Why Is The Siding Falling Off? - Page 2 - General Discussion - Contractor Talk
Old 12-07-2018, 10:44 PM   #21
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,096
Re: Why Is The Siding Falling Off?
Hard to tell what kind of staple it is from that picture. It does look smaller than 16 gauge but not sure. I have my foundation guy install 2x2 PT strips in my foundations for vinyl siding.
I’ve done the staples in vinyl before but you miss the studs a lot when the sheathing is covered by housewarap, then you have to cut the siding away from the staple. I just use nails now, not much slower.
Big Johnson is offline
Old 12-08-2018, 06:20 AM   #22
META's Avatar
Trade: General and Trades
Rewards Points: 3,388
Iíve done the staples in vinyl before but you miss the studs a lot when the sheathing is covered by housewarap, then you have to cut the siding away from the staple. I just use nails now, not much slower.
Use a pair of tin snips and cut the staple.
On staples from VSI.
META is online now
Old 12-08-2018, 06:30 AM   #23
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,306
Originally Posted by VinylHanger View Post
No, but the osb will start to swell and fail.
Why would OSB swell and fail under properly installed vinyl?
Kowboy is offline
Old 12-08-2018, 06:33 AM   #24
META's Avatar
Vinyl still leaks after being "properly" installed.
META is online now
The Following User Says Thank You to META For This Useful Post:
hdavis (12-08-2018)
Old 12-08-2018, 06:35 AM   #25
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 6,708
Vinyl is final around here. My little house or a million dollar McMansion. Some might have brick or stucco in front but vinyl everywhere else. Have installed it on hundreds of houses. Never seen a staple used though.
NYgutterguy is online now
The Following User Says Thank You to NYgutterguy For This Useful Post:
TimNJ (12-08-2018)
Old 12-08-2018, 06:36 AM   #26
John the Builder
SmallTownGuy's Avatar
Rewards Points: 8,200
yup. As does Hardie board and even brick..
That is why WRB is required by code.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
META (12-08-2018)
Old 12-08-2018, 07:15 AM   #27
META's Avatar
It's also why I won't use the lower end house wraps, those leak and deteriorate too easily as well. A few $100 more gets you night and day quality on the entire envelope.
META is online now
SmallTownGuy (12-08-2018)
Old 12-08-2018, 07:46 AM   #28
Same here.
Cutting the vinyl (with snips) and pulling it away from the staple is easier than cutting the staple. Easier on your snips too.
META (12-08-2018)
Old 12-08-2018, 09:14 AM   #29
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,220
Unless it is an unheated garage or a gable end of a house , at least here, which makes no sense. You cant tell me water does not get in behind there.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
Lettusbee (12-08-2018), SmallTownGuy (12-08-2018)
Old 12-08-2018, 11:01 AM   #30
hdavis's Avatar
Rewards Points: 3,132
Originally Posted by Rio View Post
Interesting factoid on vinyl siding; it has a Class A fire rating, can be used in fire zones in California which really surprised me. It was a 'who would have thunk it' moment when I read that in Chapter 7A.
I'm really surprised by this, since I've seen houses burn where the vinyl siding burned. Heats up, makes a pile at the bottom of the wall, and burns.
hdavis is online now
Old 12-08-2018, 05:58 PM   #31
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 5,444
Im going to take some and see if it burns
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 12-08-2018, 06:05 PM   #32
John the Builder
Its pvc. Get it hot enough you'll have a smoldering, low flame.
And dont breathe the sh!t, its bad-ass poison.
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
hdavis (12-08-2018), META (12-08-2018)
Old 12-08-2018, 08:37 PM   #33
hdavis's Avatar
:NIST tested it and clapboards. Vinyl siding burned up the wall and into the soffit in something like 240 seconds, clapboards went 400 something seconds.
Once it burns into the attic, there isn't much time to save the structure.
Staining Cedar T&G Siding j_sims Painting & Finish Work 1 05-31-2013 10:30 PM
Starting a siding crew nlgutters General Discussion 81 03-20-2013 10:15 PM
What siding on top of 2" of polyiso? zeester Windows, Siding and Doors 26 03-14-2013 05:27 AM
Should I tear off old wood siding? YJT Windows, Siding and Doors 11 08-21-2011 03:07 PM
100+ y/o siding repair. to run or not to run. VALCOR Windows, Siding and Doors 19 02-25-2009 06:22 PM
