Well - General Discussion - Contractor Talk
Well
Old 06-20-2015, 02:16 PM   #1
natural1's Avatar
Trade: Landscape contractor
Rewards Points: 428
Well
Not sure where to post this so I am posting it here.
I recently moved to a rural area and I have a well. My first experience as a homeowner with a well. I am about to complete construction of my swimming pool. Should I be concerned about filling it from my well?
I know this is kind of dumb question because who the hell knows how much water I have underground.
The well is 600' much deeper than the average well for the area. the pool is kind of large 40,000 gallons.
As far as I know well water is plentiful in the area but should I play it safe and get water delivered.
Thanks....
Mike
http://www.natural-designs.com
natural1 is offline
Old 06-20-2015, 02:26 PM   #2
kixnbux's Avatar
Rewards Points: 1,440
Re: Well
I'm on a well at my house. Wouldn't think twice. You're not going to drain an aquifer with any pool.
kixnbux is offline
The Following 2 Users Say Thank You to kixnbux For This Useful Post:
natural1 (06-21-2015), SmallTownGuy (06-20-2015)
Old 06-20-2015, 02:41 PM   #3
Creter's Avatar
Rewards Points: 1,966
Re: Well
Suggest you test your well water to see if there is anything contained in it that would make getting your pool setup and the water stabilized a major difficulty.
If there is something - weigh the cost of chemicals vs having the water trucked in if it would be easier to get the water for the pool right.
Other than that -
Creter is offline
The Following User Says Thank You to Creter For This Useful Post:
hdavis (06-21-2015)
Old 06-20-2015, 02:46 PM   #4
Talking Head
EthanB's Avatar
Rewards Points: 438
Re: Well
I wouldn't run the hose full bore for 40k gallons. You could blow the pump. Maybe run it at about half and turn it off every few hours so it's not getting too hot.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 06-20-2015, 02:55 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 966
Re: Well
You're not going to drain the aquifer, but without knowing the well's flow and recovery rates, you could be chancing running out of water for a few hours--several times. And as Ethan says, your pump isn't designed for that kind of punishment.
It'd probably take nearly a week to fill it that way.
Tinstaafl is online now
brickhook (06-21-2015)
Old 06-20-2015, 05:48 PM   #6
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Re: Well
I'm on a well, I would never run it that hard. Not sure the duty cycle on it but that would be a place to start. I don't think water delivery is available here, whats that cost?
SuperiorHIP is offline
Old 06-20-2015, 06:08 PM   #7
rrk's Avatar
Rewards Points: 4,864
Re: Well
Where I live everybody has wells and no one fills their pool up with them. That pump would be screaming after 40k gallons. Water may be $1000 to fill it by truck
rrk is online now
Old 06-20-2015, 06:10 PM   #8
Re: Well
I know my well pump is $600, well worth the $1000 to not abuse it IMO.
The Following User Says Thank You to SuperiorHIP For This Useful Post:
rrk (06-20-2015)
Old 06-20-2015, 06:30 PM   #9
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Re: Well
Our well could handle filling a pool over the coarse of a week or 2. But the water contains so much iron its not a option.
JAH is offline
Old 06-20-2015, 06:44 PM   #10
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Re: Well
I've got a 18x36 pool 3-8'. Would not suggest you fill it from the well, besides taking forever and a huge question for the pump what happens when you don't have house water? Just changed the liner and it took 4 loads of water at about $300 each, cheap knowing that I'll get able to go inside and still be able to shower and cook. The water from the trucks should be close to balanced as well, not sure about the well.
Top it off with the hose if needed, don't fill it.
Moxley-Kidwell is offline
Old 06-20-2015, 08:42 PM   #11
GettingBy's Avatar
Rewards Points: 6,486
Re: Well
40,000 gals, 4 days at 6.9 GPM, two days at 14.
I thought submersible pumps can run at 100% duty cycle for years. My bad.
"How Long Does a Water Pump Last?
It depends - on pump type, duty cycle, usage, water chemistry, even voltage levels."
"Green pool water usually indicates the presence of copper (more likely) or iron (less likely).
Brown pool water usually indicates the presence of iron or, occasionally, copper.
Purple or black pool water usually indicates the presence of manganese."
and don't forget the pH level.
GettingBy is offline
Old 06-20-2015, 08:57 PM   #12
klintala's Avatar
Trade: General Contracting/Concrete
Rewards Points: 136
Re: Well
Bring in water and top it off with your well. It's a pretty common scenario in the country.
klintala is offline
Old 06-21-2015, 09:50 AM   #13
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Well
what about the electricity for a 48 hr running pump.
truck it in, ust think 3-4 load and your kids & wife will be happy.
imagine how unhappy your house will be with a dry well..or the chance of contamination by the huge in flow of water.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 06-21-2015, 10:00 AM   #14
GettingBy's Avatar
Re: Well
48 hp-hrs @ $.15 per kwh is $5.
I'd be worried about the chemicals in the water, either in the well or what you buy, the max levels of iron, copper & manganese that are generally acceptable.
Old 06-21-2015, 10:03 AM   #15
natural1's Avatar
Rewards Points: 428
Re: Well
Thanks for all the replies. The well water is heavy with iron so maybe not ideal to fill the pool.
Considering the consequences I will probably look into trucking in most of the water.
Mike
natural1 is offline
