When My Sales Skills Fail Potential Customers - General Discussion - Contractor Talk
Old 11-29-2014, 10:31 AM   #1
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 9,102
I followed up with a lady whose undermount sink had fallen and found out she’d hired someone else who charged 35% less than I do. My otherwise excellent phone skills coaxed his methods out of her. Unfortunately, he reinstalled her failed sink with wood blocks spanning the sink flange and granite, held in place with polyester as an adhesive and mysteriously forbid her the use of the sink for three days. Virtually every sink I reinstall was originally stuck with blocking and polyester; it is an approved method nowhere and guaranteed to fail again. If it fails quickly so much the better; a slow leak can create a nearly catastrophic, and expensive, rod failure.
The sink repair isn’t the only failure on this job, I am. Because I was unable to convince this woman my higher priced repair was the best value, she’s just set several hundred dollars on fire and endangered her stone. If I wasn’t religiously convinced that I am the best possible value for this job, I couldn’t get out of bed in the morning. I feel a moral obligation to save customers from themselves and it hurts when I’m unsuccessful.
Successful contractors keep abreast of the latest in tools, methods, and technologies; all worthless without sales skills. Looks like I may need a class.
Kowboy is offline
Old 11-29-2014, 10:40 AM   #2
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 250
Re: When My Sales Skills Fail Potential Customers
Its just one call, right?
Why beat yourself up? We cant bat 100%. Some people just dont understand value.
"If I have wounds I have two choices, See myself as a victim or see myself as a warrior"
Cheif Joseph
Jaws is offline
Old 11-29-2014, 11:04 AM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,495
Some people just hear the price part when having a conversation with a contractor.
They also think all contractors are created equal.
Some things will never change...
You did all you could. Time to move on to the next one.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 100,000 Subscribers and over 15,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
CarpenterSFO (12-06-2014)
Old 11-29-2014, 11:50 AM   #4
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Any doctor can attest to the fact that you can't save everyone from themselves.
As many times as they have said, "Don't _______ or you will die." or "You must do ______ if you want to live and/or get better." people will still do whatever makes sense in their minds and you can't stop the inevitable outcome.
The good news is that when you have this situation with a house, no matter how bad things get, they can always be repaired and replaced. All it takes is time and money.
I admit that I face the same dilemma sometimes. While I will use surgical cuts smaller than an inch in diameter to fish wires behind walls, other contractors will opt to take out a 3x3 section out of the wall and cut slits all over the place. After they made swiss cheese of the entire living room and STILL have a couple of exposed wires, it makes me wish that they would have taken my advice and used me instead of them.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 11-29-2014, 11:50 AM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
One psych technique is called the box. Prior to close you ask three quetions in a row which you know the answer to, yes. Then you ask for the close. Its difficult to switch from positive affirmations to rejection.
Metro M & L is offline
The Following 3 Users Say Thank You to Metro M & L For This Useful Post:
Kowboy (11-29-2014), Shellbuilder (11-29-2014), Sir Mixalot (11-29-2014)
Old 11-29-2014, 11:54 AM   #6
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 392
That's a fact!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Old 11-29-2014, 11:56 AM   #7
NCMCarpentry's Avatar
Rewards Points: 860
I like that... BS or not that mindset will help sell jobs.
NCMCarpentry is offline
The Following User Says Thank You to NCMCarpentry For This Useful Post:
Kowboy (11-29-2014)
Old 11-29-2014, 06:11 PM   #8
Jeremiah2911's Avatar
Trade: .
Rewards Points: 324
It's hard to sell someone on quality when all they care about is the cost. I'm sure she will call you when it fails.
Jeremiah2911 is offline
Old 11-29-2014, 06:54 PM   #9
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,206
What was your plan of action for remounting?
I've never installed under mount in stone but I've seen an install using some kind of tapped/threaded pieces and clips with silicone (which is pretty strong bonding clean stone surface to porcelain.
dielectricunion is offline
Old 11-29-2014, 07:35 PM   #10
Trade: .
Rewards Points: 324
Ditto. I think most use a two part epoxy with clips but we've never got a call for this. Curious to know what a superior method to this would be.
Old 11-29-2014, 08:01 PM   #11
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Ditto... Ditto....
And what is polyester...... I've used knife grade acrylic to repair a integral granite sink...... (was I wrong) It's been fine for probably 5-6 years and it was what was advised by a stone shop...
TIA for advice......
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 11-29-2014, 08:13 PM   #12
Roofcheck's Avatar
Trade: Know it all
Rewards Points: 2,054
This doesn't work with my 4 yerar old birthday girl. Customer would have to be a real iddiot to say uh ok
Roofcheck is offline
Old 11-30-2014, 06:26 AM   #13
Stephen H's Avatar
Trade: Slate& Tile Roofing/Exterior Carpentry
Rewards Points: 2,848
I agree with you.
