Why Is My Table Saw Zapping Me? - General Discussion - Contractor Talk
Old 05-20-2020, 05:34 PM   #1
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 564
We have been using the Dewalt 60v table saw for about a year, and really love it. The one issue we have is when ripping pvc trim, which we do a lot. During every cut, a static charge will build up and zap you when you touch the metal table. More of an annoyance, as we know it's coming, but just wondering why?
My electrical knowledge is very limited, so I don't know if there is a remedy for this or not. Never noticed it on any other battery tool other than this one.
Warren is offline
Old 05-20-2020, 05:44 PM   #2
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 462
Re: Why Is My Table Saw Zapping Me?
Sounds like you need a ground strap to discharge the static build ?
I never had it happen on my porter cable table saw.
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
Old 05-20-2020, 06:08 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 30
Friction + PVC = static charge. Pretty well known effect, but I'm not sure why we don't notice it more often with our work/tools. Maybe because most cuts aren't long enough to build up a significant charge.
The obvious solution, if it really bugs you, is to maintain electrical contact with the machine while using it, so you both have the same amount of charge. Of course, that won't stop getting a zap if you subsequently touch something else that doesn't have that charge.
Back when I serviced fax machines, we found that some of them tended to have paper-handling problems due to static buildup. The solution? Periodically spray the machine down with Static Guard.
No idea why it would happen with the DeWalt and not other machines.
Tinstaafl is offline
Old 05-20-2020, 06:18 PM   #4
Geometrist
Warren's Avatar
Rewards Points: 564
Never had it happen on any corded table saw. I know that pvc does produce a lot of static, but this will zap you after even a short rip. Will only do it with pvc and not wood.
Warren is offline
Old 05-20-2020, 06:23 PM   #5
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,058
Where's Leo when you need him?
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old 05-20-2020, 07:37 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,899
Tin nailed it. Static discharge with no place to go. It doesn't happen with your plug in saw because it's grounded.
Does it have a metal or plastic tablesaw top? If it's plastic there probably isn't much you can do. If it's metal you can attach a flexible wire to it and attach it to a big nail and push it into the ground, essentially grounding your tabletop.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-20-2020, 08:45 PM   #7
Robie's Avatar
I thought you were going to come up with something fancy like...the density and molecular coefficient of pvc when pushed across an iron surface at a certain rate of speed gives an imbalance of electrons between the two surfaces...therefore causing a static charge.
Oh well.....
― Will Durant
Robie is online now
Old 05-20-2020, 08:49 PM   #8
LRG WoodCrafting
Leo G's Avatar
Pretty sure he doesn't give a crap why it happens, he wants to know how to stop it. Sorry to disappoint.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-20-2020, 09:13 PM   #9
MarkJames's Avatar
Rewards Points: 20,239
Ground it.
MarkJames is online now
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Rio (06-02-2020), Robie (05-20-2020)
Old 05-20-2020, 09:44 PM   #10
rrk's Avatar
Rewards Points: 76
A battery operated saw that you have to plug in.........hmmmm. whats wrong with this picture?
rrk is offline
Old 05-20-2020, 10:09 PM   #11
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,731
Slightly related; any time I rip pvc fascia boards I spray myself and my FACE with static guard first. Absolutely no worse pain I know of than the little cuttings getting behind contact lenses.
Imagine you’re on a 4/12 roof installing a facia board where a gable meets the main roof. (Almost laying on your side.) Just as you get to where the pointy triangle meets the roof, that was a pain in the butt to rip in the first place the sweat drips off your forehead into your eye and brings a whole bunch of murder hornet plastic shavings.
I love PVC and I hate it.
WBailey1041 is online now
The Following 2 Users Say Thank You to WBailey1041 For This Useful Post:
rblakes1 (05-21-2020), Rio (06-02-2020)
Old 05-21-2020, 04:28 AM   #12
Geometrist
Warren's Avatar
Rewards Points: 564
It has a metal top. I thought of grounding it, but with it being DC, I didn't know if that would do it.
Warren is offline
Old 05-21-2020, 06:18 AM   #13
rblakes1's Avatar
Rewards Points: 4,210
I will spray some static guard onto the table top and fence, as well.
I generally keep my left hand down as a material guide, so that reduces the shock
-Rich
rblakes1 is offline
Old 05-21-2020, 06:37 AM   #14
LRG WoodCrafting
Leo G's Avatar
Static charge has to go somewhere. Drain it off through a wire into the ground or it'll drain itself through you into the ground, ouch.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-21-2020, 04:40 PM   #15
Geometrist
Warren's Avatar
Rewards Points: 564
Grounded the saw table to the metal stand and it worked like a charm.
Warren is offline
The Following 5 Users Say Thank You to Warren For This Useful Post:
deckman22 (05-21-2020), MarkJames (05-21-2020), pinwheel (05-21-2020), Rio (06-02-2020), Tinstaafl (05-21-2020)
Old 05-21-2020, 07:27 PM   #16
LRG WoodCrafting
Leo G's Avatar
Your welcome.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-29-2020, 10:51 PM   #17
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,280
Yeah those 4/12s are a real bitch. I hope you were harnessed off somewhere. Next time try installing the fascia from a ladder like it's supposed to be done. Much easier not working horizontal and upside down
madrina is offline
Old 05-30-2020, 06:13 AM   #18
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,934
My cordless makita blower zaps me, I thought it had something to do with snow but I get zapped blowing drywall dust too.
Big Johnson is offline
Old 05-30-2020, 09:18 PM   #19
Mordekyle's Avatar
Rewards Points: 6,392
My flexvolt blower zaps me occasionally. I’ve only noticed it while blowing leaves on my gravel driveway.
Mordekyle is online now
Old 05-30-2020, 09:24 PM   #20
LRG WoodCrafting
Leo G's Avatar
Never got zapped from my EGO blower... so far.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
