Vintage Ornate Patio Table - Solid Zinc? - General Discussion - Contractor Talk
Old 09-23-2020, 03:36 AM   #1
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,368
Probably made in Mexico. An ornate patio table with curly designs on the top and fancy legs. Hole at top for an umbrella. It's definitely not wrought iron as it would weigh a ton, nor is it metal coated. I had to cut into the legs so the umbrella base would fit. It's solid silver looking metal. Solid zinc?
Caslon is offline
Old 09-23-2020, 07:35 AM   #2
hdavis's Avatar
Rewards Points: 268
Re: Vintage Ornate Patio Table - Solid Zinc?
A lot of these are aluminum. I'm not sure if an easy way to tell the difference.
hdavis is online now
Old 09-23-2020, 09:57 AM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 155
Probably pot metal.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
Rio (09-23-2020)
Old 09-23-2020, 09:58 AM   #4
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 648
It does not even exist unless you have and post pictures.
Andy.
ScipioAfricanus is online now
The Following 3 Users Say Thank You to ScipioAfricanus For This Useful Post:
KAP (09-23-2020), MarkJames (09-23-2020), tgeb (09-23-2020)
Old 09-23-2020, 10:57 AM   #5
AustinDB's Avatar
Rewards Points: 20
I've seen many made from aluminum.
if it were zinc, that would be interesting. large blocks of zinc (sacrificial zinc anode) were bolted to the outside of the submarine. their job was to rust before the hull does.
AustinDB is offline
Old 09-23-2020, 01:54 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 18
more than likely it is cast aluminum.
griz is online now
Old 10-06-2020, 01:41 PM   #7
GotWooood's Avatar
Trade: Finisher
Rewards Points: 12
hit a bald spot with some Hydrocloric acid. If it bubbles a lot its probably zinc.
GotWooood is offline
Old 10-06-2020, 06:54 PM   #8
Eater of sins.
Rewards Points: 648
Zinc has a very low melting point.
Hit it with a soldering iron and see if it melts it.
If it does then it is probably zinc or a zinc alloy.
Andy.
Old 10-06-2020, 07:48 PM   #9
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 907
This
"Quality work for those who know the difference"
nickko is offline
