Wedge Anchor Problem.... - General Discussion - Contractor Talk
Old 10-15-2015, 11:15 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 3,198
I'm in the process of installing aluminum railings on a set of concrete steps outside. I'm using 3/8" anchor wedges to secure the post bases.
The first three posts went fine. The last....not so well. I had a friend/coworker along to help me get the railings positioned between the posts. He drilled the four holes for the last post, using a rotary hammer. I'm not sure what went wrong, other than he kept bringing the drill in and out of the holes, like you might with a piece of wood.
Anyway, the anchors will not set and want to spin when tightening the nuts. I've tried everything to get them back out and though they spin freely, will not come out.
Anyone got any ideas for this? I can move the base about an inch either way and still have the old holes covered by the trim , cut off the existing exposed bolts and drill new holes. I tried some Quickcrete epoxy made for securing threaded rods inside concrete holes but am unable to force much down into the holes so don't know if that is going to work. I also tried to drill one out but that didn't go well.
I hate when simple jobs turn into money-losing nightmares.
Any suggestions? Thanks.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old 10-15-2015, 12:41 PM   #2
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Re: Wedge Anchor Problem....
Ran into a same problem in the past which is why we don’t use ancher wedges anymore, Simpson and Tapcon make anchor bolts, has just a bolt on the end so no over thread issues.
Getting out the old anchor you have two options, use a screw driver or needle nose plyers to hold the expandable piece
Option 2, cut off the wedge and let drop in hole, if you have a large cavity (non-filled block) I use foam first then Simpson 2 part epoxy
http://www.strongtie.com/products/an...ical/titen-hd/
http://www.homedepot.com/p/Simpson-S...XP22/100659425
festerized is offline
The Following User Says Thank You to festerized For This Useful Post:
Robie (10-15-2015)
Old 10-15-2015, 01:00 PM   #3
Railman's Avatar
Trade: Railing
Rewards Points: 1,209
To remove a spinning anchor, you can usually pry the nut upward with a crow bar, screw drivers, wedges, or similar, while you loosen the nut. An impact will also help.
Railman is offline
The Following 2 Users Say Thank You to Railman For This Useful Post:
greg24k (10-15-2015), Robie (10-15-2015)
Old 10-15-2015, 04:50 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Get a compressor and blow out any dust that you can...that my free it up.
Or, apply upward pressure when trying to tighten, they might just grab and then all is good.
They do make a finer viscosity epoxy which, even though tight, should flow around in there enough to set the anchor.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Robie (10-15-2015)
Old 10-15-2015, 04:57 PM   #5
General Contractor
greg24k's Avatar
Rewards Points: 8,882
I always use Sleeve anchors, never any issues with them in concrete or hollow block.
greg24k is offline
Robie (10-15-2015)
Old 10-15-2015, 06:43 PM   #6
Robie's Avatar
Thanks everyone. Was unable to pry them up and didn't want to ruin the concrete by exerting too much pressure. I used Quikrete High Strength Anchoring Epoxy and forced it down around the anchor as much as I could and around the bottom of the threads. After 4 hours, I was able to screw the nuts down with no problem. I pushed and pulled and it seems like it's holding. I was impressed. I'll finish assembly tomorrow.
― Will Durant
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
festerized (10-15-2015), Xtrememtnbiker (10-15-2015)
Old 10-15-2015, 07:21 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Robie sorry I didn't see this sooner, there is a 20 second fix for that if you have enough stud sticking out. Spin on 3 nuts, lock the last two together, tighten with the first using two wrenches.
Sometimes you can pry up on the nut a little to set the sleeve.
Inner10 is offline
Robie (10-15-2015)
Old 10-15-2015, 07:32 PM   #8
Robie's Avatar
Now you tell me....
That's okay...only had to travel 40 miles round trip and spend $18 for a tube of stuff I'll never use in the next 2 years.
I've been using these anchors for years without problem. I hate to place blame but I think it was the bit being pulled in and out that enlarged the hole enough that the sleeve didn't set.
I just hope I can put enough "oomph" on them tomorrow to keep the base solidly attached.
― Will Durant
Robie is online now
Old 10-15-2015, 07:35 PM   #9
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 108
Unless he really reamed the hole, it is not likely due to hole diameter, usually a bit looses diameter over time as it drills. If the anchor bolt was easily inserted then he reamed it too much, it you had to really hammer it to get it in, he likely damaged threads and you are spinning the bolt before the wedge grabs.
You should always use the nut to protect the threads.
As Inner said, you can put a prybar under the washer and while prying up slightly, tighten the anchor slowly allowing he prybar to lower til you have to pull it out.
Another method is to remove the nuts off the other 3, and use the handrail post as a way to pry up on the anchors while tightening, then re-install the 3 nuts
Kevin
www.BadcoDoors.com
Pearce Services is offline
The Following User Says Thank You to Pearce Services For This Useful Post:
Robie (10-15-2015)
Old 10-15-2015, 08:19 PM   #10
Inner10's Avatar
Now you tell me....
No you are suppose to retract the bit to clear debris It didn't bite because you didn't blow the hole and you used cheap redheads.
You can't pull them back out don't even try.
Inner10 is offline
Old 10-15-2015, 08:25 PM   #11
Robie's Avatar
Bit was pulled back and forth 5-6 times. I vacuumed the holes well and even used a pencil to loosen the dust at the bottom.
The anchors were from Ace Hardware...not sure of brand.
― Will Durant
Robie is online now
Inner10 (10-15-2015)
Old 10-15-2015, 08:27 PM   #12
Inner10's Avatar
Well ****...
Inner10 is offline
Old 10-15-2015, 11:00 PM   #13
VinylHanger's Avatar
Rewards Points: 14,030
Here is what we use for railings. Easy and fast. Very little chance of them not holding. They do use a special bit, but once you use these, there are lots of applications.
http://www.powers.com/product_7204SD.php
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
festerized (10-17-2015), Robie (10-16-2015)
Old 10-15-2015, 11:27 PM   #14
gfourth's Avatar
Trade: Structural & Misc. Steel
Rewards Points: 164
I've had that problem with only a handful of Hilti TZs through the years. I've got them out with a large crow bar and a lot of force, and they come out flying. If you can get them out... replace with epoxy and all-thread like an above poster said, simpson set, simpson set xp, or hilti, etc...
Sent from my SAMSUNG-SM-N900A using Tapatalk
gfourth is offline
The Following User Says Thank You to gfourth For This Useful Post:
Robie (10-16-2015)
Best trick you learned from an old schooler dnconstruction Carpentry 1491 11-12-2017 06:02 PM
How soon can I drill wedge anchors into 18" deep x 10" diameter (sonotube) footer? Tucsonmetal Masonry 9 03-05-2015 01:41 PM
Why cut wedge bricks in arches, aethetics or strength? Fundi Masonry 24 02-22-2015 03:11 PM
smallest feather and wedge set available? Rock Headed Masonry 20 12-31-2013 03:47 PM
FS Delta/Rockwell 18" wedge bed planer WarnerConstInc. Contractor Swap 6 11-16-2011 05:29 PM
