What Filter? - General Discussion - Contractor Talk
What Filter?
Old 07-07-2019, 11:33 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,388
What Filter?
I have an in-line water filter that filters water from my well.
Over the years, the original copper plumbing has failed and was replaced with PVC...except for the copper pipe at the oil-fired boiler that supplies heat and hot water. Those pipes continue to fail from time to time and it's seldom at a joint.
Is there a cartridge type filter that can help with this? I'm not sure what in the water causes this but would like to get a filter if available to keep it to a minimum.
Any ideas? Don't really cherish the idea of adding some big and expensive "Culligan type".
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 07-07-2019, 11:43 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,334
Re: What Filter?
i don't think a simple in-line will do the job.
good bet would be to have a local water/well company look at it.
also test your water for ph/minerals etc....
here's a link with some pretty good info.
https://www.cleanwaterstore.com/reso...id-well-water/
griz is online now
Robie (07-07-2019)
Old 07-07-2019, 02:31 PM   #3
hdavis's Avatar
Rewards Points: 1,020
Re: What Filter?
A simple filter isn't going to do it.
hdavis is online now
Robie (07-07-2019)
Old 07-07-2019, 04:42 PM   #4
TimNJ's Avatar
Rewards Points: 5,034
Re: What Filter?
Sounds like acid in the water.
My inlaws house, in the pine barrens had high acid and ate through their pipes a few times before my FIL went to CPVC.
Then when nephew bought the house he put in a system to cut the acid.
Kind of expensive I recall him saying, but I think he got one of those "Culligan" type companies.
Try a plumbing supply for a system price directly.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
Robie (07-07-2019)
Old 07-07-2019, 04:55 PM   #5
Robie's Avatar
Re: What Filter?
Yeah, like I said, the entire place got re-plumbed with pvc except for the boiler...probably a grand total of 4' of copper if you put it all together.
PITA.
Robie is online now
Old 07-07-2019, 07:01 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,713
Re: What Filter?
Yep, acidic water. Takes chemical treatment as opposed to mechanical filtering.
Not really all that burdensome once the setup's in place--maybe once every 2-3 years you need to mess with it. But probably $1K or so for the initial setup.
Tinstaafl is offline
Robie (07-07-2019)
