neither do I!!!!
I noticed my circular saw complains too.
I buy all cold weather cords that are good for -40c.
The ski/mountain wear may be a good idea. Also am looking into snowmabile and hunting stuff.
Cjeff is offline
Old 12-16-2009, 10:18 PM   #11
CSinc.'s Avatar
Trade: Windows Roofing Siding
Rewards Points: 75
ever tried military issue goretex and mickey mouse boots.cheap and very effective
CSinc. is offline
Old 12-17-2009, 01:49 PM   #12
Cjeff's Avatar
Trade: Renovations
Do you have a website where I can see some goretex gloves you mention? Any I see are to bulky for handling nails and such.
Cjeff is offline
Old 12-17-2009, 03:01 PM   #13
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
start bidding jobs in San Diego. currently 70* f
parkers5150 is offline
Old 12-17-2009, 03:21 PM   #14
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
A carpenter friend of mine says tough duck overalls+jacket is best, b/c you can take off the jacket if you get warm. I usually wear as many layers as I can, and I don't bother buying expensive weather gear b/c I work in stucco and my clothes have a very short life span. I Like getting military surplus, cuz its cheap and well made, and usually has quite a bit of life left when I get it.
SamM is offline
Old 12-17-2009, 03:22 PM   #15
JonM's Avatar
Rewards Points: 1,246
The best tool you could ever get is an education..
JonM is offline
Old 12-17-2009, 10:02 PM   #16
CSinc.'s Avatar
Rewards Points: 75
when i mention goretex i mean the parka and pants.i use the ironclad windproof fleece and keep one pair in my coat in case the others get wet or if i drop a glove somewhere.i like to chop off the thumb and index.i would like to find a good waterproof pair of gloves that wouldnt limit dexterity too much.find some let me know.
CSinc. is offline
Old 12-19-2009, 10:09 AM   #17
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
The there is no such thing as "too cold"... just "bad clothes!"
As others have said, Layers. Army Surplus is a good way to go.
The first layer should wick moisture away from the body. Dry=Warm
Fleece is good. I like fleece vests (keep the core warm with less bulk on the arms for movement).
Wool is still warm when wet.
Products with Thinsulate provide warmth without bulk.
Gortex is like house wrap, it lets water vapor escape, but keeps liquid water out (actually I think Tyvek is the same stuff).
I like Gortex parkas with pit zips... allows venting never want to overheat then get sweaty and cold.
I have Carhartt insulated bibs for winter work... mine are black rather than brown to capture a little more warmth from the sun.
Get a Peet boot dryer. Dry your boots each night. Best to have two pair and alternate... especially if you don't have the boot dryer.
The baklava is great, with a warm hat.
Here is a photo from a back country ski trip across Yellowstone Park. -20 to -40 most of the time and we were winter camping. No cozy lodge or campfire. Stayed warm and had a great time... out in the cold, day and night, for 7 days. Only saw people on the first and last days of the trip. Winter is the time to enjoy the outdoors without the bother of other people...
...hey, where did everybody go?
I used to play hockey in Canada on outdoor rinks, -40* was perfect. Numbs the shins so a slap shot to the shin without pads doesn't hurt so much... 'til later anyway.
If you saw an exposed ear lobe on another player, you would thwack it as you skated by... it was a courtesy really... don't want any frostbite out there.
Working in the cold weather-5689_1128583383272_1487822778_30512603_2390349_n.jpg
basswood is offline
Old 12-19-2009, 10:27 AM   #18
katoman's Avatar
Trade: carpenter
Any other tricks?
Skin a polar bear A little heavy to wear, but guaranteed warm !!!!
katoman is offline
Old 12-19-2009, 11:03 AM   #19
Ebbo's Avatar
Trade: Carpentry/Remodeling/Superintendent
Rewards Points: 75
I hear ya on that. If it gets below 70 degrees I start to freeze to death.
Ebbo is offline
Cold Jet/ColdJet 250-FP? ERAD_DIB Sandblasting 12 01-17-2011 12:29 PM
Hot water coming out of cold side Eric K Plumbing 12 06-29-2009 08:43 PM
Weather Sucks THINKPAINTING Painting & Finish Work 16 06-27-2009 01:55 PM
Batteries & cold temps Danno6102 Tools & Equipment 5 01-05-2009 11:04 PM
