Undermount Drawer Slides: Blum Vs KV - General Discussion - Contractor Talk
Old 09-15-2010, 07:43 PM   #1
Master Kindler
claymation's Avatar
Trade: HIC; BLD
Rewards Points: 75
Looked for a cabinetry section here to post this in. Didn't see one... sorry, if this is the wrong section.
Was thinking about using the Knape and Vogt MuV undermount drawer slides for a cabinet job I have coming up. Haven't used them before. Has anyone here? Are you happy with them? They look a little better than the Blum slides I've used in the past, but are more expensive. Do you have a recommendation on a slide similar to the KV MuV slide that is a little less pricey? I only need 3/4 slides for these cabinets, but it looks like the KV MuV only come in full extension models. If I go with the KV MuV slides I'll need a supplier, too, if you know a good one.
FYI: drawer faces will be flush, inset on a 4 sided drawer box. I am assuming that doesn't matter with these slides and they will accommodate that. If you know otherwise, please let me know.
Appreciate any advice you have on this. Thanks!
claymation is offline
Tags
drawer , full extension , inset , slides , undermount
Now this is a drawer slide.. Leo G Finish Carpentry 34 05-28-2010 12:16 PM
My cabinets guys sprayed sanding sealer on the cabinet drawer guides? MakeItHappen Painting & Finish Work 2 03-22-2010 10:46 AM
Drawer slides? mattsk8 Finish Carpentry 42 01-26-2010 09:57 PM
Blum hinge machine- Long Island Splinter Contractor Swap 0 09-07-2009 09:00 PM
Concrete slides Shaughnn Concrete & Paving 4 04-01-2009 08:39 PM
