Water Everywhere - Help! Help! Help! - General Discussion - Contractor Talk
Old 04-26-2014, 04:37 PM   #1
dreamworxco's Avatar
Trade: Developer
Rewards Points: 66
Today I went back to one of our properties that was vacant for the winter. The water had been turned off for approximately four months.
When I turned the water valve back on, water started leaking steadily from the water softener, from behind the wall near the washer and dryer hookup, under the bathroom sinks, under the kitchen sink, and from a few of the walls.
What's going on?
dreamworxco is offline
Old 04-26-2014, 04:42 PM   #2
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
Re: Water Everywhere - Help! Help! Help!
What's going on?
Were the pipes drained after you turned the water off? Sounds like the pipes had water trapped in them and it froze and burst.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
The Following User Says Thank You to Dustincoc For This Useful Post:
spazman (07-05-2015)
Old 04-26-2014, 04:44 PM   #3
rselectric1's Avatar
Rewards Points: 934
If the property wasn't heated during the winter the residual water in the pipes froze, expanded and broke through. There is likely more leaks than you even know about at this point. You need a licensed plumber.
rselectric1 is offline
Old 04-26-2014, 04:44 PM   #4
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
It wasn't properly winterized, if bet you have leaks all over
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
hdavis (04-26-2014)
Old 04-26-2014, 04:47 PM   #5
Trade: Developer
Rewards Points: 66
I was thinking the same. The heat was left on for the winter at this property for this very exact reason. This is going to be expensive.
The Following User Says Thank You to dreamworxco For This Useful Post:
mikeswoods (04-26-2014)
Old 04-26-2014, 05:16 PM   #6
PoleBarnsNY's Avatar
Trade: Pole Barn Builder
Rewards Points: 1,419
Sounds like the heat was not working properly. Be sure and check that too.
PoleBarnsNY is offline
Old 04-26-2014, 05:16 PM   #7
Rewards Points: 934
Just make sure you get a reputable licensed plumber to handle this or it will be even MORE expensive later.
They will find the obvious leaks and smoke/pressure test to find other issues that might be small now, but could cost you big time later if they are not all caught. (Example, if there was water allowed to freeze in traps, this might not be noticed until the place is "all done" and a tenant is in place)
Sorry to hear about the issue and good luck!
Old 04-26-2014, 06:33 PM   #8
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
boiler ran out of water ???
jaydee is offline
Old 04-26-2014, 06:44 PM   #9
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
What's going on?
As a side note, whenever I have winterized a home I always cut the main water supply off, then disconnect the supply lines at strategic locations (unless there already exists a means by which to perform the following task), then blow out the lines with slightly pressurized air to eliminate any residual water left in said lines. I also use an RV antifreeze to pour down the drains leading to any suspect traps (and also toilets) that might freeze.
I wish you all the best in figuring out what needs to be done. As RS said you should be focused on getting reputable professional to figure this out and repair properly.
Jeff G is offline
The Following User Says Thank You to Jeff G For This Useful Post:
hdavis (04-26-2014)
Old 04-26-2014, 06:51 PM   #10
General Contractor
greg24k's Avatar
Rewards Points: 8,906
What's going on?
You know whats going on... What I like to know is what were you thinking about not winterizing the house if you knew the heat will be off?
With that said, if you own vacant property, how you don't stop by and check at least 1-2 times a month to make sure everything is ok? Now its on you to get it fixed... call insurance company it should cover.
I know this is a bit off the subject, but just recently a few towns away- people from PA who also don't give a s^*t about theirs property, owned a house here, they haven't been by all winter to check on it... So someone came along, changed the locks, put a sign in the window "House for rent"... found tenants, ripped them off for the security deposit and rent and took off. Homeowner came and there is people living.
greg24k is online now
Old 04-27-2014, 03:12 PM   #11
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 9,066
greg24K:
And those victim tenants now have legal rights and must be properly evicted.
Kowboy is offline
The Following User Says Thank You to Kowboy For This Useful Post:
greg24k (04-30-2014)
Old 04-27-2014, 03:46 PM   #12
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
What's going on? YOU have a LEAK or two, or three! LOL
I have a few questions? Where are you located, does it get cold, like freezing temps below 32 degrees? If so, did you drain the lines, tanks, toilets, traps, etc.? I believe that you had the furnace on ? HOW can you guarantee that the power didn't fail for a few days, the natural gas ?? do you have gas or electric heat, lets start there! Utility companies are good, but can only do what they can, MOTHER NATURE has her own way of doing things! In my opinion, just a bit of "common sense" might be in the order for this one. I see this every year, and the same thing happens, over and over!
Dave in Pa is offline
Old 04-30-2014, 01:45 PM   #13
chew's Avatar
Trade: All
Rewards Points: 117
Another reason for using PEX.
Freezes and goes back to normal when it thaws out.
If your pipes are copper I will do the tear out for free
chew is offline
Old 04-30-2014, 05:23 PM   #14
Radical Basement Dweller
Robie's Avatar
Rewards Points: 3,998
Has anyone used a "Freeze Alarm Dialer"?
Says that it will dial a number every 15 minutes if the temp drops below 45*
http://www.amazon.com/dp/B0049D7FQQ/...I3TE6C1U1TCGTU
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
greg24k (05-01-2014)
Old 04-30-2014, 09:05 PM   #15
Talking Head
EthanB's Avatar
Rewards Points: 438
I don't know about the models but lots of realtors and vacation home owners used those in Vermont. I do remember someone pointing out that they didn't all have battery backups which made them pretty much useless as your heat usually went off because the power was out.
Planer.....
EthanB is offline
Old 04-30-2014, 09:44 PM   #16
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Sounds like you developed a water leak.
Water is strange that way. When it gets too cold, it freezes.
But when it gets too hot, it vaporizes.
Next thing you'll want to develop is a way to connect an air compressor to your water lines.
cleveman is offline
Old 05-10-2014, 10:01 AM   #17
Dave in Pa's Avatar
Well did you find the reason, or the leaks yet? Just curious!
Old 05-11-2014, 07:47 AM   #18
huggytree's Avatar
Trade: plumber
Rewards Points: 1,418
a good % of winterized homes still get burst pipes too......its almost impossible on a large house to get all the water out.....on a small cottage house that is designed to be winterized, yea it will work everytime....but on mansion size house id say you have 100% chance to get some broken pipes for sure
huggytree is offline
Old 07-03-2015, 11:56 PM   #19
Trade: Developer
Rewards Points: 66
Update: We did end up re-piping the entire house using PEX.
Old 07-04-2015, 04:12 AM   #20
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
good choice bad luck
pappagor is offline
Water heaters installed in garages greg24k General Discussion 3 01-26-2013 09:17 AM
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