I think if a person tried that technique on me I would simply show them the door, because I HATE THAT EFFING CAR SALESMEN BULL [email protected]
however, I am equally certain it will work on someone---- because their is no one approach that works on everyone
Stephen H is offline
Old 11-30-2014, 09:26 AM   #14
Kowboy
Kowboy's Avatar
Trade: Countertops
dielectricunion:
I nearly always use a Hercules Universal Sink Harness; you can see their installation video at https://www.braxton-bragg.com/index....vel/bc/0,9096/. I've done this at least 30 times and have yet to get a callback. The new Cinclips are nice and fast, but cost 7xs as much as a HUSH. I can install a HUSH in just over an hour.
Silicone between the sink and stone should always be considered a gasket, not adhesion. Mechanical fasteners are required to do the heavy lifting.
Here is a link to a post I made over at Kitchens. It's a variation, but you'll get the idea:
https://www.contractortalk.com/f74/ca...estone-128938/
Kowboy is offline
The Following User Says Thank You to Kowboy For This Useful Post:
Jeremiah2911 (11-30-2014)
Old 11-30-2014, 09:38 AM   #15
Kowboy
Kowboy's Avatar
Trade: Countertops
Originally Posted by Stephen H View Post
I agree with you.
Stephen H:
If you're doing it right, the customer never feels the pressure.
Kowboy is offline
Metro M & L (11-30-2014)
Old 11-30-2014, 09:55 AM   #16
Stephen H's Avatar
Stephen H:
I would dis-agree with that----and also add , it's not really a matter of "pressure"
since part of my job is sales----and since I have read many/most of the same "sales books"---as other people involved in sales----------
I would recognize the tactic for what it was.
It wouldn't pressure me in the slightest---- but I would recognize what I think is the inherent----well lets say less than honesty---in the approach.
remember-- there is generally a 3 day right of rescission in effect.
so if you use a "technique' like gulling them through 3 meaningless "yeses" in order to get them to the fourth YES on auto pilot
there is nothing to prevent them from coming to their senses an hour---or 71 hours later and cancelling the sale.
I would much rather meet with a customer like a human being----explain WHAT we are going to do--and why, What materials we are going to use--and why, what safety procedures we are going to use to protect ourselves and the customers property and why---- basically show them clearly and demonstrably why we are the best choice for their project and why things are going to cost what they cost.
no trickery, no flummery
Basically--- the customer can either accept or reject--- ultimately I don't much care which, in any individual situation because I know there is an ENDLESS supply of potential customers.
It's like baseball---succeed 3 or 4 times out of every 10 trips to the plate and you are going to the hall of fame
Stephen
The Following 3 Users Say Thank You to Stephen H For This Useful Post:
bob hutson (11-30-2014), Deckhead (11-30-2014), TLC Remodeling (12-05-2014)
Old 11-30-2014, 10:02 AM   #17
Roofcheck's Avatar
Trade: Know it all
Agreed but must add, presented with a likeable and honest personality.
The Following User Says Thank You to Roofcheck For This Useful Post:
Kowboy (11-30-2014)
Old 11-30-2014, 11:44 AM   #18
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 8
You can lead a horse to water but you can't make it drink. Keep moving forward knowing that you were honest and tried to do the right thing.
Now, when she calls back in the future with the same issue, raise the price and tell her to take it or leave it. Your time is too valuable to waste trying to coerce customers into doing it correctly.
You don't get paid to convince, you get paid to educate and build. I wouldn't lose any sleep over it.
WBailey1041 is offline
Old 11-30-2014, 11:51 AM   #19
FrankSmith's Avatar
Rewards Points: 5,124
How did you end up back in this house to see how the repair had been done? I will tell you what I see the problem to be. You are full of yourself and you think less of customers who choose someone else. You invent rhetoric to convince yourself that you do it all for the customer.
When I meet with a customer I do not sell them anything. I have two goals. Answer my phone or return the call very quickly and have a proposal to them as quickly as possible. When I meet with them I have no agenda as to what I want to tell them about my business and my processes. That is me guiding the conversation. I simply want to answers their questions with the best possible answers and produce the best possible ideas when considering options. If they wan't to use my ideas and hire some one else that is their business. When I do these things good potential customers will pay me more than they will pay some one else. Bad customers will take my good information and hire some one else or do it themselves and it never hurts my feelings.
FrankSmith is offline
Old 11-30-2014, 12:26 PM   #20
Particulate Filter
Trade: Flooring
Its easy to play nice when times are good. When times are tough there are not unlimited customers. There was a time in 2010 when I had 200 dollars and a mortgage payment due in a week. Closed a small job and started stacking money. When you start to think about losing your kids home and what would follow the gloves have to come off.
For the record my personal style is an earnest soft sell with good information. But thats a schtick as well, "you can trust me cuz Im not selling you." Im always closing because Im never closing sales, even when Im asking you to go through a fan deck, visualize what you want, show me pictures from pinterest and ask you when you want to start your project.
The Following 2 Users Say Thank You to Metro M & L For This Useful Post:
CarpenterSFO (12-06-2014), Jaws (11-30-2014)
The rules our sales guys live by Grumpy Marketing & Sales 31 10-24-2011 01:12 AM
Sales Commission and Production kbg1kbg1 Business 8 08-12-2009 10:21 AM
contact with potential customers AHS Marketing & Sales 13 02-13-2006 02:02 PM
