Wet Basement? Any Idea Where Its Coming From - General Discussion - Contractor Talk
Old 03-24-2012, 08:17 AM   #1
Coombs Construction
Leafan's Avatar
Trade: Owner operator of Coombs Construction
Rewards Points: 150
Hey guys. I just got down to the basement Friday to start drywall and noticed the foundation wrap was wet. See the pictures below. I dont get where it's coming from. The wall has been open (no vapor barrier) the whole time. I am thinking condensation or something. The spring thaw is happening now so it's concerning to see this wet.
The water seams to only be on the bottom 3-4 feet but on the inside of the house. I would think nothing can penetrate the foundation wrap for outside. We have no water in the house yet ?
Any ideas where it's coming from and how to stop this. I really don't want to close up anything till I know this will not be a future problem.
Wet basement? Any idea where its coming from-image-2082363327.jpg   Wet basement? Any idea where its coming from-image-3077439325.jpg   Wet basement? Any idea where its coming from-image-4069683779.jpg
Leafan is offline
Old 03-24-2012, 08:23 AM   #2
jamestrd's Avatar
Trade: wood flooring
Rewards Points: 1,280
Re: Wet Basement? Any Idea Where Its Coming From
judging by that map...i would say that big river
James Hernandez
All Flortec Inc.
West Milford,NJ
www.flortechardwood.net
jamestrd is offline
The Following 3 Users Say Thank You to jamestrd For This Useful Post:
Cwcoomer (03-24-2012), fourcornerhome (03-24-2012), FramingPro (03-25-2012)
Old 03-24-2012, 12:50 PM   #3
Coombs Construction
Leafan's Avatar
Rewards Points: 150
Lol. Maybe. *rollseyes*.
Leafan is offline
Old 03-24-2012, 01:58 PM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 492
what kind of framing job is that?
3bar is offline
Old 03-24-2012, 02:02 PM   #5
Coombs Construction
Leafan's Avatar
Rewards Points: 150
The homeowner framed the basement. Tried to keep everything tight as possible. The ledge behind the framing is the underpin.
Leafan is offline
Old 03-24-2012, 02:35 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,352
That dimpled foundation wrap; is that on the inside of the foundation wall? What kind of damp/wet proofing is on the outside of the foundation? What is the vapor permeability I that dimpled stuff?
Morning Wood is offline
Old 03-24-2012, 02:38 PM   #7
Coombs Construction
Leafan's Avatar
Rewards Points: 150
Originally Posted by Morning Wood
That dimpled foundation wrap; is that on the inside of the foundation wall? Yes What kind of damp/wet proofing is on the outside of the foundation? not sure. What is the vapor permeability I that dimpled stuff? Well it's plastic so I would think it wouldn't allow any moisture through it. It also runs down to an inside weeper.
answers above. Lol.
Leafan is offline
Old 03-24-2012, 02:53 PM   #8
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
I would think that's condensation. Get some air moving.
katoman is offline
Old 03-24-2012, 04:43 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Well I'm no expert...but have you ever had a cold glass of coke on a hot day? Look at the glass, there are lots of water droplets on it. Like Kato said that's condensation, you probably learned about it in grade 5 science class.
So if we have a big heap of frozen earth...like a giant pool of coke filled with ice cubes. Then we had an exposed foundation wall...like a highball glass. We introduce warm humid weather and voila condensation.
Now if you had a layer of insulation around that foundation it would be like sliding your glass in a beer coozie, then you wouldn't see water condense on it.
Solution? Turn on your A/C, dry it out and insulate it.
Inner10 is offline
Old 03-24-2012, 05:39 PM   #10
bconley's Avatar
Trade: Kitchen and bath design+remodel
It would seem that the home owner who put the drainage layer on the inside of the foundation, thought it would help the water problem. so my guess is that it coming frome outside.
Always check the outside conditions first gutters, downspouts, grade, water table etc. first.
If it is condensation the water pipes if exposed will show signs first.
bconley is offline
Old 03-24-2012, 05:41 PM   #11
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
I work in basement waterproofing, and without seeing the outside of the house ( grade / downspouts / gutters) I would assume just condensation like others have. A dehumidifier couldn't hurt if its condensing that bad.
Jdub2083 is offline
Old 03-25-2012, 01:39 AM   #12
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,254
Oooh-kay. That's the wierdest framing I've seen in a while.
The wrap goes on the outside of the foundation to function as a drainage plane.
Inside drains are, in my opinion, a last resort, emergency measure. Moisture issues should be dealt with on the outside.
Without seeing the outside of the structure, further diagnosis is difficult. But if the HO installed that atrocity and called it "Framing", who knows what else was done poorly on the outside. Perhaps, no waterproofing, improper grading, no gravel/drainage plane, gutters discharging to close to the foundation, and on and on.
Old 03-25-2012, 06:45 AM   #13
Coombs Construction
Leafan's Avatar
Rewards Points: 150
The wrap was done on the inside when the basement was underpinned. We've lowered that basement close to 2' also installed was an interior weeping system.
The HO had no leaking issues prior to the underpin. But wanted the inside weeper installed regardless.
I am torn on what the problem is. The downspouts are close to the foundation and the grading outside is pretty good. Looks like its all slopped away. But it's also still a construction site.
I've opened up a few other places throughout the basement and the wetness is everywhere. So I an pretty sure it's condensation. Jus trying to figure out the best fix to minimize this in the future.
Leafan is offline
Old 03-25-2012, 06:47 AM   #14
Coombs Construction
Leafan's Avatar
Rewards Points: 150
This is the best I can do for an outside shot
Leafan is offline
Old 03-25-2012, 11:30 AM   #15
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
The biggest issue in that neighbourhood is the the clay thats against the foundation, when you underpinned how did you seal between the old and new? For the amount of construction you are doing I would have dug the outside and waterproofed/Delta MS/Big 'O' the exterior. It's amazing in those areas on the old houses that the brick footings and foundations are usually right above an underwater spring literally by inches and hold up for the past 60-120 years
Chris
Chris Johnson is offline
Old 03-25-2012, 01:22 PM   #16
Box Builder
You can do all you want to the inside to keep water and moisture out, but if the outside doesn't have a drain and something on the foundation walls you're mostly pissing into the wind.
Sound-proofing walls and ceilings in basement remodel stanfordconst Remodeling 22 07-05-2010 07:58 AM
Basement Remodel. BamBamm5144 Carpentry 59 03-07-2010 12:26 PM
Metal framing for basement and drop cieling joliet_man Framing 8 10-31-2008 05:40 PM
Basement Waterproofing Help eagleandbaby General Discussion 1 10-04-2008 02:41 PM
Return Grill in the Basement orson HVAC 7 10-02-2008 11:01 PM
